Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Tub still wet/ not drying
The dishwasher was purchased by the previous homeowner, so I don't know repair history. Upon inspection the racks looked dirty, but it was actually stains/mold. I used a bottle of Dishwasher Magic and ran the unit through a complete cycle. About 80% of the stains/mold are gone, the rest I will have to scrub by hand to remove. The problem is that the tub is still wet even after the dry cycle ran. Not just a little moist from steam, It's wet; water droplets all down sides, in detergent cups and in bottom. Any help is appreciated.
  • 868 Answers
YOU NEED RINSE AID ! ! Make sure your selection option is HEATED DRY.Please rate this !
Posted on Jun 07, 2008
ICON DISHWASHER
Check and make sure the Air Dry button is not engaged. Check the clean out at the bottom. When you push the top rack in insure it is hitting the opening in the back. Finally purchase some Lemi Shine Machine cleaner for the smell, it's likely you have a some stuff lurking in the screens causing the smell, this made my Icon dishwasher work like new.
Apr 07, 2014 | Electrolux Frigidaire Professional Series...
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Sep 07, 2011 | Westinghouse Dishwashers
Have dishwasher does not dry dishes fully top rack wet bottom rack semi dry heat ring on bottom is rough not smooth
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 31, 2010 | Frigidaire Dishwashers
How do I get the Electrolux dishwasher to dry the dishes?
Hello, I've got a suggestion and at first it may sound like I'm pulling it out of my...left field. I'll tell you the what and then I'll explain why. Try this, take a rag or paper towel and soak it with "rinse aid" AKA, "jet dry" and apply it to the top of the tub and to a lesser degree the sides as well. I suggest this to all my customer's with new dishwasher's. Now the why...all dishwasher's require assistance to dry your dishes, some more than other's. Hence the need for an additive such as jet dry, it is simply a wetting agent which help's the water run off the dishes and as a result they dry better. So why put it on the tub ? Glad you asked. The reason is exactly the same, on older dishwasher's that have had many year's of use the tub has already built up some wetting agent on the tub just by normal and continued use, the new obviously has not. The only jet dry the new one has is the added amount in the dispenser. Over a short time of regular use the unit would start to dry better on it's own, this just speed's up the process. By adding the jet dry to the tub you create a seathing action allowing water to run off before & during the dry cycle as to not have water in the form of condensation dripping back onto the dishes when the cycle is complete, which leaves you with dry dishes as opposed to wet dishes. Make sense ? I hope so, it really work's. Hope you found this helpful. If so please rate the info you received frome jere at "fixya" today and good luck. Let me know if I can assist you further. I hope you didn't find this too difficult to read, I had to use my iphone, it's the only internet connection I have at the moment. Macmarkus :)
Jan 07, 2010 | Electrolux EIDW6105GW 24 in. Built-in...
My new Kenmore Elite panel ready dishwasher leaves wet
You need only enough space so the door does not rub when opened. If the unit is too far back under the cabinet the countertop (if wood) can be damaged by the exhausting moisture. The dry feature on the newer models is just as you describe. The moisture from the hotter dishes evaporates and is condensed on the cooler walls and door of the wash tub. Dry dishes wet tub is normal.
Eric
Jan 04, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher is not completing the cycle, and water remains in the tub. I've cleaned the filter and that doesn't seem to solve the problem.
check you float switch at the back to see if it is sticking ,and it should always have at least an inch of water in it to keep the motor seal wet or it will dry up and leak creating another problem
Dec 25, 2009 | Dishwashers
How do you remove the upper dishwasher rack? It's
The upper rack is held by four side brackets. They are not removable unless you pull the dishwasher out from under the cabinet. Not very homeowner friendly.
Mar 08, 2009 | KitchenAid KUDM01TJBS Dishwasher
Kenmore Dishwasher model 16779
Age/ poor quality plastic/sharp objects making contact/these are all common examples,I know there is a liquid plastic that you can purchase that really works and is safe to use.You wipe on the damaged areas and let it dry .
Jan 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Rusty dish rack
Clearly a design or manufacturing flaw. I have the same model and the rack is disintegrating after 6 years. I believe it is a manufacturing flaw. Our previous dishwasher rack lasted over 20 years in the same conditions. Same construction, vinyl covered steel. New upper and lower racks cost over 200.00 and there is no guarantee that this won't happen every six years. I recommend a new non-Maytag dishwasher as soon as you can. Meanwhile, limp along with the defective racks.
Oct 02, 2007 | Maytag MDB7100AWB Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
170 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
