Question about Toshiba Satellite M65-S821 Notebook
Keyboard replacement I have the K000026590 replacement keyboard for the PSM60U-0CR021 but I can't figure out how the top would come off to get to the screws. Help please - it took 5 minutes just to write this on the old skipping keys board. - Dennis
    Guru:
  • 1,894 Answers
U can get the key board and replace it from a radio shagg
Posted on Jun 06, 2008
  • dewan nafees ahmed Jun 06, 2008
    u can get the appropriate screwdriver from the radio shagg shops or any local shops.. u need some special screw drivers for that..
    please respond
    Master:
  • 555 Answers
Do you have a manual for this laptop? If not, let's find you one.
How do I replace keyboard assembly on Samsung NF210 Netbook?
Here is a pictorial guide, step-by-step:
http://hope-works.weebly.com/change-netbook-palmrest.html
Jul 09, 2012 | Samsung NF210-A02 Netbook
Hi, I run Windows XP SP3 and my recently purchased LogiTech EX110 keyboard has intermittent keying problems where I get a repeated figure 5 when some other keys are pressed, particularly the figure 4. ...
Keyboards are easy replaceable parts, depending on the type of keyboard it is.. i know you probably like that keyboard, but perhaps you may need to take it back to the store and get your money back or replace that one as well. Since you say there was some conflict with software, I figure you probably had a driver issue with the keyboard, perhaps that keyboard is not compatible with your Windows XP SP3 // since a newer keyboard no doubt might be windows 7 compatible. Check to make sure again your KB is compatible with Windows XP SP3, Although, i know you probably have.. it wouldn't hurt to check again, you'll be surprise how something could be missed. :) Good luck, I hope this help.. If not.. perhaps others can weigh in as well :)
Aug 17, 2010 | Logitech Cordless Desktop EX110
We moved the computer and are currently trying to reconnect the mouse and keyboard. THere are instructions on the keyboard which we followed but the keyboard will not connect to the wireless device. Any...
check the bottom of keyboard and wireless pickup device..lights should be steady on..if not, reset with buttons..also, check battery charge, by replacing battery..also re seat the wireless pickup into another usb port.
Nov 28, 2009 | Logitech Cordless Desktop MX3200 Laser...
How to remove Insperon 1725 keyboard
Keyboard Dell? Inspiron? 1525/1526 Service Manual NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer). NOTICE: To help prevent damage to the system board, you must remove the battery from the battery bay before you begin working inside the computer. Removing the Keyboard Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer. Slide the keyboard cable out of the keyboard connector. 1 screws (2) 2 keyboard 3 keyboard tabs (5) 4 keyboard cable 5 keyboard connector latch Replacing the Keyboard Slide the keyboard cable into the keyboard connector. Rotate the keyboard connector latch to secure the cable. Align the tabs along the bottom of the keyboard and slide them under the palm rest. Press on the right edge near the top to snap the keyboard into place. Replace the two screws on the top of the keyboard. Or else if this is not clear you can also visit Support.dell.com Thanks Deepak
Oct 30, 2009 | Dell Inspiron 1526 Laptop
Some of the keys don't work. I've tried the solutions suggested so far with no luck
I would remove the keyboard from the laptop, clean the keyboard and the flex cable that goes to the computer, make sure its clean and reconnect it, then try it again.
To remove a keyboard it varies from laptop to laptop, take it to a local professional if you can't figure it out, it involves unscrewing 2-6 screws and possibly removing the plastic keyboard cover from the top of the keyboard which is between the display.
Sep 10, 2009 | Advent 4211c Notebook
Its typing numbers when pressed letters
If the wrong characters appear when you are typing or you are trying to use a keyboard that is different than the one that came with the computer, use the following steps to synchronize Windows to the type of keyboard you have:
  1. Click Start c01311982.gif , and type region into the Start Search field.
  2. Select the Keyboards and Languages tab.
  3. Click Change Keyboards .
    A Text Services and Input Languages window opens.
    Figure 3: Change Keyboard button
  4. Click Add .
    Figure 4: Add button
  5. Select the keyboard(s) you want to use and click OK .
    Figure 5: Add input language: US Dvorak keyboard selected.
    The new keyboard is added to the list of available keyboards and a keyboard icon appears on the system tray, allowing you to switch between the keyboard that you want to use with the mouse.
