Question about Panasonic TH-50PV30 50 in. Plasma Television
Panasonic TH-50PV30 I have a Panasonic TH-50PV30 and it has a intermittent problem as it keeps turning off. Can someone help me to fix the problem I purchased this product on 10th December 2004 and it has always been connected to a PURGE AV Power Board and I have tried connecting the TV direct to the wall outlet and it still turns off after 5 minutes.
  • 3 more comments
  • Anonymous Jun 19, 2008
    I recently purchased a Panasonic Viera TH-50PZ77U and I'm having the exact same problem.
  • jackspratt52 Oct 16, 2008
    same problem,should we sue????? so frusrating to say the least!!! my machine has been back to panasonic and back,same problem.what can 1 do? it switches off after a few minutes or it can survive the whole night!
  • aa130453 Nov 15, 2008
    My Panasonic TH50PZ80 switches itself off with a faint blue screen. Sometimes it works through the night.... Intermittent.
    Under warranty repair is due next Friday. I will report progress.
  • Lamborghini Dec 31, 2008
    Sorry to everybody that assisted me with my problem but you all were wrong. I fixed the problem by vaccum the rear of the TV as there was a lot of dust. I no longer have the problem with my Panasonic turning off all the time also it was out of warranty.
    Thanks to all.
  • aa130453 May 11, 2010
    My problem reported on 15th November is to do with the tv set switching input to HDMI1 when the HDMI1 input (SKYbox) is switched off! Panasonic repair technician blames SKY box, I know SKY has no autoswitch facility, there appears to be no cure.... switching HDMI connection to HDMI2 helped but now I have a DVD player there, so when the unwanted switch occurs, I manually switch it back to where I want to watch!
Make sure the power supply cable is tightly plug-in, the one in the back of the TV. This fixed my problem.
Posted on Dec 30, 2008
How do you remove the stand from a panasonic TH-50PV30 50 inch type with 3 levvels of storage shelving. Thanks.
Never owned the this TV, but from what I can tell the outside edges on either side should have a series of screw holes. Even if you can't see the actual screws, there are philips head and there are in the bottom of those 4 or 6 holes. Take those out to get the TV off the stand.
Those may also be covers for a less complex connect to the spot where the additional speakers normal mount. Either way, remove still starts there.
Apr 27, 2011 | Panasonic TH-50PV30 50 in. Plasma...
How to convert from pal bg to pal I in panasonic th50pv30
Specifications for the Panasonic TH50PV30 Plasma. Broadcast Standards, PAL-I.DVB, AV-NTSC:PAL 50/60Hz, NTSC, M-NTSC. Picture size, 42" (106cm) Discontinued Model.
Should work, have a look in the intallation menu for the correct country that you want.
Hope this helps.
Mar 09, 2011 | Panasonic TH-50PV30 50 in. Plasma...
Television keeps turning off then there are 5 flashes of the red LED light followed by 1 flash then this repeats itself continiously
5 Blinks on this set means loss of SOS 5V on the P-board AKA power supply board. Replacing it should resolve the problem.
Jan 05, 2011 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic TH-42PX60U Turns On/Off by itself
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 30, 2017 | Panasonic TH-50PV30 50 in. Plasma...
Hi....my 61 inch nec plasma is turning itself off
Set is going into "PROTECT". Unplug as you'll cause more damage. Get Pro repair ASAP. Around $450.00
Please rate!
Apr 01, 2009 | Panasonic TH-50PV30 50 in. Plasma...
Intermittent turning itself off
check your setup menu and make sure that turn off timer is off
here is instruction below on your tv
hope it works
panasonic.com.au/content/library/files/F000518.pdf
Oct 27, 2008 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic TH-50PV30
You can check the board where the components are mounted and resolder any that look bad. a brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. all can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced.
Dec 21, 2005 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic Viera 42" TH-42PV30
Check the 2 main interconnection cables (24pin and 26pin) rear of PDP and Tuner box. Make sure they are firmly connected. (Loose connection of 24pin will cause no power on symptom.)
Oct 21, 2005 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic TH-50PV30 50 in. Plasma Television Logo
314 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
