Question about Comfort-Aire EKTC12-150J Air Conditioner
Central air conditioner
Keeps running and wont shut off .
  • nana7 Jun 06, 2008
    air condtioner runs and dont shut off. central air
Causes can be a bad thermostat or the wire insulation came off. take off the thermostat carefully do notes on a note book to put back the wires and then use a ohm meter and check the read and the yellow for continury and if it have continury the wire is the problem if not is the thermostat
Posted on Aug 05, 2008
Ruud heat pump wont kick off
If you have your thermostst in the off position and the outdoor unit is still running, your condensor contactor has welded shut.
Oct 30, 2010 | Ruud Central System Air Conditioner
I have a central air unit that the line has frozen. How do i fix this?
Shut it down and keep the fan on so it will thaw out...then check the filter and have someone check the freon charge...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 21, 2010 | Weather King 12AJA4801AH Air Conditioner
Air conditioner blower fan wont turn off
If this is central AC unit check the fan motor to see if it will try to run. If the motor tries to run it may be capacitor easy to change. If not posible fan relay. Please keep in touch and I will help you with this problem. Rus Need more info please.
Nov 11, 2009 | Heating & Cooling
Condenser shuts down after a couple of hours.
check capacitors, make sure the condensor coil is clean. sounds like the compressor is overheating. is the condensor fan motor still turning when it stops cooling. if not check low voltage wires to condensor, furnace and t-stat
Aug 19, 2009 | Amana Haier AP125HD Air Conditioner
I have a GE central air conditioner model
If you are talking about the indoor fan it is probably a bad capacitor. Replace the fan motor capacitor. And YES, if the fan motor needs replacing too, you can DO-IT-YOURSELF.
Jul 05, 2009 | General Electric Heating & Cooling
Central heat and air system won't shut off
sounds like tstat is wired wrong or possibly the contactor relay has fused shut outside. if you can stop the system from running at the tsat it is usually a problem with the t-stat
if you cannot shut off the outside unit without turning off the power at a breaker than usually the contact relay needs replacement
Nov 22, 2008 | Ruud UBHC Air Conditioner
Central air
Most thermostats have a setting for the fan called, "manual". That keeps the fan on continuously. The electronic thermostats can fail in a "fan on" condition. That would require a new thermostat. I also saw one air conditioner with a fan relay welded "on" by electrical surge. That would require a new relay.
Jul 20, 2008 | LG LWHD1800R Wall/Window Air Conditioner
Air conditioner won't shut off when temperature reached
suspect a stuck contactor on condenser unit or cooling relay stuck
Jun 14, 2008 | Kenmore 72055 Air Conditioner
Heating & Cooling Logo
109 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Cesar Quant
Cesar Quant
Ottoniel
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
