Question about Saeco Coffee Makers & Espresso Machines
I have a saeco expresson machine
The red light is on constantly anf now when i press the gree light for an expresso noithing happens!!was working fine 1 hour ago
  • 515 Answers
Try to take out the dregdrawer for 20sec and put in again.
You can also try to open the steam knob and make a cup of water.
Posted on Jul 11, 2008
The descaling light and water drop is constant flashing preventing machine from working, what to do?
Did you check if your hot water know was fully closed
Try turn off the machine, press the water drop button and turn on the machine . Keep pressing for 20 sec.
You may attached a recording video if problem not resolved
Good luck
Nov 12, 2014 | Saeco Odea Giro Plus Coffee Maker
How to get less water dispensed. My expresso dispenses 100ml. Too much for an expresso. Help.
On a lot of machines if you press and hold the button while it dispenses and release the button only when you have the desired amount it will retain that amount for the next button press of that particular button.
Jul 23, 2014 | Saeco Incanto Classic Fully Automatic...
Can I repair it myself?
Notice if you can hear the pump when you are opening for steam.If you dont hear it ther is a problem at the switch.If you hear it then the tube is just blocked with milk.
Apr 29, 2014 | Saeco Vienna SuperAutomatica Coffee...
Water light stays water dispensed, even
My Machine will grind-tamp but will not add water to push through.It will send water out tap on the side.
Apr 14, 2010 | Starbucks Saeco Italia Digital Barista...
Coffee grnder not working
Try to cantact Saeco Australia (, or Saeco Italy (
They should know where you can get spare parts.
Best regards
Jan 29, 2009 | Saeco Royal Digital Plus Coffee...
Inoperable expresso machine
Make sure the magnet in the water tank float up to the top.
Try to make a full cup of water (Tea).
Let me know if i can help you more
Best regards
Sep 08, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Easy Expresso Maker Instruction Manual
You have it on e-mail:-)
have a nice day
Aug 19, 2008 | Saeco Easy Espresso Machine
Saeco expresso machine
1743 Boundary Road
Vancouver, BC
(604) 299-7555
Dec 14, 2007 | Saeco Vienna De Luxe Espresso Machine
Open Questions:
Defect Saeco Odea Giro. Red exclamation flashing fast. Mashine is function only in service mode. A defect in Saeco Odea Giro. TYP 0310R ser. number. 9007SA40523803 Please help for repairing the machine. I bought the automatic coffee machine second hand. After unpacking, I discovered that someone was intruding into it cracked plastics and handles. By common check, I discovered the 1st fault - a broken piston catalog number 11003468. This is quite a common fault with these machines. 2nd defect leakage of the valve. Even one O ring was missing. I replaced all O-rings with new ones. Then I went over to check the individual sensors: Level sensor in the tank - OK Sensor closed coffee bean hopper - OK Sensor of closed door on the brewing unit side. - OK Sensor on the waste container - okay When I wanted to try switching on a microswitch that detects the presence of the brewing unit in the hole, I did not find contact. So I removed the wall behind the brewing unit and found that there were two microswitches near the toothed wheel. I checked their functionality. Both well. I assumed that one of them was not at his destination. The one with the green connector I supposed to indicate that the brewing unit is in place. I moved him to the top. I checked the state of the electric motor and lubricated the gear. I returned the wall back. Next, I ran the diagnostic mode and checked other components: a Boiler - Heats up b The pump - presses correctly and the green diode flashes during its operation and shows the activity of the flowmeter c solenoid valve - switches correctly d the grinder grinds and during its operation the green diode flashes and reveals the activity of the speed sensor in the mill e the brewing unit is moved to the top position and to the basic position without any problems Other things I've done: The whole coffee maker is cleaned, deep decontamination is performed using the diagnostic mode. Check the flow meter clean without oxidation. Check the tightness of all hoses. Both boiler thermostats are checked. Removed and thoroughly cleaned the mill. Despite this, the machine behaves as follows: Turn on the machine and fne the mill shaft. The red exclamation mark flashes very quickly. The green light of the boiler heating is not lit or flashing. However, the boiler is heating up properly. When I eject the tank water flow, the red exclamator lights up permanently. After the tank returns, the red exclamation mark will flash rapidly again and the green indicator the boiler is heated will light up properly. When switched on, the Indycatter does not light the cup. Only a drop of water drops and coffee beans lit up. Can not prepare coffee, can not refuel hot water. All this can only be done in diagnostic mode. In the diagnostic mode, I also de-aerated the machine. Both the nozzle and the coffee outlet through the brewing unit. Self-cleaning will not start. I do not know anymore, maybe there is a bug in the electronic panel. Will anyone advise me? Thank you.
Mar 09, 2018 | Saeco Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
121 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
