Question about Samsung SGH-E370 Cellular Phone
How do I dismantle this phone?
I have a new set of covers for this phone but cannot dismantle without damage
    Brigadier General:
  • 7,752 Answers
It is best to take the mobile to a professional mobile center and have them put the new cover on for you.
Posted on Jun 14, 2008
1989 mitsubishi lancer ,TIMING BELT BROKE HOW TO CHECK WITHOUT DISMANTLING
as it is an interference engine it is a sure bet that the valves will be bent. If you have already fitted a new belt then do a compression test
Jul 04, 2013 | Cars & Trucks
Water pump bolt broke off
Common problem. You are in for a rough ride my friend. The only way to fix that is to remove the rest of the bolts, the front crankshaft dampener pulley and take the timing chain cover off. Usually the bolt is seized into the timing cover itself and the timing cover ends up getting destroyed in the process. Once the cover is out of the way, the bolt will most likely come out fairly easilly with a pair of Vise-Grips.
Fortunately, a replacement timing chain cover is not real expensive. The trick is to get the [BLANKETY] thing off without causing any damage to the engine block. If you are going that far, I recommend putting a new timing chain set on it while you are in there.
Recommended parts: Timing cover gasket and front seal set, timing chain and gear set, and possibly a new timing cover unless you can get it off without ANY damage.
Keep in mind that if you have to pry it off and the pry tool leaves indentations in the gasket surface, or if you "warp" the cover, the timing cover MUST be replaced unless you want to do the job over to fix oil and engine coolant leaks. (It doesn't take much to make the thing leak)
Aug 16, 2011 | 1991 Ford F150
Hopw to fit new belt
DC07s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, if your brush bar isn't turning then you have a faulty clutch. New clutches are available on eBay reasonably cheaply, but again good tools and DIY skills are required.
Have a look atwww.dysonmedic.com which has some excellent info on dismantling and repairing a DC 07.
Oct 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
When I put my memory card in my phone,and when I try to go to the camera it says''please insert memory card''.I know its not the memory card because I just bought a new one.It must be the phone.how do I...
To repair the memory card slot of your phone, you have to dismantle the phone first and get to the memory card slot or reader that is in the phone, then you replace it with a new one.
It is quite a fragile process therefore i will strongly advice you take proper caution in dismantling the phone.
First, turn off the phone, remove the battery cover, sim, and battery of the phone, get the appropriate screwdriver and unscrew the phone, carefully, remove the parts, then you will see the memory card slot, try to get the replacement parts down before starting the process.
After getting the memory card slot replaced, reverse the process of dismantling for reassembling the phone.
Good luck and take care
Oct 08, 2010 | Samsung Instinct Cell Phone
How to dismantle nokia 6720 cover
hi....
I am attaching the images so that you can easly understand
2bbad5d.jpg20f7d60.jpg please Reverse the procedure for putting the new cover
thanx
Jul 14, 2010 | Nokia 6720 Classic Cell Phone
How do you dismantle the Yamaha RAV-249 remote without damaging the unit. Removing the set screw under the battery cover does not seem to help.
Once you remove the screw from the battery compartment you will need to find a long flat iten to pry the remote open, such as a knife, metal ruler or the like. There is no way to do this without marking the sde of the remote. Simply place the pry between the two halves of the remote and gently pry. You will hear a snapping sound as their are 4 internal catches on either side. Tease it apart in more than one place along the edge. and it will eventually pop apart.
If you have the slow button problem a small circle of tin foil/aluminium paper glued to the back of the rubber pad will have your remote working good as new.
Mar 04, 2010 | Audio Players & Recorders
How to dismantle the housing of my P910i without damaging it?
On your flip top key pad, you can remove first the middle cover, it is clip type so no need to un scew, but just be very carefull.
after removing it, you'll see to set of screw, remove it so that you can take out the flip key pad,
turn your unit back, near the camera , there are two small cover there , remove it and you will see two screw, take it out
open the battery cover, remove the battery and sim card and the memory card, inside you will see, again two set of screw, take it out,
now all the screw has been removed
on the side oy your unit where you ca find the scroll, try to plip out the cover usig a twizzer or any pointd object, just flip the cover easily until you where able to remove the topcover completely
now just support the LCD, be very carefull so that may never damaged the flex of your screen
at the back of the screen, there are again another set of screw, remove it slowly, make sure that you supported the screen properly
then you can remove the lcd after taking out the stainless cover protection
removing the board is very simple, just lift the board a little higher enough for you to see the back of the board, there is another flex wire attached to the board and the scroll switch, remove it carefully.
then thats it, you had dismantle your unit
Nov 01, 2009 | Sony Ericsson P910i Cellular Phone
I dropped my phone in tea, the phone still works but you cannot see anything on the display screen. Is there something I can do to fix it. Sony Ericsson Walkman W350a.
Short answer: No. Long answer: Your phone has water damage. Warranty is void if your phone has water damage. Since you KNOW you've dropped it in tea, you should consider it a lost cause and move on. For others - if you do something similar (dropped in water): Immediately turn it off. Take the battery out, then proceed to completely dismantle the whole phone. I have in the past used kleenex paper to tuck into places I can't dismantle, to get the water out, but they usually say to dismantle it, then let it completely air dry. It may take a week. If it, after it's completely dry, still works, then maybe you got lucky, and maybe it'll start acting up in a while, problem by problem as the electronics corrode inside the phone. I have heard of phones surviving water damage with only minor problems, but it's rare.
Jun 10, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Liquid Damage to a Palm Centro need help
dismantle your phone and clean everything inside..
May 12, 2009 | Cell Phones
How to replace the nokia N70 keypad. I was advised to also purchase the T6 Torx screwdriver (which I have, and I was wondering the best way to tackle this without damaging the phone. Thank you
you don't need a screw or t6 just to replace your keypad, you only need your bear hands
here's a link
http://www.youtube.com/watch?v=2BkaYtsi3J4
showing how to dismantle your n70 phone
Aug 19, 2008 | Cell Phones
Samsung SGH-E370 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
