Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Unit's dvd door will not open - Panasonic DMR-EZ47V DVD Recorder/VCR
Had the same problem. I believe the drive is damaged, luckily I had another dvd recorder with the same drive and swapped it out. Now it works.
VXY1961 DVD DRIVE UNIT 355.58
Posted on Jun 06, 2008
DVD DOOR WILL NOT OPEN.
Someone needs to open the unit to see if a jam or something is blocking this--could be easy but you have to SEE what is wrong first.
Nov 06, 2012 | Televison & Video
DVD door will not open
Some one is going to have to open the unit up and see what is happening, something jammed or out of position etc.
DVD door won't open
you should get the DVD door cleaned either profesionally or just do it yourself
Feb 19, 2012 | Panasonic DMR-ES40V DVD-Video Recorder
The machine will not open the DVD Drive. When I push the eject button the display indicates "OPEN" but nothing happens. Is there a way to open the drive manually?
No,if u forced it,will damges the little motor that help it to open the dirve door.Unplug the unit,hold the unit in ur hand tight over head shake it a few times,this will help,what caught inside that stop the drive door from opening.Wait like about an hour later to replug it back in the unit,will be resetting itself back to the factory setting,will help help the unit too.
Dec 11, 2010 | Samsung DVD-V4600 DVD Player/VCR
DVD unit door does not open
Check you owners manual for the emergency door release function and use it to open the door. usually thisis a small pin heole to release the mechanism, it could also be a slot under the unit. If this does not work , then take off the top cover of you unit and check the dvd carriage for possible dirt and obstructions, that are preventing the dvd drawer from working properly.ou can have a broken belt or some other out of alignment problems. While the unit is open you should clean out the dust and debris with a small brush and compressed air cleaning the unit . This will help in the unit over all operation. Hope this helps you with your problem.
May 16, 2009 | Philips DVD625 DVD Player
Drawer won't open on my sanyo vhs dvd
check the front of your dvd has it got a small hole located on the facia just below the draw if so unplug your unit and insert an unfolded paper clip in to this hole as straight as you can you will meet some springy resistance that is the door locking mechanism push gently and the door will open .. once it has leave the door open and power up the unit the door should close and reset ... oh and make sure your kids ( if you have any ) havent dropped any M&Ms or stuff into the draw common problem Kids love em ?.
Regards Vortash
May 12, 2009 | Sanyo Televison & Video
I have a Toshiba SD2019U DVD player and the door won't open. When I turn it on, it makes a rumbling sound and displays "opening", then continues to rumble then changes to "closing" and...
i think there's a broken or loose gear.or someone put something small that stop the door from openning.
you can try to open the unit up and turn the power on
and check what hinders the door from openning.
May 08, 2009 | Televison & Video
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Aug 25, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD stuck in DVR5000
Some CD/DVD units have a manual opening mechanism, it looks like a small hole on the front of the unit, try using a needle or a metal rod that fits by inserting it into the hole and pushing it should open the unit in case it got stuck somehow. If afterwards it continues to work then all's good else you'll have to bring it to a workshop.
Nov 19, 2005 | Rio DVR5000 DVD Player
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
91 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
