Question about Insignia 42" LCD Flat-Panel HDTV
Channels change by themselves after 20-30 minutes of tv being on
This week my TV started going crazy on me. I'll be watching TV and the channels will just start changing on their own on the TV itself ( not the Directv) No matter what I do it will not stop and when I try the TV menu the tv is still going crazy through the menu options and will not stop. Finally I give up and shut the tv off. After about 10 to 20 minutes I turn it on and its fine again for about 20 minutes then it starts all over again. It's very aggravating because I can only watch 20 minutes of tv at a time. I tried watching a movie last night and finally gave up. Does anyone have any idea what could be causing this problem?
  • dazstud Oct 20, 2008
    omg im exactly the same i got mine 2 days ago and its got worse so im goin to call the shop up and get a replacement but mines a 40" samsung 1080p
  • shootout Dec 13, 2008
    I am having the same problem and found a weird thing that fixes it temporarily. Next time it does this take your finger to the bottom right of the TV and graze back and forth over the grove. I know this sounds insane but my TV is weird and decides that this is what she will listen to. If anyone knows a more permanent and humane way to fix this problem, please let me know as my finger is getting sore :).
    Problem Solver:
  • 8 Answers
Have you tried covering the IR eye on the front of the TV when this starts occuring? Sometimes other devices in your home can emit infrared light that in rare cases can be picked up by your TV as a command from the remote. If covering the eye seems to stop the problem, I would say my guess is correct. If the problem continues even with the IR eye blocked I would say that the internal tuner of the TV might be defective. good luck!
Posted on Jun 17, 2008
I have just connected my Viera to power & antenna. The screen said "New channels found" so I selected that. It said it would take 3 minutes. It found the channels and stated on the top yellow...
Run through the set-up again and after it says channels found, at the top YOU MUST hit the SELECT on the screen in order for the set to log them into memory, otherwise there will be nothing. So high-light the select after it all done and your ready to go.
Jan 18, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
I have a HP PL5060N My TV is going nuts. The channels change on their own no matter if I am watching TV, gaming or watching a movie. I just get booted out of where I am or the TV show to watch the new...
Take the tv aparts.Take the tv manual control board aparts.Reajusting the board and screws it back in.Should solved ur problems,if not than the whole tv Tuner signal board is the causes and the problems.That the board,where the incomming broadcasting signal board plug into it,this board have intermittent problems and the causes.Try website like Ebay.com t buy a whole refurbish tv Tuner signal board for the replacement.
Dec 06, 2010 | HP PL5060N 50 in. Plasma HDTV
Could you tell me why the tv insignia channels swich fron 2 to 3 channel, and the tv value is going up and down by itself? Because I"m not able to watch my programs. Can You help with this?
if you have set top box ,go to main menu ,check on restore factory settings ,put in default password 0000 and press ok,restarting the set top box automatically,waiting for some minutes.
restarting starts scanning all channels one by one and put them on their respective location in channel store.
now ,enjoy with all channels.
same process is done with tv if u have't any set top box ,only RF input from ur cable operator.
Nov 29, 2009 | Insignia IS 20" TV040919 TV
Sony KV-27V22 scrambled picture and loud buzzing audio
the variation from higher channels from lower channels, few things changes eg frequency, voltage, and current.
take your tv to a w/shop and have the following
tunner voltage pulse variation on a avo meter has you change channels. if the difference of voltage is not unform when you are changing from to channel then you should change the control ic on the rf stage or check the capacitors a round the rf ic for variations in value.
Mar 25, 2009 | Sony KV-27V22 TV
Mitsubishi WS-65611 tv channels cannot stop scrolling
Check to make sure the channel down button is not stuck. If it is not the button is probably defective. Mits has had a lot of problems with the buttons.
Jan 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
LG 42LC7D TV does not want to chg channels after 5 min of use
There are some inductors that are out of spec. LG's original SB said to replace some of these with a jumper, but it only lasted a couple months.
You need to have the Total Main Assy replaced.
Jul 28, 2008 | LG 42LC7D-UB Television
Sound and Volume trouble
I bought my Insignia 32" LCD in November 2007 - same problem. I figured out that if you press the "input" button on your remote select any of the other options "component 1, composite 1, etc.. that you're TV isn't on -then press "input" again and go back to the component that you're TV plays on - you'll have volume when you go back every time. I've gotten so used to doing it now that it's become habit. 9 times out of 10 I have to do it.
Mar 15, 2008 | Insignia IS-LCDTV32 32 in. Television
Crazy TV?????
Hi, either the eprom is corrupted or the front control board is bad, the control board can be a diy job but not the eprom. Have you pulled the tv`s AC cord for 30 seconds and then plugged it back in to see if that will do a re-set on the micro ? If not try it, you`ll have to remove the back of the set and pull the cable from the control board while it`s on so if this makes you nervous call a tv tech instead of attempting it, be advised that removing it while the set is turned off will not work because of course there is no way then to turn on the set, hope this helps, questions? e-mail me back, BMW Rider
Dec 31, 2007 | RCA TruFlat 27F520T 27" TV
SPECIFIC FIX FOR GE 32GT660
I have the same problem, except that it would turn on by itself and then start changing channels. I had a can of compressed air and sprayed the button areas to see if there were sticking. It worked for a coupe of days, then started happening again. So I searched the web and found a response to a question someone else posted and the ensuing reply "most likely you have one of 2 things going on one is the foam between the buttons and the switches or you may have a switch getting leaky and would need replaced" Looks like I may have to taking the cover off and find some type of electronic cleaner, or replace the buttons. I find it odd that I got hits for the same issue with the same model. hhhhmmmmm?
Nov 21, 2006 | GE 32GT660 32" TV
Insignia 42" LCD Flat-Panel HDTV Logo
752 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
