Oil leak under fuel filter
The HPOP (high pressure oil pump) is right under the filter housing. There are 2 lines that distribute the oil to the cylinder heads. The o-rings on those fittings go out. Kit is available from Ford or International. You will need a special wrench to get to the fittings though.
O-ring in the high pressure oil pump .
CHECK
Well theres really not much there but the turbo seals and try to tighten the clamps to the air flow tubes oil tends to leak out from the inlet tube and the outlet tube
ford f250 super duty 4x4
coolant sensor for computer
leaking from fittings to fuel filter.
