Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint Washer/Dryer I think the filter on my Hotpoint Washer/Dryer is blocked - how can I locate the filter ?
  • Mo0o Oct 07, 2008
    My washing machine is leaking all over the kitchen floor, I can only presume that there is something blocking the filter so the water can't drain properly.
    I belive the filter is found behind the back panel.
  • Hotpoint Master
  • 3,463 Answers
The filter is located behind the removable lower rear panel.
Undo the clip that secures the large black hose to the bottom of tub.
Remove plastic filter and clean, replace , making sure the hose is securely fastened, and test for leaks.
Posted on Jan 04, 2009
I have a Hotpoint Aquarius 1100 washer dryer and think the filter might be blocked but I cannot locate the filter to check it. Any ideas?
Remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean the plasic filter inside hose..
Also check the pump for a blockage as well.
Thisn should solve your problem.
Dec 14, 2009 | Hotpoint Aquarius WD63 Front Load...
I think i've blocked the machine after washing some hessian sacks where is the filter?
Hi. Remove lower rear cover of washer.
Locate and remove large black hose from bottom of drum.
Filter is located inside the hose.
Please rate my solution.
Thanks.
Aug 05, 2009 | Hotpoint Aquarius WD63 Front Load...
Spin cycle not draining
Hi-ya Brian
Probably blocked filter.
To locate and clean, remove rear panel altogether, locate large black hose at bottom of drum, remove from drum, and you will find the filter located inside the hose.
Check drain hose is not blocked also.
Thanks.
Jun 17, 2009 | Hotpoint Aquarius WD63 Front Load...
I think the filter is blocked
To make it faster, I will report a good solution from barkencoa, that is one fo our experts.
I quote:
"Remove rear panel, locate large black hose at right lower side.
Remove securing clip and hose, inside you will see the plastic filter, remove and clean filter, note location of plastic ball.
Refit filter and hose, and securely fasten hose back on.
When you remove hose, watch out for water, as there will be some in the hose.
water test before fitting panel back on.
Plz rate my solution"
From Hotpoint aquarius filter problem
Feb 01, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wf325 filter problem, Blocked maybe?
You are correct as to the location of the filter.
Thanks.
Jan 08, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Not drying
the steam gets condensed back to water and pumped away so sometimes draining problems cause poor drying. is the machine plumbed in according to handbook?
also your dryer filter may be blocked but this is not accesable without the dryer box being stripped down.
Nov 05, 2008 | Hotpoint Aquarius WD640 Front Load...
I have a BWD 129 Hotpoint intagrated washer dryer and lights 1 2 and 4 are flashing what does this mean and do I need a new machine it will not do a drying cycle?
Filter blocked, disconnect hose from under sink connection and drain into bucket. Hotpoint does not want you to change filter, contact Service Engineer.
Apr 03, 2008 | Washing Machines
Not drying
if you hav'nt fixed it try the element in the dryer unit on the top of the drum check it for continuity have you any flashing lights
Nov 19, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
387 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
