Sorry for the multiple posts in a single day...
I have solved this issue!!! (In my case anyhow)
WARNING: What I am posting here can cause SERIOUS problems with your computer if you do not know what you are doing. If you doubt yourself, then DO NOT DO THIS.
Using information I found at: http://www.fixya.com/support/t567993-local_machine_installation_failed
Heres what I did:
1) I downloaded the latest version of RegSeeker (Link provided in the other fixya post referenced above).
2) I ONLY did a "Find in Registry". Typed "AVG" and did a search. (I searched for Grissoft as well, but it found nothing)
3) With the list of registry entries I then at the bottom, selected all using the "Select" link(with a green checkmark next to it.)
4) Using the "Action" Link (Also at the bottom) I deleted all.
5) Go to "C:\Program Files" and delete the "AVG" Folder.
6) Reboot machine
7) Start fresh install of AVG 8.0
8) Perform updates to AVG 8.0
AGAIN... This worked for me. IT MAY NOT WORK FOR YOU.
Changes to your registry by ANY means should NOT be done by those not familiar with operating systems.
For what it's worth.
Joe
Error: Action failed for file avgmfx86.sys: starting service....
Error 0x80070002
Whats it mean, this kind of problem?
You have to reinstall avg software
pleast tell me in brief when are you getting this message
brand of your computer and operating system
if its a DELL provide me the service tag
located on the right hand side of the tower
its located on a black sticker which has a 7 digit alphanumeric number
Thank you very much. I had the same problem on my hp pavilion DV4 laptop. I succeed after doing the same step three times. Trying again and again might help.
SOURCE: cant Local machine: installation failed
the same problem also weak up all the night with out any solutions problem is icab instal avg 7 but not 8 .
i regognized somethig when i instal avg antimalware if i chose to install spyware the shield will not work if idont chose spyware the shild will work propably !!!!!!
SOURCE: Local machine: installation failed
this error message is connected with avg antivirus program. boot in safe mode and uninstall this program. boot up again and then re-install avg
problem in installing in avg antivirus 8.0 avgmfx86.sys
I have (I think) the same problem....
Installation:
Error 0x80070002
I've looked in Add/Remove programs but it is not listed.
SO... It thinks it's installed, but I can't un-install to try again...
Anyone else have ideas??
Thanks,
Joe
Added note: (I feel stupid now)
I found the "Uninstall AVG" link in my start menu, but got this:
Local machine: prepared for the installation
Installation:
Error: Uninstallation is not possible. Product not installed.
This Laptop is an Acer TravelMate 630, Fresh install of Win XP Pro SP3
Setting it up for my son, so it is lacking...
512MB Memory, 1.5ghz Processor.
Is this a glitch with AVG 8.0? I have older versions on other machine doing just fine...
Any advice would be helpful
This problem is in avg 8.0 version software
i get this message at the end of the installation process please help
action failed for file avgmfx86.sys:starting service error 0xc00703fa
i've got this message when i tried to remove the avg software "avgmfx86.sys"
Error 0x80070002
I can't upgrade, it keeps repeating that a bin file is missing and was able to
get the following file: AVG MFX86.don't know what to do.
Delano
This is the error I'm getting after attempting to install AVG's free version of their virus protecting software.
"Action failed for file avgmfx86.sys: starting service....
Error 0x80070002"
I have taken the following steps with a reboot after each step:
Not sure what else I can do at this point except install some other respectable antivirus software, like Panda or something. But it irks me to no end that AVG can't be installed on this computer.Uninstall all other anti-virus apps (had an old version of Norton before)
Ran CounterSpy (www.sunbeltsoftware.com) to remove AntiVirus08, the infamous fraudware app
Ran RegClean
Ran RegSeeker's autoclean feature
Did a thorough search for anything antivirus related incluiding "AVG", "Grisoft", "antivir08" (and variations).
Removed anything that was suspicious but clearly not system file that Win would need.
Installed all Windows updates, including SP 3
System data:
MS Windows XP Home
Version 2002
SP 3
HP brand
Intel Celeron M, 1.GHz
480 mb of RAM
Thanks in advance for the help!
Hans
same
Error 0x80070002
evry time i instal avg it appears as action failed for avgmfx86.sys: starting service....
Error 0x80070002
Error 0x80070002
Error 0x80070002
I had the same problem but fixed it using acesdwn's solution. It worked great thank you for the easy to follow instructions... Â HP XL795 Â XP Â Bob
no me intala el antivirus
Error 0x80070002
it would not download avg on my computer
olmnlm
Same Here
same it
=[ I have the same problem
same thing t says AvgMfx86 needed restart ur compi
Error: Action failed for file miniavi.avg: creating backup....
Error 0x80070020 %DESTINATION% = "C:\WINDOWS\System32\Drivers\Avg\miniavi.avg.install_backup", %SOURCE% = "C:\WINDOWS\System32\Drivers\Avg\miniavi.avg"
Error 0x80004004
i uninstalled my avg 8.5 edition to install the pro version and it is saying i cant install anything as there are pending deletes from old version which arent deleting during start up.
AvgMfx86 is missing or needs reinstalling
kan ikke hente avg fejl Local machine: installation failed
Installation:
Error: Action failed for file avgmfx64.sys: starting service....
Error 0x80070002
Rollback:
Error 0x80070002
Error 0x80070002
avgmfx86.sys
