Question about Garmin iQue 3600 GPS Receiver
No serial number for Ique
I bought an Ique 3600 off ebay and it has no serial number under the antenna - you need this number to get a new unlock code in mapsource or ro register it with Garmin.
  • 4 more comments
  • slacsteve Jun 12, 2008
    Good luck I also bought one and the serial is visible but when I go to register it it says that number is already registered. I am waiting for an email response from Garmin on how to fix. They don't support IQ by phone anymore.
  • Anonymous Sep 06, 2008
    I have the same problem, please let me know if hear somthing.
    Thanks
    dutchstar2@hotmail.com
  • Anonymous Sep 29, 2008
    I have the same problem!
  • andminha Oct 19, 2008
    Yes, i have same problem with same ebay seller..
  • mike1355 Oct 28, 2008
    Yes, Garmin will send you an activation code from the internal serial number as long as you can send proof of purchase and they can validate that. HOWEVER they no longer give out 2 activation codes for each map as they used to . I bought a used 3600 off of ebay as a backup but I can only validate older maps with it:(
  • avaculik May 21, 2009
    Good idea that unit numer but where ca i find that one?
Garmin can activate the unit from either the serial number or the unit ID. Doesn't sound like a big problem, just call them to do it that way. I did that on mine that I got off of eBay a year and a half ago without a sticker.
Posted on Oct 25, 2008
Yeah, same problem here, from the same ebay seller.
Posted on Oct 17, 2008
I have the same problem, I bought one off ebay from
No serial number for Ique - s.gifjohnthefisherman_123
If he does fix this for us make sure you post a negative, the way ebay list sellers now is based on rating.
My old garmin 3600 Ique has some problems. I
the software for running the maps is not compatible is the cause.
Nov 04, 2009 | Garmin iQue 3600 GPS Receiver
1 iQue 3600 no Installation Disks or anything else.
You can download for free the installation disk software from www.garmin.com. You can also download a base map, but may have to buy maps from Garmin for more detailed maps/charts. You may need the serial number of the unit to unlock the maps, this is on a paper sticker under the gps antenna.
Mar 06, 2009 | Garmin iQue 3600 GPS Receiver
Ique 3600 antenna reception problem
How long does it try to find the satellites? If it trys for a half hour of more with no results, the antenna may be broken. I have read in other forms that people have added an external antenna and their units would then work, evfen with the built in antenna broken.
Feb 25, 2009 | Garmin iQue 3600 GPS Receiver
Unlocking IQue 3600 maps
Even with the maps unlocked it they can appear to be locked.
There are little known flags to diable/enable the base/detailed maps.
Check that the boxes are checked under the <Map><Options><Misc>
You can select either base or detailed maps there.
Disable both and it looks like the unit doesn't have any maps.
Aug 21, 2008 | Garmin iQue 3600 GPS Receiver
Internal antenna works but can 't get external to work
Sounds like ext antennae is sick. Mine works 100% just by plugging into 3600
Aug 10, 2008 | Garmin iQue 3600 GPS Receiver
Ique 3600 does not work why?
Well unfortunately, sounds like it's replacement time.... same problem I had with mine. Even with an external antenna...no or little signal. Garmin charges $200 canadian for an exchange unit.
So much for costumer support.
Good luck.
Apr 28, 2008 | Garmin iQue 3600 GPS Receiver
Fritzed Unit when antenna up
I have a similar problem but I can't turn the GPS off at all, even when the antenna is down. As far as the power on/off cycle, I found another link on this site that said to turn off WAAS while the GPS is off then when you turn it on the unit will not power cycle continuously. You loose the WAAS feature but the GPS and unit still works.
Jan 24, 2008 | Garmin iQue 3600 GPS Receiver
Map Unlock Code
Garmin normally replace your unit with a refurbished unit. Yes call Garmin and ask for a new unlock code. Normally they provide a new registration ID (yellow piece of paper with the unlock code for the latest mapsource map and accessories which it also included with the refurbished unit.
Jan 05, 2008 | Garmin iQue 3600 GPS Receiver
GARMIN ique 3600 - need spare part
eBay or other online sites like that, search for sold 'as is' for parts.
However you can't have mine... it works just fine. ;>D
Sep 11, 2007 | Garmin iQue 3600 GPS Receiver
GPS receiver problem
Does it work with an external antenna hooked up? If it does, it could be a problem with the flip-up internal antenna.
Mar 12, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
410 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
