Question about Nakamichi SoundSpace 21 System
Dvd player does not work
It always hang, even though i do cleaning using the cd cleaner. nobody want to fix it even i ask authorized dealer to fix it,cause the store owner is new. please help
This problem is mostly cased by an defect of the Laser-pickup and need to be replaced.
Is not a easy work on this typ of unit -put possible.
Posted on Oct 24, 2008
I put a dvd in and it says it is loading and then it says no disc found even though it is in the dvd player. I have tried several different dvd's.
Unfortunately , Some DVD players cant read some DVD s and
then it gives either "loading" or " no disc"..reading on the display...
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc itself has problem, laptop does not read either..
Since you h
ave not stated,if it is an old player pls Clean your DVD player's LASER lens anyway .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD - This cleaner contains six soft brushes that gently remove dust, dirt and other airborne contaminants from your DVD player's lens. (Price: $6.09)
Maxell DVD-LC DVD Lens Cleaner - This DVD Lens cleaner features the "Thunderon Brush System" and include tests for audio performance including Dolby 5.1 surround sound. It also features an interactive on-screen instructions in 8 languages including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner - This DVD Lens Cleaner features an 8 brush carbon-system with carbon edge that removes static build-up from your DVD Players. It prevents skipping and also improves the sound and picture output of your DVD Player. ($13.11)
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 26, 2011 | Proscan 32LB30QD 32 in. LCD TV
Hi, I have a Samsung DVD-VR300E dvd/vcr combo. The DVD player won't read any DVDs anymore, whether bought or recorded. What I don't understand is that it does still read the DVD cleaner disk! It won't read...
The laser in the DVD drive may be shot (?), even though it seems to read the DVD cleaner disc. I attended a maintenance class on cleaning CD and DVD writer drives for PCs and was told not to use the disc cleaners with brushes as they can knock the laser out of alignment. It's best to use a can of pressurized air to clean a drive when it's open. Just make sure not to allow any of the propellant to get inside!
Aug 03, 2010 | Samsung DVD-VR300 DVD Recorder/VCR
Won't reconize disk in player
Well here is your resolution for your problem.
As you saying that when you insert any CD or DVD in Player its shows NO DISK.
Well Sometime what happen is if a CD contains are not compatible with Player than it wont work with it.
Or if you had burn that CD or DVD from your personal computer or laptop but it is not burn in proper format than also it wont work in PLAYER.
Well even if CD or DVD is having any scratches on it or it is Used uncounted enumerable times than also sometimes this things happen and it wont work in PLAYER.
Well before Inserting any CD or DVD in Player Just check the above mentioned points.
If everything is ok with the CD or DVD but than also its shows the same problem than get the CD or DVD cleaner liquid spray or even you can use Spirit to clean the CD or DVD and than Insert it.
After doing all this but if its shows no result in it than go to the company dealer and ask him to change the head of the player and you wont face this problem afterward for sure.
if you still have nay quarries regarding the same or any other you may reply me.
Naiven
May 23, 2010 | RCA DRC233N DVD Player
My Oppo DVD player suddenly froze in mid-play, and then when I tried to reboot it, it just hangs, saying "loading." Then after a long while, it says "no disk"-- even though there is indeed a DVD in it. And...
clean the lens with a dvd/cd lens cleaner (walmart, radio shack, etc.). or if you're feeling adventurous, remove the top, remove the dvd shuttle cover, and clean the lens with a q-tip dipped in rubbing alcohol. wip it off gently ad blow it dry with your mouth (as opposed to a hair dryer). the alcohol will evaporate. put it together and try it out. if it still doesn't read, you may need to replace the optical pickup (lens and motor).
Jan 06, 2010 | Oppo Digital DV-970HD DVD Player
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Mar 04, 2009 | Sony Televison & Video
Disk error
That means that the lens are dirty, and the unit cannot read any disk.
Try first cleaning the lens using a lens cleaner kit (the ones with liquid cleaninc solution), like the one here :
Allsop Ultra Pro Lens Cleaner for CD, DVD and Game Consoles
Ifthat does not work, then you will need to access the lens inside theunit by opening the cover and accessing the lens pickup, and gently clean lens by using isopropylalcohol and ultra soft soft cotton sticks.
Here is how the lens look like:
Nov 07, 2008 | Sanyo DVW-6100 DVD Player/VCR
How Can I Fix My Laptop DVD/CD Player? It's Not Working Right Anymore
Provide a CD/DVD cleaner disc and clean it maybe it help;
I encoutered that problem 3 months ago, the DVD ROM recognized only few DVD disc, other DVD's won't even the windows is freshly installed. The laptop was return back to the store they replace it.
However, in your case; it work fine before so maybe i suggest you to clean your DVD rom using the cleaner, if not work then , scan your computer with a potent antivirus, if this not work also, maybe i recommend to format and reinstall the system,
If all of those are not working maybe its time for you to enjoy the warranty of your laptop if the laptop has a warranty. hope this help.
Jan 22, 2008 | Acer TravelMate 223X Notebook
Nakamichi SoundSpace 21 System Logo
85 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
ELECTRICLAW
Level 1 Expert
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
