Question about Samsung WF337AA Front Load Washer
Samsung WF337AA Front Loader
When it comes to sycling it shows 7E and the washer will stop. Could you help me and let me know how to fix this error?
Hi Ya, I had exactly the same problem with my washer. 7E means that the water supply has stopped or is too weak. So I unscrewed the water hoses at the rear of the machine (turn water taps off first) and removed the little filters from the inlets on the machine by **** them out with a small screwdriver.. I then cleaned the filters out with a small brush and hot water, refitted them and HEY Presto!! All fixed. Good Luck Greg NZ
Posted on Jan 05, 2009
    New Friend:
I was able to solve E7 error code by bypath IH signal from Silver Care Unit to MAIN CPU board.
Samsung WF337AA Front Loader - samsung-washer--wf306law--xaa---ag-unit--with-fix--wire-pic1-j0lckjmzkrtf4sdudsjndtkn-3-0.jpg
Posted on Oct 21, 2017
Ok that didnt work
Posted on Apr 03, 2010
My front loader washing machine samsung has an error SE. What does this mean.
Contact supplier and ask them the get the right answer.
Jan 09, 2015 | Samsung WF337AA Front Load Washer
Unfortunately I do not have '7E' in my list ;-0(
However I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 31, 2011 | Samsung WF337AA Front Load Washer
2008 Samsung front end loader develops a 4E error
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Jul 12, 2010 | Samsung WF337AA Front Load Washer
Error code de on samsung front loader J845
The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you have a warrenty!
Jan 26, 2009 | Samsung WF337AA Front Load Washer
Samsung wf337aa front loader
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jul 13, 2008 | Samsung WF337AA Front Load Washer
Error code 7E
Silver Care Kit (Silver Care PCB) Failure.
Check Silver Care PCB ,Main PCB & Wire harness
Jan 27, 2008 | Samsung WF337AA Front Load Washer
Samsung 306BHW-Error code 7E
I don't know what the problem is bUT I HAVE THE SAME PROBLEM TOO ON a machine 8 months old
Dec 03, 2007 | Samsung WF337AA Front Load Washer
Samsung WF337AA Front Load Washer Logo
935 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
