Question about Brother MFC-8220 Fax
Strong noise when i send print o recived a fax i get a strong noise like "track, track, track" and doesn't print the paper is inside and don go out
  • Jentil12000 Jun 11, 2008
    When the fax machine receives an incoming fax or prints out a transmittal, it makes a loud clicking noise. It is coming from the left side of the machine. I have already replaced the toner and drum, thinking that it might have been the problem. But it still makes the noise. I think that the piece that helps turn the drum is not connecting, and that is what the noise is. What is that piece called? And can I replace it myself, or do I need to call a company to come and replace it?
    Thanks,
    Jen
  • whiteheadmd Oct 02, 2008
    The machine makes a loud grinding noise like the drum cartridge is not connected all the way. I tried replacing the drum cartridge but this did not work.
  • 3 Answers
Sounds like the fuser gear is broken.
Posted on Jun 09, 2008
I have panasonic kx-pf711 fax machine it will send properly but it has a problem reciveing document 2pages
You are not making it clear as to what your problem is? Does it not print the second page? Is it paper jamming on the 2nd page? Is it giving an error code?
Please repost with more accurate info. Thanks
Jul 18, 2016 | Panasonic Office Equipment & Supplies
Hi Everybody, My 6322DN says "printing...", you
First ckeck the line of the telephone,put another printer and see if you recive the fax on other printer.If you not recive fax possible fax board may be faulty.
Mar 16, 2011 | Samsung SCX-6322DN All-In-One Laser...
The fax can not recive fax just sending it
Is your line fax enable? If not, definitely you cannot receive fax just sending only. Check you telephone provider.
Mar 09, 2011 | Lexmark F4270 Plain Paper Inkjet Fax
I have a Panafax 770 when sending fax it reduces the recived fax
Open up the document feeder and make sure of the switches is not trapped in the down position.
May 18, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
I have brother all in one 420cn. Can send fax but cant recive fax
There are no digital fax machines. You need an analog phone line for your machine to work reliably.
Feb 25, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Send and receive
Most likely has a problem with the fax PCB board inside it. Its not worth repair.
Jan 07, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
Printer error 054
That's because you need to take out cartridge and put it back! See is there any jamed paper inside!!! Error 054 is about cartridge!! Can't read that cartridge is inside the printer!!!
Feb 07, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
NOISE OR PAPER GETTING STUCK IN FAX MACHINE WHILE SENDING FAX
look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
This is area where the original document feeds through
Jan 22, 2008 | Brother IntelliFAX 2800 Laser Fax
Panasonic fax kx fp342 regarding
my fax do not send paper but it's reciver and copy it .
what solution ?
Dec 29, 2007 | Office Equipment & Supplies
Send or recived fax
1st of all do check that the telephone line cord is plugged into the correct jack in the machine. It needs to be in the jack marked "line." not the jack marked "Tel."
Further questions need to be addressed, such as :Is this a recently acquired machine? or Has the machine been disconnected from the power for any length of time? or Has the machine been moved to a different location?
Dec 21, 2007 | Canon LaserClass 9000L Plain Paper Fax
Brother MFC-8220 Fax Logo
273 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
