Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Heavy Frost in Freezer
The freezer section has heavy, heavy frost (like frosty the snowman kind) and there is accumulation of ice on the right side of the freezer. This just started after 2 years of use. What is causing this?
  • 2 more comments
  • SCGirl40 Jun 17, 2008
    I took everything out of the freezer section to look for the cause and as I did this my daughter saw a frozen food package in back of the drawer. The package was preventing the door from closing completely, although it looked and sounded closed. We removed the package, cleaned the freezer of frost and it is working perfectly. We did have an air leak and thankfully it was just an obstruction and not a mechanical problem.
  • ramtough1949 Aug 25, 2008
    ice in freezer where the evoperator is like snow
  • Anonymous Nov 09, 2008
    same problem here, any fixes?
  • Anonymous Dec 06, 2008
    The freeezer drawer on my LG French Door style fridge does not seal on the left side. The hinge keeps coming loose from the door itself, which is what is causing the frost. When you pull on the door handle to open the freezer it angles out at the top, then it pulls open. I think this is why the hinge comes off. How do I fix this? I have put the hinge back on once, but it came off again within a week or so. The door did not originally tilt out like it does now. How do I stop this?
  • 489 Answers
You have an air leak coming from the light switch in the ceiling of the freezer.  You will need to call LG for resolution on this problem.  I believe there is a fix for this problem.
Posted on Jun 08, 2008
  • dear_TRAGEDY Nov 04, 2011
    Wtf?? Is that what yer gunna tell them??? Wow awesome help!! Well the problem is right there. The RIGHT SIDE of freezer door is not closing all the way? Check for food blocking any area of door or on floor of freezer...p.s. u don't need a service call. LG's are notorious for gears to come off track..give it a nice pull and it will realign itself....or have the Guy wit the last comment chrage u for 10min of his time
Freezer cools well, refirgator is warm, the vent that brings air from frezer to refrigator has no air movement, ice inside , i broke some ice with knife shoul di spray hot water to get rid rest , I did...
This answer will be somewhat long, but in order to understand the "fix" for your problem you need to understand how a refrigerator-freezer works.
Most units have ONE COMPRESSOR which usually cools the FREEZER. Then, to cool the fridge area, there is a DUCT or ducts between the freezer and the fridge area to move some small amount of very cold freezer air into the fridge section. In the old days this occurred by convection, but most newer units have a small fan in the duct to more dependably move the air.
The run time of the compressor, and thus the temperature of the freezer is usually controlled by a THERMOSTAT [usually with numbers on the dial]. A second control [usually with the letters A, B, C, and sometimes even D] operates either a DAMPER in the duct, or controls the duration of fan operation in order to control the temperature in the fridge section.
Under certain conditions of higher humidity, FROST [fine ice crystals] can build up in the duct, and on the fan if there is one, reducing or totally blocking the cold air flow from the freezer to the fridge section.
From your description of the freezer working well, but the fridge section being "warm" suggests that blockage of the duct is what has happened. However, there are a couple of other possibilities:
1. You inadvertantly moved the fridge control to a warmer setting,
2. You inadvertantly placed something in the freezer and/or fridge which BLOCKED the entrance or exit of the duct,
IF one of the above are the cause, a "manual" defrost of a few hours with the freezer and fridge doors open to allow warmer air in should melt out any frost/ice from the duct and allow the system to work properly. Depending on the severity of the frost/ice buildup, it could take a couple of days to fully melt all the frost/ice.
During the manual defrost ALL frozen and perishable foods should be temporary stored in an ice chest or cooler of some kind.
One more thing, in addition to heavy humidity, frost/ice buildup can also be caused by a defective automatic DEFROST TIMER. IF the system does not do its regular defrost cycle [usually an hour or two once in each 24 hours], then frost/ice buildup can occur even with "normal" humidities.
