Question about SanDisk Sansa e250 MP3 Player
Refresh Database Hi Recently i encountered this Refresh Database problem, whenever i switch ON my player it shows Refresh Database, even it doesn't switch OFF. I need to remove my battery to switch off my player, i tried to connect to my system, but player was not displayed in my system, and it is showing Refresh Database even in that situation also. plz help me in this regard...
  • Anonymous Jun 27, 2008
    what do you do after you are done downloading music to your mp3 player and its says refresh database?
  • 8,596 Answers
Firmware upgrade needed most likely:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 11, 2008
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
REFRESH DATABASE
Remove the 4 back panel screws and take the battery out. Wait about 30 minutes than reinstall the battery. This should force it to reboot and load the program from ROM.
Jun 22, 2009 | SanDisk Sansa e200 MP3 Player
(Sansa 2.0 GB e250R) Player shows an empty database...
DO YOU GO TO YOUR COMPUTER ICON ON YOUR COMPUTER AND THEN PLUG IN YOUR SANDISK SANSA AND THEN DRAG YOUR SONGS TO IT BECAUSE THAT IS WHAT I DID AND IT WORKED
Apr 15, 2009 | SanDisk Sansa e260 MP3 Player
Recently i encountered this Refresh Database problem, whenever i switch ON my player it shows Refresh Database, even it doesn't switch OFF. I need to remove my battery to switch off my player, i tried to...
Try this: disconnect the player from the computer, turn it off, hold in the volume + (REC button for Sansa e200 series) button, and reconnect the player to the computer while holding the volume + (REC button for Sansa e200 series) button in. Keep holding the volume + (REC button for Sansa e200 series) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Dec 18, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
MP3 needs to refresh DataBase?
You have to many songs a sansa e 250 only holds a certain amount of space so your best bet is to buy a memory card or delete songs so you can add new ones.
sincerely,Britani
Apr 19, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database fail
Hi try this for me see if you can put your mp3 into recovery mode if it goes into recovery mode then i tell you what you need to do next ok follow these instructions
1. with mp3 off switch lock button to on position
2. press and hold rec button on left hand side
3 whilst holding down rec button switch mp3 on this should now be in recovery mode let me know if you get this far ok
Feb 23, 2008 | SanDisk Sansa e250 MP3 Player
Freeezing
Hi. The symptoms you described may be due to corruptions in the player's music database (this player maintains an information pool on the music files you download to it). To resolve that, you would need to delete that database and let the player re-create a new one. To delete the corrupted database, let's do this: Step 1: Switch your player to MSC mode Step 2: Browse the player in "Windows Explorer", and look for the folder named "System" and/or "Data". Note: if you can't locate these folders, your Explorer may be configured to "Hide" system files and folders. To change that, please go to "Tools" on the menu list on the Explorer window, then choose "Folder Options". This will display a Window arranged in tabs. Select the "View" tab, find the "Hidden Files and Folders", then choose the "Show Hidden Files and Folders" radio button Step 3: Under the "system" or "data" folder on the Sansa E260, look for this file and delete it: "PP5000.dat" Step 4: Safely remove your Sansa E260. Then power it on. Your player will now either display "Rebuilding Library. Please Wait" or "Finalizing Update". Either way, it would re-build the database and hopefully resolve the error your player is encountering. I hope this helps. I love the Sansa E260!!
Mar 15, 2007 | SanDisk Sansa e260 MP3 Player
"refresh database failed" how do I do a database refresh?
i have the same problem ... refresh database fail .. i can put songs on the player but it doesn't show them or play them :-( HELP!!!!
Nov 15, 2006 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
98 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
