CD/DVD players use a protocol;
Open tray. Insert disk. Tray switch tells mechacon that the tray is shut. Attempt to focus on disk.
If focus is acheived, then it will spin up and try to read the disk otherwise it will ask for a readable disk.
If the tray keeps opening, I would suspect the tray detect switch is malfunctioning, maybe the drive belt has stretched.
This is likely the same issue occurring when the disk tray will not open either. Suspect your drive belt is worn and requires servicing. This is best done by an xbox servicing agent. Not too expensive. I have been suffering with a tray that will not open for over 2 years now, however, I am able to fix it simply by ensuring a disk is always left in the tray. It only fails to open if there is no disk in the tray. Even then, I can open it by lifting slightly with a paperclip.
The sensor inside the cd writer does not recognize the closing of the tray. Hence it keeps opening all the time. To stop it from opening hold the tray pressed when it closes for some time. The tray may stop opening. Sometimes it works. Else you have to repair or replace the CD writer.
turn on xbox open tray, turn off xbox with tray open, turn it on making sure u dont close the tray until it is totally on then close it, then restart your xbox
Try tapping above the disk drive or if that doesn't work open the tray take your disc out close the tray. open the tray put ur disk back in and close the tray again.
