Question about Motorola Mobility C168 Cellular Phone
Help my jabra corded headset stop working, but it works on other phones
  • 294 Answers
Jabra corded head set are not as that compitable in motorola cellular phones.as compare to the nokia 8000 or nokia 3000. so basically it may create problems.. cheers!!
Posted on Jun 23, 2009
My phone asks for headset in "discoverable mode" How do I get it there?
What kind of phone do you have? I have heard people with LG phones say that it does not pair with their phone. If this is not an issue with you then these steps may be more helpful:
1. Charge your Jabra BT135 until the solid blue LED turns off
(approximately 2 hours)
2. Make sure the Jabra BT135 is switched off
3. To put the Jabra BT135 in pairing mode, press and hold the multifunction
button until the LED stops flashing and turns solid blue
4. Set your mobile phone to "discover" the Jabra BT135 (see your phone
user guide)
5. Press Yes or OK when asked if you want to pair the phone with the
Jabra BT135
6. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK
7. Your phone will confirm when pairing is complete and your headset
will flash
Jun 17, 2011 | Jabra BT135 Bluetooth Headset
I need help getting my jabra Bt185 working on my playstation 3
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Dec 27, 2009 | Jabra Bt185 Bluetooth Headset
How to disconnect bluetooth headset from a lost phone
I bought a Jabra Bluetooth headset, It worked fine with my phone(nokia). I lost my phone now. Now i want to use the same headset with my new phone (huawi), but i am unable to connect it to my new phone as the phone is already paired with my previous phone. So please help me with the issue and tell me is there any way i can disconnect the bluetooth headset from my previous phone??
Jun 04, 2009 | Jabra BT125 Headset
Need PIN code to re-connect Jabra BT350 Bluetooth Headset w/phone
I had the same problem-- i asked a verizon wireless guy and he said it's almost always four or six zero's so "0000" or "000000". Hope it works for you!
Jan 23, 2009 | Jabra BT350 Bluetooth Headset Headset
Setting up Jabra VBT2050 Bluetooth
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Dec 26, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 stopped connecting
BR, I had the same problem with my BT350 and my Razr V3c. I was finally able to resolve the problem by doing the following:
- delete BT350 from device list on Razr
- start Razr looking for device
- put BT350 in pairing mode while phone searching (hold answer button till solid blue light)
- phone will detect BT350 and retrieve name
- select Jabra BT350
- say 'yes' to bond with Jabra BT350
- enter passkey - 0000
- phone will connect with Jabra BT350
May 14, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra BT2010 Bluetooth Headset help
Hey guys, hold the button pressed for 6 sec. until led is solid. then search bluetooth devices on phone click on Bluetooth headset insert '0000' press OK now it should work, or check http://jabra.com for compatibility. Best wishes, htmlfreak.
Jan 03, 2008 | Radio Communications
Jabra BT 350 has stopped connecting
Hey everyone! I had the same problem, and I actually got it to work again! I hope these directions will help you get yours to work (from the manual):
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on. <== THIS IS VERY IMPORTANT! HOLD THE BUTTON UNTIL YOU SEE A SOLID NON-BLINKING LIGHT! (This is where I was going wrong with the directions.)
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
Nov 30, 2007 | Jabra BT350 Bluetooth Headset Headset
Connection prob
Brand New Jabra -BT350 won't work on my Nokia 6102i, I did everything in term of setting my phone properly to paired with the Bluetooth, My Phone Bluetooth light is on, and the device blue light is flashing as well, but it still doesn't work. the phone would ring, I hit the JABRA button to answer it.....still can't answer my phone... Please send your help to me at jjkernaud@hotmail.com
thank you all.
Nov 08, 2007 | Jabra BT350 Bluetooth Headset Headset
Pairing with a phone
this happened to me too.. i googled a user manual for it.. if i recall it said, turn the headset power off, then once the phone is in pairing mode, hold the power button on the headset till the light stops blinking and becomes a solid blue light. then the headset is in pairing mode as well and your phone should find it
Mar 20, 2007 | Jabra BT250 Consumer Headset
Motorola Mobility C168 Cellular Phone Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Vernon Taylor
Timllfixit
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
