Question about GE Zoneline AZ38H12DAD Split System Air Conditioner
Remote Thermostat Control hookup for AZ28E15DABM1
I recently purchased a remote thermostat control model RAK148P1 for my Zoneline model AZ28E15DABM1 (which was purchased 2 years ago). But, the remote thermostat instructions only tell you how to REPLACE an existing thermostat...but do not tell me how to do the original wiring to connect the remote thermostat to my A/C. Can anyone help with this issue?
I called out an electrician and he wired it for me. Even told me they sold me one not designed for my model, but he retrofited it and it works fine. Been about a year now.
Posted on Jun 18, 2008
Where can I find an instruction manual for a n american standard remote for a trane split heating and ac unit?
AccuLink Remote Control - American Standard
Find more information on the AccuLink Remote Thermostat available from ... terms for your AccuLinkTM Remote Thermostat, please refer to your owner's manual ...
Thermostat Controls - American Standard
Discover thermostats and get a digital thermostat for your home with American Standard. ... 7-day programmable comfort; Remote monitoring and programming ...
Free American Standard Thermostat User Manuals ...
Products 1 - 34 of 34 - Find the user manual you need for your home appliance products and ... American Standard Central Thermostat Installation Instructions.
Free American Standard Air Conditioner User Manuals ...
Feb 03, 2016 | American Standard Heating & Cooling
Hunter 44665
You can get the manual at:
Normally these thermostats read remote temperatures but do not use them for control. The external remote sensor is normally put outside in our area yeilding an inside out side thermometer.
Nov 22, 2013 | Hunter Fan Company 5/1/1 Programmable...
GE Model AZ25E09D3CM1 Serial HF 655868 No unit reponse at all regarding fan operation or compressor. Unit seems like no power supply. There is 240 vac power, 24vac supplying the outer board &...
Not certain but I believe 19 is required. Where are you reading this 16.9 and take a reading from the outdoor unit WITH OUT the wire attached and see what you get. Possibly a bad wire heading inside or weak transformer.
Jan 29, 2018 | GE Zoneline AZ35H12D Air Conditioner
How to connect to my Air conditioner AZ28E15DABm1 GE a thermostat model TR400 HC-A SECO?
carefully follow the below steps;
Turn off the circuit breaker that controls the air conditioning system. Turn the thermostat to the "On" position to make sure that all power is cut off and the air conditioner cannot accidentally operate.
Remove the cover of the existing thermostat and remove the colored wires from the terminals. Take out any screws that secure the thermostat to the wall, and remove the thermostat.
Mount the new thermostat on the wall. Feed the wires through the unit, with enough slack to allow you to make the new connections.
Connect the red wire to the thermostat terminal labeled "RH," "RC" or "R." The red wire carries the power from the transformer.
Connect the green wire to the thermostat terminal labeled "G." This controls the relay that controls the fan. Attach the yellow wire to the "Y" terminal of the thermostat. This powers the main control. Connect the white wire to the "W" terminal. This is the heating control wire.
Close the thermostat's cover and turn the breakers back on. Turn the new thermostat to the "On" position to test it and that would be all.
I hope the above helps. If it is not helpful, please let me know so that I may direct you further.....
Good luck.
Feb 25, 2011 | GE Zoneline AZ38H12DAD Split System Air...
Is it posible to konnect a remote thermostat model TR400HC-A to the air conditioner model AZ28E15DABm1 GE? The Zoneline Air Conditioner is working "On" "Of" and again when the outside...
You can connect That thermostat provided your unit must have option of 2 stage cool and 2 stage heat. If not you have to jumper with Y1 and Y2 and also W1 and W2. Follow the manual and wiring diagram. If any more details plz write here again. Thanks.
Feb 16, 2011 | GE Heating & Cooling
Hello. The company I work for recently purcahsed an F13BR36-C ice cream cabinet with remote condensor unit. I've installed the condensor unit; however, there is no temperature control for the cabinet and...
You need to install a thermostat to cut off control power to condenser contactor at a set temperature that you will have to set, let's say; 5 degrees for example. You should be able to purchase a thermostat at any A/C & refrigeration store. If you are familiar with control, this should an easy job.
Good Luck!
Dec 17, 2010 | Delfield Refrigerators
How to program Honeywell thermostat for remote sensor
Remote Sensor (Setup Function 0340): If an optional outdoor sensor is installed, the thermostat can display the outside temperature. If an optional remote indoor sensor is installed, the thermostat will display the temperature at the sensor location (the internal sensor in the thermostat is not used).
\ 0 No remote sensor
1 Outdoor sensor (display only)
2 Outdoor control sensor (select heat pumps
Dec 31, 2008 | Honeywell Heating & Cooling
Could be the main control board.
Could be that somebody has been messing with the dipswitches beneath the control board.
Dec 22, 2008 | GE Zoneline Deluxe Series Cooling &...
Zoneline PTAC short circuit
Most likely you will need to either replace transformer or there may be a low voltage flat type "car fuse" usually 3 amp or 5 amp for just such an occasion. Good luck!
Mar 29, 2008 | GE Zoneline AZ55H07D Air Conditioner
Temperature varies 13 degrees around setpoint on aux heat
I don't have the book for this particular unit but, check the sequencers that control the electric heat mode, as the regulator heat pump works good. The part may have a time or temperature delay that is too long for you. Also if it has a remote thermostat, check the heat anticipate setting. You will have to check the installation manuel, but its usually .6 to .8, but I don't think that is the problem.
Nov 28, 2007 | GE Zoneline AZ55H09D Air Conditioner
GE Zoneline AZ38H12DAD Split System Air Conditioner Logo
514 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
