Question about Marantz Audio Players & Recorders
Can't find replacement bulbs
I need to replace a couple bulbs in a Model 170DC Marantz Amplifier and I can't find them anywhere. Any suggestions where I should be looking for these?
    Sergeant:
    Champion:
  • 319 Answers
Unit probably uses fuse type lamps, either 8 or 12 volt filament. Remove one of the lamps and look for voltage rating on end cap. You can order these lamps from Allied Electronics or MCM Electronics online
Posted on Jun 08, 2008
Rs800 marantz schematic
Marantz Manuals - HiFi Engine
www.hifiengine.com/manual_library/marantz.shtml
Manual Library. Marantz. Marantz was founded in New York by Saul Marantz in 1952 and for a period in the 1980's was a subsidary of Philips. The company ...Missing: rs800
Marantz - Vintages HiFi
www.vintageshifi.com/repertoire-pdf/Marantz.php
Marantz ' Hifi Manuals Free: Service Manuals, Owners Manuals, Schematics, Diagrams, Datasheets, Brochures online for free download and free to your ...Missing: rs800
[PDF]Marantz 1060 Service Manual
akdatabase.org/AKview/.../Marantz/Marantz%201060%20Service.pdf
Amplifier Output Load Box Simplified Schematic ............................ 4. 3. Remove ... service information for Marantz Model 1060 Stereo Console Amplifier. Servicing ...Missing: rs800
Jan 10, 2016 | Marantz Audio Players & Recorders
Marantz amplifier PM68 replace fuse
You don't see any glass fuses? There is also a non replaceable fuse in the power transformer.
Apr 06, 2014 | Marantz PM-68 Amplifier
No dispay only if very dark
It's VERY possible that the Tuner has a "backlit" display ( Like many of the 1980-90's Yamahas)...You'll need to replace a couple of small bulbs inside
Jan 19, 2014 | Marantz ST6000 2 Channels Tuner
No display to see
It's VERY possible that the Tuner has a "backlit" display ( Like many of the 1980-90's Yamahas)...You'll need to replace a couple of small bulbs inside.
Standby light is flashing on my marantz sr7001
hi,
First of all remove all the speaker connections from the amplifier. After that power the amplifier and check the Standby blinking (protect) show or not . if not, then any of the speaker is damaged also check the wire for any short circuit . If then also its goes to protection then it have some hardware truouble inside.
Amplifiers gose protect mode , when there is a hardware fault in side it. Its a warning that some thing is wrong.
Normally amplifiers show this when any of the output amplifier have some problem. there 6 amplifiers in this receiver . May occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
You have to check the amplifier.
For that you need digital multimeter,soledring iron screwdrivers etc
Open the amplifier , then power it on. Connect the negative terminal of the multimeter any where in the chase( metal body of the amplifer). Then connect the positive terminal to all the output transistors emitter pin one by one . The voltage should be bellow 0.5V. If any of the emitter of the transistor shows voltage more than +/- 0.5V., then that amplifier stage is faulty. Remove the transistors and check it. if it is shot then replace with a new one.
After replacing the transistors do not power up the amplifier directly from the main. You have to put a bulb of 60 watts in serial.
You can do this easily remove the mains fuse. Put the bulb in a holder. Now you have two wire from the holder. connect one of it to the one end of the fuse holder and the other wire to the other end of the fuse holder. Why using a bulb is, if there is any further problem in the amplifier stage on which the transistors replaced, there is a possibility of the new transistor get damage. if we use a bulb in serial with its mains supply ,when any overload in the amplifier occur the bulb will drop the current, by lighting itself.
After connecting the bulb in serious power on the amplifier. watch the bulb. It should light for one or two second and go dim ,then remove the power , remove the bulb insert fuse and connect the power and check.
(If the bulb shows bright light then there is some component also faulty in the same amplifier. after removing the power you have to check again the amplifier stage of which the transistor is replaced, for any other faulty components
OK
Aug 20, 2011 | Marantz SR7001
Our receiver automatically shuts down, showing 'protect' in the display, when volume is turned up to -30 db. How can we stop/reset this? We really appreciate your answer.
hi,
First of all remove all the speaker connections from the amplifier. After that power the amplifier and check the protect show or not . if not, then any of the speaker is damaged. If its goes to protection mode when you incrase the volume then check the impedance of your speakers it should be 4ohms or above . Test with some other speakers if available.
Normally amplifiers show this when any of the output amplifier have some problem. there are two amplifiers stage left and right . May occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
(If the bulb shows bright light then there is some component also faulty in the same amplifier. after removing the power you have to check again the amplifier stage of which the transistor is replaced, for any other faulty components.
ok
Jun 13, 2011 | Marantz SR4021
Marantz model PM 400 yes its about 30years old. Problem volume does not respond to knob changes. Very cracklie sound. Do I need to replace the amplifier or is their a service agent on the sunshine coast...
It can be fixed by yourself. All you need is some tuner lubricant (available at Radioshack or similar store, or if nowhere can be found you can even try WD40). Pull the knob off so you can see the shaft. Spray the tuner lube onto the shaft (let gravity be your assistant). Replace knob and work it back and forth until it moves more easily than before. Test it and you should be golden.
Aug 05, 2008 | Marantz Audio Players & Recorders
101 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
