Smart report hard drive failure iminent
I have an HP pavilion m9150f . Recently recieved and a warning message on the desktop "Smart systems report. A hard drive may fail"
System is operating normaly at this time, but continue to get the warning. Since this is only about two months old I do not expect any hard drive problems.
What information can you supply?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey 72cobrajet,
If you are receiving this kind of error message, it can often be an indicator that a self-diagnostic tool has determined that your computer may be suffering from a hardware failure.
Whenever your computer starts up, it performs a self-test to ensure that everything is working properly. If your computer detects anything out of the ordinary, it generally prompts you with an error message indicating what the problem may be.
While your computer may seem to function normally at this time, I would strongly suggest backing up any necessary information as soon as possible to avoid any potential loss.
In some instances, you may be able to determine the exact reason why you are receiving an error message by using a software tool developed by either Microsoft or the hard drive manufacturer itself. Please keep in mind however, that you may receive more detailed and product-specific support when using a manufacturer-developed diagnostic utility over Microsoft's CHKDSK.
If you are unsure how to use any these programs and are still under the manufacturer's warranty, you may wish to contact HP directly for further assistance. Additionally, if you would prefer to not work directly with HP, you may always bring your computer into your local Best Buy™ store for warranty service and support.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 09, 2008
I received the following error on my HP Pavilion laptop: SMART Failure Predicted on Hard Disk 4: WDC WD2500BEVS-60UST0-(S1) Warning: Immediately back-up your data and replace your hard disk drive. A...
SMART is used to measure your HDD health.It warns you of impending failure of your hard drive. If it goes down, it's a good idea to backup important stuff and prepare to replace the HDD.
S.M.A.R.T is an acronym for Self-Monitoring, Analysis and Reporting Technology systems (SMART) and it's usually built in to most modern ATA and SCSI hard disks.
If you need further assistance, feel free to ask. If this answers or solves your issue, please rate it. Thanks, Joe
Feb 09, 2011 | HP Computers & Internet
Smart test failed on the drive
A smart failure warning is an internal hard disk drive self-diagnostic that will help predict a failure of the hard disk drive. Any system that is displaying a SMART error should immediately have any important data backed up as the drive is not reliable and is impending failure if it hasn't failed already.
Resolution is hard disk drive replacement, Generally around $100 depending on size and speed of replacement HDD
Jan 25, 2011 | HP Pavilion Slimline s3700y Desktop,...
Hard Disk Problem
That failure is predicted by the SMART reporting system. Its a status chip on the drive that reports to apps that can read the smart data from the hard drive. Its not always accurate but it usually is.
Time backup your data on that drive ASAP and then buy a new drive.
Sep 07, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
On black white screen it says Hard Drive failure is imminent. Back up or replace
Your computer is set to warn you of controller failure to the hard drive. Its called SMART monitoring. You will have to replace the drive. Start backing up your precious data to a reliable drive before the unthinkable happens. Right now it will continue running normally, but it WILL fail. Portable hard drives are extremely cheap right now. Its recommended you purchase a portable drive that is at least twice the size of your current hard drive. Next, get a hard drive that is the same type of drive you have in your system (have a service tech help you with this if youre not comfortable doing this).
Mar 18, 2009 | HP Hewlett Packard Pavilion a6130n PC...
ACER SMART failure
SMART means self monitoring and reporting tool, this is the option which performs certain test for the status of hard disk health, if its coming it means condition of your hard disk is not good, its better if you immediately back up your data and replace it, by the way you can also disable this warning through the bios, just disable the smart feature in hard disk
Nov 10, 2008 | Acer Aspire 3680 Laptop
Turn on, after intital screen with setup options the following appears: "SMART Failure Predicted on Hard Disk 4: SAMSUNG HM121HI - (S1) WARNING: Immediately back-up our date ....... Afailure may be...
Have you installed or attached any Software /Device since then.
Please unlug any device attached and then try. Also try tapping F8 key during bootup.
Check BIOS with F2, DEL or ESC key during Bootup.
Best of Luck & Regards Puneet
Oct 05, 2008 | HP Computers & Internet
When you turn the computer on it says SMART Failer predicted on hard disk 0: HTS54108G9SA00-(S1)
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) is a diagnostic method originally developed by IBM that at that time referred to as "Predictive Failure Analysis". This technology was developed for IBM mainframe drives to give advanced warning of drive failures. Based on this diagnostic, Compaq announced IntelliSafeTM, which was submitted to the ATA/IDE standards committees and the resulting standard was named S.M.A.R.T.
S.M.A.R.T. analyzes many of the mechanical attributes; over time, some failures can be predicted by detecting if the hard disk drive is moving out of tolerance. While the S.M.A.R.T. technology can detect upcoming issues, not all hard drive failures are predictable.
All this means on most modern drives is the hard drive is coming close to the maximum tolerances
I usually switch off in the bios smart monitoring.
This system is trying to predict a possible failure, which may or may not occur..
Mar 30, 2008 | Computers & Internet
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
