Question about Hitachi 53UWX10B 53" Rear Projection Television
Blue circle across top of tv screen & maybe some yellow
All of a sudden we have a blue circleall the way across the screen.
  • 927 Answers
Good Day,
Does the blue spot have tin white lines?? Is there a picture behind the 'circle'? You may a blue crt (tube) problem.
Posted on Jun 16, 2008
Screen flashing ribbons of color over picture
i think its your cable box. check it carefully.
May 25, 2009 | Vizio VA26L 26 in. LCD HDTV
Blue and yellow shadows on tv
DID YOU CHANGE THE OIL? OBVIOUSLY MY RESPONSE IS A JOKE!!! DO YOU THINK THAT YOUR TROUBLE IS POSTED IN THE WRONG LOCATION.
Feb 28, 2009 | 1991 Ford Econoline
Toshiba Tube TV 32AF45 Picture Squeeze in middle
Try unplugging TV while it is on and let sit for 20 minutes. Re-connect and see...
It sounds like your horzontal control is bad. It requires a new circuit board.
Mastersage!
Feb 18, 2009 | Toshiba 43H70 43" Rear Projection...
Colors off. blue and yellow not lined up
try to set the convergance if you cant you can adjust the color tubes from inside the tv but have to be very careful to do this. There is actually only 3 colors in the tv red, blue green so I would say your blue and green need lined up
Sep 30, 2008 | Televison & Video
Intermittent blank screen with r,g and b semi-circles at top of screen
the blinking standby light should be a help. It should be blinking a repeating code. Can you post that here please?
Thanks,
Dan
Sep 09, 2008 | Sony KP-46V35 TV
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Problem with picture
check there are no magnets near the tv ie speakers etc,
May 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
'No Signal' on Sony XBR
on the tv remote: press menu, external entry is highlight (yellow) right press on the outer circle then scroll down to video 4 (satellite entry) (it could be on video 3 depending of the satellite assignment entry) when video 4 is highlight (yellow) right press on the outer circle on the screen you will see 1080i if settle on an HD channel hope it will fix your Sony Bravia..
May 30, 2007 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
232 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
