Question about Lexmark Wheelwriter 15 Series II Typewriter
IBM Selectric II
We have an old IBM Selectric II typewriter in the church library. When I hit the return button, instead of moving to the left and moving the paper up, it moves to the right. I tried to set the righthand margin, but it did not correct the problem.
  • r152 Jul 07, 2008
    Cannot find the spring that was referenced in the answer.
    New Friend:
  • 120 Answers
The return clutch torque limiter is off or broken. If you take the right dust cover off it is on the turning hub around the middle of the typewriter. a small spring about 1.25 inches long with a hook on the end. I have been fixing these for 35 years. good luck. Lawrence
Posted on Jun 09, 2008
My IBM Selectric II typewriter skips part of a letter when typing envelopes and going over the overlapped thickness. Even repeating the letter doesn't help.
That particular key is not hitting the paper flush as it should. Carefully try adjusting it in the direction of the miss.
Nov 08, 2015 | IBM Correcting Selectric II
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II keeps returning to right.
Check the pitch lever on the top L. of the cabinet it may be in between positions.
Sep 08, 2009 | IBM Office Equipment & Supplies
Return key only returns the carriage part way, press it again and it moves a little farther, help (IBM Selectric II)
These old selectrics are all getting very gummed up you probably need a good chemical cleaning.
Sep 02, 2009 | IBM Office Equipment & Supplies
I have a IBM Correcting Selectric II and I'm having trouble clearing out the margins. Can you help?
space to the right side of the machine, hold down the tab clear key and hit return.
If the carriage stops partway back, one of the tab stops has rotated too far on the tab bar.
remove the platen and paper pan, go to the stuck stop, rotate it to the rear of the machine to line up with the other tabs
Jul 16, 2009 | Nakajima AE-710 Typewriter
IBM Selectric II-return goes past the margin stop
The margin release mech. is probably gummy and allowing returns to go past the margin. If thi is a dual pitch machine see if the pitch selector lever will move easily. If not use some WD40 on the margin rack.
Mar 11, 2009 | Lexmark Wheelwriter 15 Series II...
Don't know how to load and string the ribbon on an ibm selectric
Selectric III has two different ribbons the selectric II ribbon tha the ribbon guides are part of the macine and the "bicycle" ribbon that has the guides bilt into the ribbon. to replace the "bicycle" ribbon move pull the red lever on the right toward you, drop the ribbon in turn the knob a few times in the direction of the arrows, move the red lever back done.
The other style move the lever, drop the ribbon in, be sure the ribbon is left of the slacker finger sticking up on the left,thread it tru the guides, turn the knob inthe direction of the arrows, move red lever back,done.
Feb 24, 2009 | IBM Wheelwriter 30 Typewriter
IBM Selectric II won't return completely
The machine is probably gummy. If you know how to remove the case do so, get some WD40 and spray everything that moves espesially the stuff on the outside of the rt. side frame.
Sep 28, 2008 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II
Sounds like you have a broken torquo limiter tension spring you should have it professionly serviced.
Jul 07, 2008 | Office Equipment & Supplies
IBM Selectric II
Yes. From not being used in so long It needs a chemical cleaning or washout and lubrication. It may need a part or two also. Everything is gummed up. I have been repairing selectrics for 35 years. Lawrence
Apr 20, 2008 | Lexmark Wheelwriter 15 Series II...
Lexmark Wheelwriter 15 Series II Typewriter Logo
240 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
