Question about Denon DRA-455 Receiver
Denon DRA-555 Memory won't hold set FM stations when powering up
I have had this Denon Receiver since 1986 and it has been a good unit. I am still using it, however I am currently having a problem withe pre-set FM/AM stations. If I program the stations in and then shut the unit down, the next time I power up it does not keep these in memory. I would think this would be a simple fix, but not sure how to proceed. Would this be some sort of fuse? Again, every time the unit powers up for FM it is at 87.7.
Any help would be appreciated.
  • 1 more comment
  • werenka Dec 22, 2008
    I have the same problem with a Kenwood KR-A46. Must be the same amp with a different name on the front panel. Layout is a bit different, but the features are the same. It will remember the stations from time to time, so wondering if it has to do with power shutdown to the memory/keyboard/display IC.
  • werenka May 11, 2010
    I first looked for a battery, but none to be found. Any idea what kind of capacitor I would be looking for? I could just try every cap close to the IC :-| Unless someone has a schematic that can identify the exact one.
  • javichuchu
    javichuchu Mar 28, 2013
    You got to fix the problem, if you located the capacitor can you tell me where it was?, Thank you very much and I hope your answer soon.
  • 85 Answers
Most probably the memory capacitor / battery inside soldered to pcb
Posted on Jan 09, 2009
Unit shut off. Why doesn't it turn back on?
Unswitched power has nothing to do with the power supply of the receiver. Look for blown fuses or a failed component on the power supply.
Feb 20, 2016 | Denon DRA-545R AM FM Stereo Receiver
My Denon Stereo Receiver (DRA-345R) (quite an old model but has worked perfectly up until now) has a very static reception on AM. FM is fine. It started when I had my DirecTV upgraded with a Genie (whole...
it's obviously getting interferance fronm that whole house broadcast unit (not abnormal!) best and only thing you can do is to move the stereo to a place where you can get the MOST am stations the loop ant. is exactly what it says it is a loop of wire with two ends..both ends connect to the ant. input on the back of the unit..however if that whole house broadcast unit is the devil then an ant. no matter what or how it's made will only recieve more static not built to reject static! so you've got to move it unfortunately ..fm is a totally different band obviously fm isn't being affected by that whole home broadcast unit..you're lucky! on that count
Dec 12, 2013 | Denon AVR-2307 Receiver
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Sep 14, 2011 | Denon DRA-37
My Denon Audio precision am fm DRa 435R Reciever will not stay on station very long. After about 30 or sometimes 45 minutes it get off station. I have it set to a local FM Station, 97.9 and it plays good...
OK,this is a fairly common problem with digital tuners, I get them from time to time in my shop, you see, what is happening is the voltage that's used to tune the set, usual;y stays rock solid, your device however is drifting off station due to this voltage changing, usually it is in the powers supply or the actual tuner itself. It can be bad capacitors, bad IC's, bad transistors, bad tuner module. Sometimes it maybe a "Dry Joint" too.
The only fix is either a replacement PSU or Tuner or indeed maybe both? One simply cannot tell exactly without examining the unit.
You need to take this unit into a Denon repair center and ask for a "Quote" as to costings etc. Once appraised of that one can proceed from there?
Contact a Denon head or local office and ask them there, for a referral to an authorised service center.
Jul 18, 2011 | Audio Players & Recorders
My denon DRA-295 does not remember stations I set to memory when completely turned off. If on standby all goes well. A month after the problem mentioned above the tuner started to modulate reception and...
My better guess is a CMOS chip is either bad or there is a cold solder connection in the vicinity. If the power supply is bad, the receiver would not power up.
Nov 23, 2010 | Denon DRA-295 2 Channels Receiver
DRA-345R stereo receiver. FM is gone, poof! just like that. nothing looks burned. where do I start? No change to the antennae has been made
I have a denon DRA-345R and when I put on position mode cd I can listen music and then after 1 minute the mode change automaticly to position FM. Tell me please what a have to do?
Jan 31, 2010 | Denon Audio Players & Recorders
AS SOON AS I TURN ON MY DENON-395 RECEIVER IT TURNS OFF
I REMOVED THE AM LOOP ANTENNA. AND THE UNIT WORKED. TO MAKE SURE THIS WAS THE PROBLEM I REMOVED AND REPLACED IT SEVERAL TIMES. EACH TIME IT WENT OFF AND. I THEN PUT ON THE FM INDOOR (WIRE) ANTENNA. THE UNIT BEGAN TO PLAY BEFORE EVEN BEFORE I CONNECTED IT. JUST GETTING IT CLOSE TO THE FM COAX. MADE IT WORK.
Oct 28, 2009 | Denon DRA-395 Receiver
Denon receiver (DRA 397) will not speak to iPod dock
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
Oct 13, 2008 | Denon DRA-397
No sound to speakers with power on
OK. That tells me that the output section is good. This may sound silly, but check to be sure that the tape monitor switch is not on.
Dan
Jun 06, 2008 | Audio Players & Recorders
Panel Lock On. How can I turn it off?
make sure unit is off then hold down spker b and mode buttons and then turn it on
May 17, 2008 | Audio Players & Recorders
Denon DRA-455 Receiver Logo
760 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