So, once you have the system back in operation, watch for the normal cycling of the defrost program, and if the problem continues, contact a qualified refrigeration repair technician to repair or replace the defrost TIMER.
Jul 13, 2011 | Refrigerators
Heavy frost accumulates just inside freezer door (and on adjacent foods) -- next to refrigerator door
Check your freezer door seal especially where the frost is the heaviest. Also check and make sure that you ice shoot for the thru the door ice is closing.
Jun 24, 2011 | Frigidaire 22.6 Cu. Ft. Side-by-Side...
Defrost not working heavy ice build up around coils
Hi
Frost is a natural occurrence on the evaporator coils in the freezer compartment of your refrigerator. To prevent frost buildup, a self-defrosting refrigerator warms the coils using a defrost heater several times each day to melt away the frost. This frost melts into water and flows out of the compartment through the drain. If any part of the defrost system is not working properly, the result can be heavy frost buildup that may affect the cooling capacity of the refrigerator.
The defrost timer is a mechanism that tells the defroster how long to run to melt the frost. The limit switch measures the temperature in the freezer and helps to maintain it, while the heater is the key element that melts the frost. Any one of these components could need replacement at a given time, which will result in this over-frosting.
Also check this bellow link:-
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 01, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
Heavy Frost in the freezer
There are a few reasons for frost building up inside the freezer compartment. Refrigerators work like dehumidifiers collecting the moisture in the air inside and defrost is supposed to remove the moisture while defrost through a drain and then to the defrost condensate pan below the refrigerator. Ever notice how ice in freezer over time the ice cubes become smaller? Or food that is not sealed dries out. You either have one of three problems. Defrost drain blocked behind the rear wall in back of freezer, air leaking into freezer through the door seal and in your case the drawer seal and finally water possibly leaking into freezer from Ice Maker, Let me know, Thanks Sea Breeze
Jun 19, 2010 | Samsung RF265AA Bottom Freezer French Door...
Runs constantly, freezer isn't cold enough, bottom of fridge is freezing
Do you have a heavy frost build up on the back wall of the freezer section toward the bottom. If you do your defrost heater has gone bad and will need to be changed. If you do not have frost build up the other problem would be with the evaporator fan or the main board. Let's hope for heavy frost build up.
Mar 09, 2010 | Hotpoint HSS25GFP Side by Side...
Fridge part of my side by side registers above 40, spoils milk; freezer section which is frost free gets frosty buildup in in; ice maker quit working also. freeze food still?
Look into the back of the freezer to see if frost is building up on the rear panel. If yes that is a sign of the defrost system failed. I will need your model number. When most refrigerators begin the problem it is a sign that defrost is not happening. Ice makers stop working above 5 degrees. Send me your model number and I will help you get this solved or pointed in the right direction, Sea Breeze
Feb 13, 2010 | Refrigerators
Refrigerator was making a 'Thump'' noise every so often and just stopped working. Freezer is still working It's a kenmore elite 3 door bottom freezer refrigerator model number 76539
Unplugging for an hour won't allow it to defrost if that is what the problem is.
Look inside the freezer at the back wall. Look for heavy accumulations of ice building on the cooling coil, which is behind the back wall panel. You may have to look in the louvers or past where the evap fan is located.
Once we know if there is heavy frost or ice there, we'll have a better idea how to resolve. Is there any warranty on this refrigerator that you know of, besides the 5 year compressor warranty?
Dec 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Evaporator freezing up on my ge gss25tsrd refridgerator
YOU CAN SEE HEAVY FROST ON THE REAR OF FREEZER WALL?
Jan 29, 2009 | GE Refrigerators
Frost accumulation on ice maker
Normally the frost is taken away during defrost so if things get worse we need to look at the defrost timer.If freeze temps.begin to rise let me know, Thanks JT
Oct 24, 2007 | Frigidaire FRS26KF5C Side by Side...
Ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Aug 10, 2007 | Whirlpool ET1FHTXM Top Freezer...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
287 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
