All of a sudden, there is no power and the machine won't turn on. Bag is not full. Is there an internal fuse that needs replacing or maybe the switch went bad?
I don't have the exact same model as you guys, but maybe my situation is similar to yours. My Miele Silver moon model won't turn on one day. I took it to a Miele authorized repair shop ( they all offer free estimate on finding the problem first, then they will tell you what the repair cost will be). They said my vacuum cord reel shim was damaged. The damage was caused by over stretching the cord while I vacuumed. According to them the shim is kind of like a clip that holds the cord inside the vacuum. When the shim is damaged, the cords are pulled apart and electricity can no longer pass through. That would expalin why it won't turn on. The repair cost was not too bad, it costed forty-six dollars. I hope this helps.
Hi If the power head isn't working it may be clogged. Try taking it apart to see if threads and general dirt has got in at the sides. Also without the power head if the Miele still isn't working then its a possibility that the on switch wiring is either loose or check the plug at the end of the power cord.
I have the identical problem I think, I've wracked my brain all day trying to figure out what's up. Did you ever find out?
I have exactly the same problem.
Worked fine one day and the next day it won't even turn on. I think it must be a fuse or a breaker of some sort but can't find an obvious location.
Set up vac I bought on ebay (this model)
switch doesn't turn on
