Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Amana Refrigeration stopped running
My amana SQD22NBW side by side refrigerator stopped working (fan/compressor. The lights continued to work. I read somewhere that it could be a defrost timmer. I also read to unplug it over night and try it in the morning when it is defrosted. (it never had any frost inside) I emptied it and left it open overnight When I came back to it it fired up (fans and compressor) (Oh my wife turned the thermostat cooler two days ago right before it stopped working) The refigerator is in the garage where it is around 90-100 degrees.
Do I need to replace anything? Will it stop again? If I need to what parts do I need to replace and are they hard to replace.
Thanks in advance!
Brent
  • 828 Answers
If the compressor is at room temperature and no noise coming from it your problem could be the thermostat control. If the compressor is hot and you hear a hum followed by a click the compressor may have failed. Check the condenser and make sure it is clean. In those operating temperatures the compressor is overworking in the first place and if it is not getting free air flow across the condenser it can burn out. Best condition for operating any refrigerator is to remember that if you feel hot it feels hot. They are designed to operate in an place where we live and at the temperatures we live in.
Posted on Jun 08, 2008
Amana refrigerator SQD23VW
If the freezer is not freezing. I am guessing that the refrigerator is not cold also. Here is link to an Amana Refrigerator Not Freezing. You will need to narrow down parts that are working and are not working. I would first pull the refrigerator out to make sure that the compressor and the condenser fan are running(the condencer fan motor runs to cool the compressor down). This is a link to a GE refrigerator condenser fan motor problem. The compressor and condenser fan motor are in the same place. This can give an idea at least where it is at. Make sure that the evaporator fan motor in the freezer is running also. Make sure that the rear freezer wall is not iced over. This can be a defrost problem. See what a defrost problem is HERE. If your unit is sitting there with the lights on but you hear no noise from any fan motor or your compressor. Your unit may be in a defrost mode. Locate your defrost timer. It looks as tho it is either located in the front behind the kick plate or in the back by the compressor. Here is a link to your units diagrams http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VW-P1315302WW/1268/0165000/P9060266/00011?componentDescription=&brandDescription=&searchTerm= or http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VWP1315302WW/1268/0165000?searchedModel=sqd23vw&blt=11 . Hope this helps a little. This is my Appliance repair Contact. You can get a hold of me at http://www.apcoapplianceandair.com/contact.php anytime.
Apr 09, 2013 | Amana Refrigerators
Amana Model SQD22NBW Refrigeration stopped running MFG P1162412WW
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
If it is just that the unit is not cooling properly, it could be a problem with the compressor. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
It could also be that it is simply too hot in your garage for the fridge to work properly. If that is the case, your compressor may be under strain and could have burnt out.
If your unit is under warranty, best thing to do would be to contact the manufacturer/point of purchase. (Warranty is usually 5 years).
There is no quick fix for this, and you will need to have some experience in refrigerator repairs. It seems most likely that the issue is a burnt out compressor. But whether it is the wiring or the compressor itself, will be hard to tell without testing for continuity, etc.
If you feel that you have correctly diagnosed the issue, and wish to try a DIY, I suggest you purchase a service manula first. Here is a good one:
http://www.appliancepartsworldwide.com/Store_Part.aspx?Id=501956
You can then purchase the required parts from here:
http://www.appliancepartsworldwide.com/Store_SearchResults.aspx?S=647313&ST=PBM
Hope that helps! If you find my solution helpful, kindly take a moment to "Accept" my solution. Thanks.
Jun 12, 2008 | Refrigerators
Amana ABB222DE is the overload/capacitor the same thing as the compressor relay? I just had the compressor relay replaced in amana bottom mount. Frig cools fine but every 2 days or so buzzing noise...
I have been doing refrigeration for over 30 years and I have never seen a compressor with a chip inside of it. Have you tried cleaning the condensor coils? I almost sounds like you have a weak start capacitor. Let me know if i can help you any futher.
Apr 24, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Freezer not freezing nor ice maker
Is the refrigerator still working? Is there any cold air in the freezer? If your compressor stopped working it would cause the refrigerator to be warm also. I had a problem with my amana refrigerator where the freezer wasn't getting cold enough and it was due to a condenser fan running intermittently. i replaced the fan and was back in business. i would check to make sure both your fan and your compressor are operating...
Mar 03, 2010 | Amana ABB1927DE Bottom Freezer...
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana/Maytag ACD2234HRS sometime not working
If your compressor is running with the noise you described, I would make sure the parts that were replace on compressor are working properly. Also use a amp meter and get a reading on amp draw while it is humming. Anything that is above normal readings for the compressor would indicate compressor is bad or the relay and starter are not working properly. I need a series number also like a number 15 before the model number, Thanks, Sea Breeze
Mar 21, 2009 | Maytag MZD2766GES Side by Side...
Light is on, fan runs, compressor will not come on, compressor has never made a noise. Amana Distinctions model ARS2665A S/N 0010242568..side by side refrigerator freezer with ice maker.
Below bottom grate is a defrost timer. Turn slowly clockwise until you hear compressor start. If this works, replace defrost timer.
Let me know, Thanks, Sea Breeze
Mar 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
My refrigerator
is the compressor running?. check the compressor at the back side of the refrigerator.
Feb 21, 2008 | Amana ABB1927DE Bottom Freezer...
How to troubleshoot amana refridgerator
the evap fan, fan by compressor and the compressor should all be running. if they are then more than likely a bad compressor, so junk it
Oct 30, 2007 | Amana 22.6 cu. ft. Side-By-Side...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
119 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
