My xbox wont read disk, when it does the game tray opens and closes at random times and the light flashes like its trying to open constantly, any ideas on how to fix it?
The main problem might be a big problem with the disk tray. There might be an faulty wire that has lost connection and if your disk wont event turn on, there might be a problem with the power supply that supplies the cd tray. If the disk opens and closes but doesnt read and wont say tray is in and keeps saying open tray, there might be a small fracture on some of the wires or there is something wrong with the motherboard of the xbox 360. The best way is to buy the warrenty now and send it to the xbox 360.
First Turn your X-box on
Second Take out your game or CD
Third Open tray
Fourth Close tray
Fifth Repeat Third and Fourth a couple times and let it load then open
Sixth Stop when you hear the xbox make a spinning noise like when it is reading a game
Seventh Open tray
Eighth Pit a game in
Ninth Close tray
Tenth Play you game!
take out the cd. close the tray with no disk in it. let it read till it says open tray
open and close it like 3 times with tha method mentioned above with out the disk. then put the disk back in and it will probly work.
sometimes the system turns dumb and u haft to remind it to reconize when there is actally no disk.
My 360 is/was having a similar problem...my 360 would say "reading disc" then "open tray". Well since my system is only about 8 months old...I opted to send it in for repair. Its under warranty. My system is in route to be fixed as we speak. I would advise you to get yours registered too.
I have had this happen about 3 times. The first time was when i figured out how to fix it. The 2nd and 3rd were temporary.(Just needed to be turned off for a moment) You need to shut the console off for atleast 15 minutes 10 at the lowest with everthing unplugged. I mean the hard drive, memory unit, and all cables, and adapters. Then after 10-15 minutes plug everything in and DON'T PRESS the BUTTONS ON THE XBOX OR THE CONTROLLERS. Press the button to open the tray and take out the game or dvd and put in a different one. If this doesn't work do it all over again and then put in a different game or dvd not the previous ones and turn on the console the same but then a soon as you get the disc in and closed in shut it off then open the tray and wait till you are at the main menu go into any program so you can't see it is reading and close the tray. If that doesn't work contact the xbox support line. Really hope this works for you.
well i had the same problem with my xbox is i opened the faceplate and pressed the button and if that doesnt work u will have to wiggle it around a little bit if it comes out what u need to do is take some WD-40 and spray some on a cloth or something to wipe the sides of the tray and the silver part of the tray and open and close it a couple of times if it opens and closes put the faceplate back on and it should open and close now
