Question about Acer AL1716 17" LCD Monitor
Input not supported?
Hi when I plugged in my new display theres a sign moving back and forth that says : input not supported? I dont understand what the problem is pleeeease help me im going crazy
/Natalie
  • Anonymous Feb 20, 2009
    when i plug monitor in to my system it tells me "input not supported" it will work on another system just not this one!!! But on the monitor it tells me that it works with windows vista....I have windows xp on this one
I reinstalled XP (had to nuke the old one with Linux as the original XP CD won't overwrite a later version) so I knew the system worked, cable was good. I got a default video setup and the "input not supported" message if I tried to change to a higher resolution. Got the motherboard software (Asus P4S533-MX) and ran it. There is no separate video card and the video comes from the motherboard. Seems to work.
Posted on Sep 08, 2008
    Scholar:
  • 56 Answers
Chances are your Winders resolution is not supported. Start Winders in "Safe Mode" and reduce the resolution on the monitor.
You can do this by right clicking the desktop, selecting properties, Settings tab. Adjust the slider to a lower resolution. Also, be aware that flat panel LCD monitors to not use refresh rates the same way the old CRT monitors did. Look in the manual that came with your monitor and find the "Native Resolution" for it. This will tell you the optimal settings for resolution and refresh rate. If the rate is set improperly, you'll get a very fuzzy output. If it is too far out of whack, you'll get nothing but an error message like you are getting now.
Posted on Jun 06, 2008
Powers up but get no signal sign
Use the input button or menu button to change the input to cable.
Nov 30, 2013 | Albatron Televison & Video
Yukon XL driver side seat not working
There is a seat module under the seat that reads the inputs from the switches and then sends power to the motors, disconnect and reconnect and it may reset. If not you will have to check inputs at module.There is more than one connector on it, you will have to disconnect the power supply.
Mar 19, 2013 | 2005 GMC Yukon XL
We moved our freezer that is a little over a year old for about a mile. It was laid on it's back during the move. When it was plugged back in it doesn't cool and the display on the door flashes an...
Here is a tip that I wrote on moving refrigerators...if you did not do it thisway then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is thebest way
If you already have moved it wrong, you can sometimes get it working byplugging it in and unplugging it a number of times with an hour or so inbetween.
heatman101
Jul 23, 2011 | Frigidaire Freezers
The screen changes when i move it back and forth
thats the display is giving you sign for repacement
very soon the display might go blank so you have to change the screen ok
Mar 01, 2010 | Advent Netbook
Paper jam..cartridge back and forth
hi
This clearly indicates that problem is with the rollers in the paper feed tray..to clear the obstruction-fold a sheet of paper 3-4 times lenghtwise to make it thick..insert this into the paper feed tray,behind the rollers-move it left right a couple of times....repeat this a couple of times-if no go...call tech support..printer would be replaced if in warranty...good luck
Jan 24, 2009 | Office Equipment & Supplies
2001 malibu shifts rough
code p0113 means: IAT sensor high temp
and the solution:
The Intake air temp sensor is located inside the air flow meter and uses yellow and black wire and the black wire. IAT sensor circuit code P0113 indicating excessively high voltage or (Open Circuit) the ECM is either not seeing the correct voltages at terminals 66 and 80 under the dash at the ecm. It could be as simple as a broken wire under the insulation right at the air flow meter, Or a little worse a bad air flow meter. There are cheeper remanufactured Aair flow meters available at Nissan for your car around $150 instead of $400 like they used to be new.
Jun 26, 2008 | 2001 Chevrolet Malibu
Hooking up computer to philips 60pp935217 AV5 HDTV connector?
Hi Roger,
Initially, pls try lowering the screen resolution of your PC. This can be done at the Display Properties/Settings tab and then move the slider of the Screen resolution towards the left, Apply OK. In some instances, you need to also lower down the Screen refresh rates in the Monitor tab of the Advanced Properties.
If your concern has not been corrected after completion of the above procedures, then other methods can be considered.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 15, 2008 | Philips 60PP9202 60" Rear Projection...
Moved my al1716 to my computer in the bedroom. Nothin' !
What this monitor is trying to tell you is that your resolution is set to a higher degree than this monitor can support. Turn your computer off, restart then go to safe mode by tapping the F8 key or by holding down the left shift key while it is booting. Once in safe mode set your display resolution in desktop display properties dialog box to some thing easy like 800x600 16 bit color and reboot your pc. This should get you back to normal operating system where from there you can then try to find the highest support resolution for this monitor.
Feb 04, 2008 | Acer AL1716 17" LCD Monitor
VGA Input
If it says no support then it can't read the computer. There is no way around this unless you have a RGB (this is a computer input port) input port on the TV
Jul 10, 2017 | Polaroid FLM-2625 26 in. HD-Ready LCD...
Reciever display changing by itself
Sounds like a bad microcontroller. First check on the function selector knob if there is one and make sure it is not stuck - move or rotate it back and forth. Also, if the remote is nearby, try removing the batteries from it.
May 21, 2007 | Pioneer VSX-D511 Receiver
Acer AL1716 17" LCD Monitor Logo
239 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
