Question about Toshiba Tecra A4 Notebook
Modem doesn't recognize dial tone
I have a Toshiba tecra a4-s313 with modem v.2.1.51.0. I does not recognize the dial tone. I am using another computer.
  • Anonymous Dec 09, 2008
    drivers
  • 300 Answers
If you are on another computer and everything is fine. I would say that the modem has been damaged by some type of power surge, especially if there has been recent storms. If this is the case, the modem would need to be replaced. Since that modem is internal It may be difficult for you to replace.
According to the manual at http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_outFrm.jsp?moid=1132652&rpn=PTA42U&ct=DS&soid=1170276&BV_SessionID=@@@@0589613970.1216923303@@@@&BV_EngineID=cccfadeejkmemelcgfkceghdgngdgnn.0 you dont have PCMCIA option.
You can locate a Toshiba Repair Center at http://www.csd.toshiba.com/cgi-bin/tais/su/su_gaspLocator.jsp?subs=tais&BV_SessionID=@@@@0589613970.1216923303@@@@&BV_EngineID=cccfadeejkmemelcgfkceghdgngdgnn.0 and see what options they give you.
Thanks
Posted on Jul 24, 2008
Hi, I'm looking for the WiFi driver for my Toshiba Tecra A4 - PTA42U where can I find it?
I dont know which driver you need you have two computers listed. 313 an pta42
Sep 04, 2013 | Toshiba Tecra A4-S313 Notebook
Hard drive burnt out
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 12, 2012 | Toshiba Tecra A4-S313 Notebook
Dial tone of my phone disappears whenever i switch on my computer and my d link dial up modem can't find dial tone. What should i do?
Disconnect the telephone-cable from the computer's modem.
Does your telephone regain the dial-tone?
If so, then replace the computer's modem -- it is going "off-hook" as soon as you turn on the computer, not just when you try to use the modem to open a dial-up session.
Sep 27, 2010 | D-Link DFM 562IS (DFM-562IS) Modem
I have a Toshiba Satellite A305-s6916,modem is not connecting
Get a external modem and try that, But first try and connect network.Start- Control panel , delete current Network and make new one. If its Vista it will repair itself. just follow the bouncing prompt
Jul 30, 2009 | Toshiba Satellite X205-SLI1 Notebook
Partial lcd display on laptop
Hi
Sometimes the resolution changes to an unusual setting when an external monitor is attached. make the LCD screen your main monitor and change the resolution to 1024x768 or 600x800 whichever is best.
Happy to help
CBZ
Apr 25, 2009 | Toshiba Tecra A4-S313 Notebook
Lack of dial tone with modem on Toshiba Satellite Pro L20
just go to the modem properties and you will see a option there called wait for dail tone if u see tick mark there please remove the tick mark your problem might get solved. if this doenst work then check up ur cable and the modem
Feb 14, 2009 | Toshiba Computers & Internet
Modem stopped working
Well its sounds ike the modem may poked ut lets assume it is not perhaps yo have doube checked your conection is correct if it is TRY ANOTHER modem because they are known probems for your coonections especially dialup are you meaning this?
Jul 13, 2008 | Toshiba Satellite A135-S4527 Notebook
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
Toshiba Tecra A4 Notebook Logo
294 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
