Question about Pioneer KEH-P8900R Cassette Player
KEH-P8900R hi, i am trying to find a replacement face plate for my KEH-P8900R as water does not go well with the old one and display has packed up. Tom
2 Suggested Answers
kenw392
  • 2226 Answers
SOURCE: I am having KEH-P8900R/X1B/EW PIONEER,
There should be a "band" button on the stereo. you may have to press it several times before you get to AM mode, depending on how many FM stations it will store in it's memory.
Posted on Mar 25, 2011
Keh pioneer will not illuminate
I am assuming you are talking about the tape deck (head unit) and not the changer. You more than likely have burned out bulbs in the face. Unless you are good at desoldering and soldering, I would suggest you have them replaced professionally.
Feb 23, 2012 | Pioneer KEH-P4400 CD Changer
I am having KEH-P8900R/X1B/EW PIONEER, by default it is playing the radio station FM- AF, I am trying to change it AM, but I did not get sucess. Can you please advice, how to change it. Thanks &...
Mar 25, 2011 | Pioneer KEH-P8900R Cassette Player
I Loss The Face Plate
Remove the stereo and check the model and serial number in the back
and check http://parts.pioneerelectronics.com/
and they might let you know if they have it available and the cost
have a nice day
Dec 06, 2010 | Pioneer KEH-P1010 Cassette Player
I have a pioneer KEH-P4100RDS head unit which the display has gone dim on ( seemed to half go out then a day or so later go fully out ), everything else works so was wondering if it is possible to replace...
Another issue with detachable face units is the spring on the latch gets weak over time and the contacts will not be 100% reliable. Try cleaning the contacts between the unit and the faceplate and also make sure there is not debris in any of the latching mechanisms that could be causing the face to not sit totally flush on the receiver. By the way, cassette tapes...really?
May 31, 2010 | Pioneer DEH-P645 CD Changer
My xdm6820 has no display showing. What do you sugest? Any ideas? It works fine but can not see clock or radio station. No display at all!!
There are two 3mm white LEDs inside the face-plate that need to be replaced. Remove the face-plate and turn it over. Remove the 4 screws in the corners. Un-snap the plastic back off the face-plate. This exposes the back of the printed circuit board. Pull the volume knob off the front of the face-plate. You may need to use a small screw driver to gently pry it up. Flip the face-plate back over and remove the one screw that's holding the printed circuit board in. Separate the printed circuit from the front of the face-plate. Be careful to not lose the spring for the push pin. Flip the printed circuit board over and you'll see a raised metal box surrounding the display. The one end of this metal box is covered in black tape. Remove this tape to revel a small cavity in the side of the metal box with two 3mm white LED in it. These are the 2 LEDs that need to be replaced. This cavity is so small there's not much working room. Note that the positive terminal for each of these LED is on the left and the negative terminal is on the right. Rather than un-soldering the old LEDs I found it easier to use a small pair of diagonal cutters to just cut their leads and then pull them out of the cavity. Leave enough of the old leads sticking up to solder the new LEDs to. Trim the leads of the new LEDs to the proper length, slide them into the cavity one at a time and solder their leads to the stubs of the old leads. Make sure you get the polarity correct. Put everything back together and you should be good to go. I hope this helps you out.
Dec 20, 2009 | Dual XDM-6820 CD Player
Hi.clutch noisy when engaging
Sounds like the clutch throw out bearing got water in to it. This bearig is what the clutch fork actuates. Being a bearing it allows the stationery fork to push against the rotating clutch plate. I expect you'll need to tear down and replace. While your in there I'd replace the clutch too. Give the clutch plate a good looking over.
I hope this may have helped,
Tom
Oct 15, 2009 | 1998 Mitsubishi Montero
The face plate does not light up
check your gas connections on your stove
Apr 25, 2009 | Pioneer KEH-P7800 CD Changer
PIONEER P5450
Tiny led bulbs behind fascia face need replacing
Oct 18, 2008 | Pioneer KEH-P5600 CD Changer
Hi, I need a wiring diagram for a Pioneer KEH-P3630R Radio/Cassette system
s.gif Faisceau avec connecteurs ISO pour autoradio PIONEER 12 broches
NEUF SOUS BLISTER
16 broches sur ISO - Dimensions de la prise environ 43 x 8 mm
Détail des câbles des haut-parleurs :
Blanc : HP avant gauche +
Blanc/noir : HP avant gauche –
Gris : HP avant droit +
Gris/noir : HP avant droit –
Vert : HP arrière gauche +
Vert/noir : HP arrière gauche –
Violet : HP arrière droit +
Violet/noir : HP arrière droit -
Détail des câbles d'alimentation :
Jaune : Permanent + 12 V batterie
Rouge : Alimentation + 12 V après contact
Noir : Masse
Bleu : Antenne motorisée
cote_g_olitec_j.gif Liste des autoradios compatibles :
cote_g_olitec_j.gif Série KEH cote_d_olitec_j.gifKEH-1100SDK
KEH-1150SDK
KEH-1200SDK
KEH-1300K
KEH-1300R
KEH-1300SDK
KEH-1311
KEH-1400R
KEH-1400SDK
KEH-1450
KEH-1450R
KEH-1500
KEH-1500R
KEH-1530
KEH-1530R
KEH-1540
KEH-1700
KEH-1700R
KEH-1730
KEH-1730R
KEH-1800R
KEH-1830R
KEH-1900R
KEH-1930R
KEH-2100R
KEH-2300R
KEH-2400R
KEH-2500
KEH-2500R
KEH-2520R
KEH-2530R
KEH-2700R
KEH-2710R
KEH-2720R
KEH-2730R
KEH-3400
KEH-3520R
KEH-3700R
KEH-3710R
KEH-3720R
KEH-3730R
KEH-4400R
KEH-4500R
KEH-4530R
KEH-4700R
KEH-4730R
KEH-5700R
KEH-5730R
cote_g_olitec_j.gif Série KEH-P
cote_d_olitec_j.gifKEH-P26R
KEH-P27R
KEH-P28R
KEH-P2800 R
KEH-P2830R
KEH-P3300 R
KEH-P3400 R
KEH-P3600 R
KEH-P3630R
KEH-P3700R
KEH-P3730R
KEH-P4300R
KEH-P4400R
KEH-P4500R
KEH-P 4510
KEH-P4530R
KEH-P4600R
KEH-P4610R
KEH-P4630
KEH-P4630R
KEH-P4700R
KEH-P4730R
KEH-P5700R
KEH-P5730R
Jul 14, 2008 | Audio Players & Recorders
Pioneer KEH-P8900R Cassette Player Logo
42 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
