Just bought and connected 160 firewire. the icon appeared, but that's all. I have an imac g5 10.411 tiger. I've had my logic board replaced twice, so I want to backup my entire computer onto this. I was assuming something would appear telling me how to do that. could you steer me in the right direction? thanks, don
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello there
1) verify and reconfigure firewire.
2) verify drivers for 160 FW
for mAC
Posted on Jun 16, 2008
IMac will not start up.Question mark in a box comes up.Also will not boot up from start up disc
The operating system on the hard drive is corrupted, or the hard drive is not available. The procedure for starting from the startup disk varies a bit depending on the model of iMac. On the oldest ones (CRT iMac) and some of the early display-on-a-dome models, hold down the "C" key while starting the computer. This will force the computer to bypass the hard drive and boot directly from the startup optical disk. (If the C key doesn't work, restart and follow the option key procedure in the next paragraph.)
On newer Macs, hold down the option key while pressing the power button until you see that the boot loader is running. You should see an icon for at least one drive on the screen, perhaps followed by another. One of these is for the optical drive. It may take several tens of seconds for the optical drive icon to appear, particularly on older iMacs. Use the arrow or tab keys to select that one, then press return to start loading the system on that disk. If you only see the optical drive icon, that confirms there is a problem with the hard drive. Try Disk Utility anyway; if it can find the hard drive, there is some possibility of recovering it, or reformatting and loading from your backup. If the hard drive icon appears in the startup option screen, Disk Utility may be able to repair the problem if it is a file system issue affecting system loading. If a fundamental system file is corrupted, you will likely have to reinstall the OS.
In the worst case, the hard drive has a physical problem. Most of the time this is mechanical (sometimes announced with repeated, regular clicking noises as the drive vainly hunts for its starting position). Rattling noises (like the head has separated from its arm and is bouncing around) are also most unwelcome. Occasionally, the problem is with the controller board on the hard drive. In this case, if you can find another drive of the same model, you can swap controller boards (doing so successfully requires observing electrostatic discharge safety procedures to prevent zapping the drive, and properly identifying and operating the latch mechanism for the ribbon cable connector that connects the board to the drive mechanism). Generally, however, you have to replace the hard drive. Once in a while, the problem is with the cable between the hard drive and the logic board. On the old Macs with IDE drives (40-line ribbon cable connecting both optical drive and hard drive on some, two such cables on other models), there may be a bad connection on one wire because the wire is not properly seated in its two-tined fork inside the connector. To reseat the wires, gently push the cable down right at the connector shell (towards the surface of the connector shell that is pushed onto the pins of the drive or logic board). Do not put a crease bend on the cable there; you're just trying to make sure the wire is in the bottom of its fork. Repeat on the other side of the connector with the end of the cable (use a fingernail to catch the edge of the cable end).
Aug 28, 2014 | Apple iMac Computers & Internet
My imac firewire port in not detecting my firewire sound card
Verify support and download drivers from your sound card manufacturer's website.
Open up Mac System Profiler by clicking the Apple in the top left, then about this mac, then go in to more information. Connect the firewire sound card and see if it becomes detected but is simply unknown. This will be a sure fire way of determining problem is with lack of drivers.
Sep 26, 2012 | Apple 21.5" iMac Desktop
Imac continuosly goes to sleep
Go into System Prefs, Energy Saver and disable sleep for hard drives and display. If it still appears your computer is going to sleep, this may be a display problem, being caused by logic board, actual display or graphics card, all requiring a trip to the apple store for service.
May 12, 2012 | Apple IMAC IMAC CI3306 215 4GB 500GB DVDR
My computer starts up and you hear the chime andthe little led lighton the bottom right lights up and stays solid but the screen remains black. i still hear sounds from the mac but i still have a black...
If the light stays solid for as long as you have it on then I would say that the logic board is dead. I would not bother fixing it, a new logic board costs almost as much as your computer on ebay used. If you still prefer to replace it yourself here is a link to the logic board and here is a guide to replace it.
However, if the light comes on and then goes off it is probably the screen.Guide Part.
Sep 21, 2011 | Apple iMac Z0CY Desktop
I have an imac intel 17" which is kernel
If someone has looked at this issue and determined it to be a logic board problem then the only solution is to replace the entire logic board.
You can purchase them on usedmac.com here for $289:
http://www.usedmac.com/catalog/product_info.php?cPath=34_160&products_id=2384&osCsid=555099ea1dd6e69fa573fbc345fbe149
Here are instructions on replacing the logic board yourself:
http://www.ifixit.com/Guide/Repair/Installing-iMac-G5-17-Inch-Model-A1058-Logic-Board/971/1
Feb 06, 2011 | Apple iMac 17" Desktop
I have one blue and one green horizonal lines
First you need to find out if the problem is with the display or with the video card. If you connect an external display to the iMac and see the same lines on the external display the problem will be with the video card, which is attached to the logic board. So the logic board will needed to be replaced.
If the lines don't show up on the external display. The problem is with the internal display module, which will need to be replaced.
Feb 02, 2011 | Apple iMac G5 Desktop
I'm trying to find a web cam w/mic that is compatible for an imac m5521
Hi Krystine. If your imac has firewire ports then look on ebay for an Apple iSight Camera.If you haven't got Firewire - and even if you have. it's wqorth looking here http://agent.liquiddigital.com.au/
This is a USB version of the Apple iSight in all but name.
I've seen it working and can vouch for its quality.
Sep 08, 2010 | Apple iMac G3 15" M5521 Desktop
G5 dual processor keyboard freezes for 10 seconds or so
you might need to check the usb connections for the keyboard and mouse. and see if they are correctly connected, also to clean the connections with a q-tip from time to time. Also you might want to switch to another usb port. to narrow down the issue. Because if say you change to another port and it still persists, even when running a usb hub with external power, and even a external firewire hub with usb connection then the issue would be the com board for the usb and firewire. and hopefully the G5's usb, firewire ports are on a separate board that is then ribbon wired to the main board. because if its just ports ribboned to the main board you will need to get a new logic board. and that is not cheap. unless you still have your applecare. then just take it in to get replaced.
Jul 02, 2009 | Apple 24" iMac Desktop
Lacie 150 running on Imac G5 Tiger 10.4.11
Hello, I assume that this is a FireWire external drive. Do you have any other FireWire devices (another drive, older iPod, etc) that you can test the port with? If other devices work, then the port on the drive has malfunctioned, or the drive needs repair (try Disk Warrior or First Aid in Disw Utility within OS X Applications...Utilities). If those other devices don't work either, then the port on the computer may be the problem (meaning logic board). You can also try creating another user in OS X, and testing the ports and the drive under that user. If all is well as another user, then you may have a software issue in your own user account.
Jun 13, 2008 | LaCie (300728U) 250 GB Hard Drive
Using a MacBook as an external HD
Try reading here: Apple
Even though the article refers to Leopard, it should work for Tiger.
Here is the catch: The iMac needs a FireWire port
Mar 26, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
