the sync speed for the sb-600 is onlt 1/200 on most cameras i think so if your shutter is faster then that then all you will see is black/ the curtans behind the shutter.
basicly just try again with a slower shutter speed
Check that the terminals on the flash and the camera foot are clean Use a pencil eraser to clean thyem by using a gentle rubbing motion. reconnect and test.
Auto zoom only works when on the hot shoe of the camera. You also need to make sure that its in the righht mode (make sure that above the word Zoom on the display it doesn't have a "m").
Oh and of course you have to have a CLS (Creative LIghting System) compatible camera.
Yes. The SB-600 instructions don't mention the D60 because the SB-600 came out before the D60 existed. Bear in mind that the D60 does not have a commander mode so you can't use the SB-600 as a slave.
Basically, as far as the SB-600 instructions are concerned, just pretend that you have a D40.
This flash was made in the 1990's for use on nikon film cameras. It wont work in TTL mode on current nikon models, and it has no infrared remote capability like the sb600/800 speedlights, but it can still be fired in manual mode by even the newest nikon cameras. I wouldnt throw it away, but I probably wouldnt use it that much either.
Nikon hot shoe is rated up to 250V (canon's is rated up to 6V) so you can use almost any tipe of flash, except maybe for old studio flashes. Vivitar 283 (older versions) is ~200V rated, and much lower on newer versions. It should work.
You have to order parts from the Nikon authorized service rep for your area. Call Nikon tech support for information. In some areas, Nikon will sell direct.
