Question about RCA HD52W59 HDTV Projection Television
RCA HD52W67 convergence menu missing from menu and has a b,r,g line going through the top of the menu and it looks like every thing is in 3d
Were can I find the two ic chips that everyone is talking about on a HD52W67.Is there anywhere online that I can download a shematic for this
RCA TV.Where can I find the fuseable links for this model to that people say to replace
  • RCA Master
  • 8,617 Answers
That model doesnt use the two STK ICs that most other models use. Try replaceing fusw fl231 . The schematics arent easially available for any RCA TVs unless they are the older projection ones. I would recommend checking with this link and seeing if they have the service manual or perhaps they can get it, if you leave an email with your model number.
http://servicemanuals.vstore.ca/
Posted on Jun 06, 2008
My RCS HD52W67 is showing three pictures on the screen. I have tried zooming, but it only makes all three pictures larger. I cannot get it to only show one screen. What can I do?
Your TV most likely has a convergence failure. You can get parts and instructions from www.tvrepairkits.com Here are some of the most common symptoms and example photos of a convergence problem Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
Nov 22, 2012 | RCA HD52W59 HDTV Projection Television
My rca projection screen tv picture looks like it is in 3D, the colors do not line up and it is warped at the top and the bottom, is there a way to fix it?
Yes there is. First are you missing the convergence menu? If so go to my tip at http://www.fixya.com/support/r5119668-fix_convergence_problems_rca_chassis which explains the problem and how to fix it. Let me know if you need more help.
Thanks for using fixya and for the generous rating.
hardrocko
Jul 25, 2010 | RCA P52926 52" Rear Projection Television
It is like looking at 3d in all three colors. i
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 30, 2010 | RCA D52W19 52" Rear Projection Television
RCA hd52w67 analog convergence problem.
with Tv off press and hold ch- and vol- at same time untill tv turns on then release and you should be in factory settings service mode.
May 26, 2010 | Televison & Video
I have a 52" rca hdtv. the screen looks like its in 3d. can this be fixed? model# hd52w67
It seem like a convergence trouble. I tink it is a ITC222 chassis in this set. If it is, you probleme is eeprom for convergence need to be reprogrammed and cause no power on convergence board.
Apr 22, 2010 | RCA R52WM24 52" HDTV Projection Television
Have the HD52w67 rca. Have a 3d effect. know we have to adjust the lamps. we go to menu but we have no auto convergence. What can we do now?
Is there a manual convergence setting in the menu? if so try to adjust the level 1, 2, and 3 settings. If not try to clean the lenses with qtips and alchohol.
Mar 07, 2010 | RCA HD52W59 HDTV Projection Television
Pic looks like 3d
Convergence chip and capacitors damaged on the Y sustain board Cant be tuned from the unit controls
Please rate my help++++Thanks for using FIXYA
Oct 24, 2009 | RCA R52WH73 Projection Television
I have a rca hd52w67 projection tv and the screen looks like it is concaved,has three lines across the top and looks like it is in 3d. What is wrong with it?
The convergnce amplifiers have failed.
This is a common old-age problem.
This requires replacing the convergence amplifiers and possibly resistors and fuses. A repair shop would charge $300-$400 to repair.
If you are tech savy or know someone who is, thae parts will cost around $40.00. Search this site for specific instructions.
Good Day,
-Dan
Sep 10, 2009 | RCA HD52W59 HDTV Projection Television
Tv looks like it is in 3D
Sounds like your convergence amp board has gone out and will need replaced. If you feel like giving it a try yourself this web site has them fairly cheap and they have an 800 line if you need help determining your board number.
http://www.moduslinkptstvboards.com/Default.aspx
Aug 13, 2009 | RCA HD52W59 HDTV Projection Television
Rca 52'' projection tv model p52937
Go to menu ,now to setup when in set up do you see convergence? If convergence is missing in menu it is a open fuse,only it does not look like fuse ,They look more like small square capaitors brown, they will be right next to flyback transfomer FL231 (3) of them in a roll it will be the middle one,you can take needle nose plyers and pull top up on fuses.
Dec 17, 2008 | RCA D52W19 52" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
956 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
