Question about GE Spacemaker WSLP1100D Top Load Washer
GE Spacemaker Washer WWP2000S: washer will not drain
Wash cycle performs normally but washer will not drain. Drain pump simply does not activate at the appropriate place in the cycle. I've tried cycling the control knob through all the available cycles / wash modes but cannot get the pump to activate. Agitator filter is clean; drain hoses are normal and clear. Seems like I've got a bad pump or is there some kind of float switch that must be activated in order for the drain pump to work? Also, if it's the pump can I get to it easily and replace it myself?
  • Anonymous Dec 28, 2008
    My spacemaker will wash but wont drain. If I take the hose from the machine the water will pump out of the machine while using a bucket to catch the water. The hose seems to be cloged. How do I uncloge it. My hose is attaced to the facet for input of water.
    thanks
    pickle
4 Suggested Answers
catriver
  • 878 Answers
SOURCE: washer make a clicking noise
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. Catriver..post back.
Posted on Dec 01, 2006
JULIANFIX
  • 975 Answers
SOURCE: GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Posted on Apr 16, 2008
MNTECH
  • 1543 Answers
SOURCE: timer switch on GE washer
You don't state your exact model number, and the number off the timer is not the actual part number (it's some sort of part stamping number). Most likely what has happened is a plastic tab on the timer housing (which normally goes into a slot in the metal, and thus holds the timer at that point) has broken off. The fix is to replace the timer, but instead of buying a new timer, I usually fashion a Z type piece of metal which I can put one screw though into the metal and the other side holding the timer against the metal. Takes a little work, but it's a lot cheaper than a new timer.
If you want to take the timer knob off, you have to pull it out and use a thin tool, like a small screwdriver, to push the plastic clip off the shaft behind the knob, allowing the knob to then come off the shaft. Push the clip back on the knob when off, so that all you have to do to reinstall the knob is push it on and it will lock on the shaft again.
Posted on Dec 08, 2008
  • 17 Answers
SOURCE: REPLACING THE AGITATOR
unscrew the plastic nut down the centre and then pull the agitator up and off
Posted on Jul 20, 2009
GE spacemaker Washer Dryer Combo don't drain properly?
Check the drain hose for obstructions. Is it being pinched where it goes over the top of the drain pipe behind the washer?
The pump may be going bad...
Jul 29, 2014 | GE WSM2700W Unitized Spacemaker Washer and...
Washer won't agitate in wash cycle
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Jan 19, 2013 | GE Profile WPRE6100G Top Load Washer
My GE SpaceSaver Washer/dryer will wash, but when it's time to rinse and spin the machine stops. It will not drain, riinse , or spin.
Jul 27, 2012 | GE Spacemaker Washer and Dryer Electric...
My spacemaker will not drain or function in spin cycle
Hello & Welcome to FixYa
When the unit is unable to drain it will not even work in spin cycle, the problem is with blocked drain/drain pump filter which should be cleaned. If after cleaning the problem comes back then the drain pump needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 03, 2011 | GE Spacemaker Washer and Dryer Electric...
GE WCSR2080B4WW - After wash cycle the washer does not spin and..
your washer must drain to spin.you may have a blocked or failed pump.you get to it thru the frount.use a putty knife between the lid and the frount ,push the springs.top comes up take frount off.pump has two hose .pumps white or tan smaller.God bless,tom
Jan 01, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Spacemaker spin cycle problem
you may have something stuck in the drain pump......
first try using a wet/dry vacuum attach it to the drain hose and try to **** out what ever you have stuck in there... if that works you are good... if not you will have to get open the cabinet to get to the drain pump
Dec 23, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Washer will not drain
I just repaired one that had a needle stuck in the pump. Take the front cover off and the pump is in the lower left corner. Remove hoses and pull pump out then dis assemble pump and clean out.
If that does not do it you have to replace the pump.
Jul 23, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
GE WASHER WON'T GO THROUGH THE DRAIN CYCLE AFTER WASH CYCLE
ck wiring to motor be sure all conections are tight lid switch is ok since will agitate also ck control bd for connections most likely suspect all ck ok is control bd itself
May 20, 2008 | GE WBB4500EWW Top Load Washer
Washer won't drain
The switch located to the top which is activated by the lid is bad. replace that and your washer will be fine.
Feb 19, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Washer does not drain water
Make sure the drain hose is not kinked
Dec 27, 2007 | GE Spacemaker WSLP1100D Top Load Washer
GE Spacemaker WSLP1100D Top Load Washer Logo
83 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