    Figure 6: Keyboard tray icon
  6. From the Text Services and Input Languages window, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    Figure 7: Move up button
  7. Click OK . You can now use the new keyboard. If you find that the new keyboard works well and you do not want to use the other keyboard, repeat these steps and Remove the keyboard that you do not want from the General tab of the Text Services and Input Languages window.
Jun 10, 2009 | HP 386209-001 Keyboard
Locked keyboard buttons
  4. Click Add .
Jun 02, 2009 | HP DC170B Keyboard
Laptop keyboard replacement
I had the same problem ... spilled a drink on my keyboard causing the keys to stick
Symptoms:
1) Internet explorer browser always jumps to top of page even when trying to scroll page down
2) Windows explorer can't select any items except the top or upper most item or folder ... top item always stays selected
Solution:
Fortunately, the keyboard is pretty easy to access. According to the service manual ...
1) Unplug the power cord from the wall and laptop
2) Remove the battery pack
3) Remove the lid covering the hard disk drive
4) Remove the hard disk drive and bracket assembly
5) Remove the 2 screws from the battery compartment
6) Unsnap the "Middle Cover" ... that's the small panel between the keyboard and LCD that has the power button located on it
7) The keyboard can now be gently lifted out
Download the User Manual ... SG_AS7720_7720G_BOOK.pdf ... click on the very small, almost hidden, looks like a legal disclaimer, link near the bottom of the page labeled, "Save file to your PC: click here" ...
http://www.2shared.com/file/3900367/f777f80e/SG_AS7720_7720G_BOOK.html?s=1
Order a new keyboard ...
Part Name and Description
KEYBOARD 17KB-FV2 105KS WHITE US INTERNATIONAL
Acer Part No.
KB.INT00.138
Google Shopping Search ... http://www.google.com/products?sourceid=navclient&rlz=1T4GGLL_en&q=Acer+Aspire+7720+Laptop+Keyboard&hl=en&um=1&ie=UTF-8&sa=N&tab=wf
Note: If you have a different model Acer laptop, here is a link to more service manuals ... http://www.acer-userforum.de/allgemein/9558-100-service-guides-anleitungen-service-manuals.html ... you can find part numbers listed in those.
Aug 29, 2008 | Acer Aspire 7720 Notebook
Have a replacement kb K000026590 a Tosh Sat M65-E821 (PSM60U-0CR021). I have no instructions as to how to be the top of the the case off - short of jimmying w/ an sdrvr. Help pleaaase!
hi this is how it is done in a HP laptop
i hope it helps you out
Remove the keyboard
  1. Loosen the four captive P1 Phillips-head screws that secure the keyboard to the base enclosure.
  2. Turn the notebook right side up and open the display panel fully.
  3. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and then place it upside down on the top cover.
  4. Using minimal force, lift the locking bar to unlock the pointing stick ZIF connector on the system board (only on models with a pointing stick). CAUTION: Use care to prevent damaging the ZIF connector and ribbon cable.
  5. Remove the pointing stick ribbon cable from the ZIF connector.
  6. Using minimal force, flip the locking bar up to unlock the keyboard ZIF connector on the system board.
All the best
AJ
Jun 05, 2008 | Toshiba Computers & Internet
Manual can be found here. Parts 1-3 must be downloaded before opening.
Directions from the manual for removing the keyboard:
(User-Replaceable)
Required Equipment
• #1 Phillips screwdriver.
Removal Procedure
Unplug the AC adapter, if present, and remove the battery.
Remove the keyboard cover (page 2-12).
Remove the four M2.5×4.0 mm screws that secure the keyboard to the top case.
Lift up on the keyboard at the switchboard PCA end and then pull it toward the display assembly to release the tabs from the top case.
Turn the keyboard over and disconnect the motherboard cable.
Remove the keyboard.
Reassembly Notes
Caution
Do not excessively bend or fold the keyboard cable. Excessive flexing can damage the keyboard cable connectors.
• Lay the keyboard face down on the top case, forward of its normal position, then reconnect the keyboard cable.
• Slide the metal tabs on the bottom of the keyboard into their slots in the top case, then lower the keyboard into place.
Apr 01, 2008 | HP Compaq Business Notebook NX9010
Toshiba Satellite M65-S821 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
