SPlit green screen on Samsung LN-T3253H
This morning I turned on my TV to find that the left half of the image is green.  This appears regardless of which input component I select. I've disconnected and reconnected cables as I was told to do, but it's still there.  What could be causing this problem?
  • jtp1000 Sep 14, 2008
    On our Samsung HD TV, we also get the "green screen" but it only effects black. This may be a bit confusing so let me elaborate. It seems that all colors (red, yellow, blue, etc) show as expected but where there is black in the picture (say a picture of a dark alley way for example), instead of black the color is green. This is not a permanent condition but the TV will transition between this state and the correct state (showing black as black) in unpredictable times.
  • Anonymous Dec 28, 2008
    My new LG 37" LCD was working great for one day then suddenly the screen split and the picture turned green!!! HELP?!!? I tried turning off/on, checked connections, reset pic, etc... nothing helps?!?!!?
    Problem Solver:
  • 12 Answers
Have a look at my 'I broke the glass post'
Posted on Jun 06, 2008
The image on the screen looks like everything is in slow motion, the the color is messed up. I have already tried adjusting contrast, brightness, etc. Is this a fixable problem, or should I just buy a...
I know the colors are all messed up.But the tv LCD screen panel light it is bright enough to see the screen picture,and the tv LCD screen panel are clear,no purples,reds marks or bruses to the tv LCD screen panel itself?Yes,to all of these.The tv can be fixed.The tv Tuner signal board,that the board where the incomming broadcasting signal wire plug into it.The tv Tuner signal board it is dying and the problems to causes this.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.Will fixed this tv and get tv this to be working normal again.
Aug 20, 2011 | Samsung LN-T3253H 32 in. LCD Television
Hello. My Samsung LCD model # LN-T3253H 60"/61"
It sounds like your LCD panel or your T-con board is bad . Panels are expensive so I would replace the T-con board first. You have to open the TV and get the part number from the actual board in order to find the correct one. You can find parts at www.interliquidparts.com
Jun 03, 2011 | Samsung LN-T3253H 32 in. LCD Television
The tv has a green screen
If you're running Y/Pb/Pr connection, then double check that you have the connections in the right place.
Also make sure that both devices are set to Y/Pb/Pr and not Y/Cb/Cr. Should be able to find this in menus if it's an option to switch.
Apr 08, 2009 | Samsung LN-T3253H 32 in. LCD Television
Worth It?
It would cost just around the same amount of what the LCD TV is worth. I would get another one.
Feb 22, 2009 | Samsung LN-T3253H 32 in. LCD Television
Dlp tv hl-r5688w samsung
i believe the buld is bad replace it its cost from 200 to 500 dollars depending on the year and model
Jun 20, 2008 | Samsung Televison & Video
Picture Size problem with Samsung Flat panel LN-T3253H
You should contact Samsung service to know if the internal setup for the picture sizing was not adjusted properly at the factory.
Take care that some of these sets have a user zoom mode. Maybe it is in the zoom mode. Check in your instruction manual before calling for service support.
Jerry G.
Apr 12, 2008 | Samsung LN-T3253H 32 in. LCD Television
SAMSUNG TV
The LCD Screen can only be replaced. The link for this item is listed below.
Samsung LN-T3253H LCD Screen Replacement
Mar 29, 2008 | Samsung LN-T3253H 32 in. LCD Television
Remote code
If this is for a universal remote, the different manufactures assign their own user code to set up their universal remote. They internaly convert to the proper protocol for the TV based on an internal software table.
Jerry G.
Feb 21, 2008 | Samsung LN-T3253H 32 in. LCD Television
LN-T3253H issue with camcorder
Samsungs will not switch to an input that has no signal going into it. Try putting the cables into the TV, then hit play, then switch to the correct camcorder input.
Dec 24, 2007 | Samsung LN-T3253H 32 in. LCD Television
Televison & Video Logo
366 people viewed this question
Top Televison & Video Experts
Electro Med Services...
