Question about Socket Communications Mach Speed - P4MDPT Motherboard
P4MDPT Mother Board
I have a P4MDPT Mother board with 3 caps popped. Do you know what the full spec is on the caps? Only information I have gathered is 1000µf 10V Radial Mount etc. I need the Dimensions and Tolerance values and ERS value if able.
  • Anonymous Aug 19, 2008
    driver
  • itek Nov 07, 2008
    I lost my driver CD.
    My motherboard P4MDPT.
    I can't setup my graphic.
    Can you help me download its?
  • 84 Answers
You can check it on the manual of your motherboard.
Posted on Jun 12, 2008
Sound Driver for Windows XP Pro SP 3
First thing, we need information about the sound card.
If you really are looking for the Sound Driver, then try going to the manufacturer's website of the device.
NOTE: if its onboard, or embedded on the mother board, then go to the manufacturer's website for the mother board. It also helps if you know the serial number or model number of the mother board.
May 12, 2011 | Computers & Internet
Machine is not booting
  • I know what is your problem?May be problem on your HDD you change it then solve your problem.If you are not fix,You need Fox con MX PK g31 chip mother board.It is very adjustable motherboard for pin less p4 HT processor.
Mar 19, 2010 | Intel D946GZIS Motherboard
I have p4mdpt mother board but grounded, what is the common cause?
common cause is that your house wiring is wrong some home owners connected the house wire's wrong so when you plug something in that is wired wrong you get this and the board should be earth grounded if you have a home depot or lowes goto the electrical department ask someone that you need to test you outlet to make sure that the wiring is correct at the outlet they will give you a outlet tester which has three lights check outlet and have corrected as needed
Dec 16, 2009 | Socket Communications Mach Speed - P4MDPT...
WILL WINDOWS VISTA 32 BIT WORK ON A P4MDPT MOTHERBOARD 100[? WHERE CAN I FIND DRIVERS FOR THIS BOARD?
comon dude.dont joke.even in the new computers it wont work properly.! try windows 7.but it depends on RAM also.
Oct 08, 2009 | Socket Communications Mach Speed - P4MDPT...
Machine display Full memory messege. Idone what
On this fax machine if you tried everything and still no luck, you might want to try to reset the main board.
This will reset the main board to factory settings.
When you do this, you may need to enter all your information back in again, speed dials, date, time, ect....
On this type of problem, sometimes this works, sometimes the problem maybe more indepth such as, replacing the main board on the machine. I am talking about the large mother board.
Hold down these buttons at the same time... Menu, 1, 3 and * button.
While holding these buttons, use the left hand to power on the machine, while holding these buttons for about 15 seconds...
When you let go of them, the machine should come back on to a normal screen.
There can be other changes in the memorywhen you reset the main board information.
If the machine does not come back on to a normal messege screen, you may need to replace the mother board.
Good luck.
Sep 03, 2009 | Xerox WorkCentre Pro 765 Laser Printer
Help for gateway motherboard power connections, ibm, manual
The mother board will have numbers on the up side. There you should be able to see the mother board manufacturer, model, and version.
Just because the information is on the case does not mean it is the right one, if som,e one changed it.
Apr 17, 2009 | Intel Motherboard
Socket Communications Mach Speed - P4MDPT Motherboard Logo
768 people viewed this question
Top Socket Communications Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Socket Communications Computer and Internet Expert? Answer questions, earn points and help others
