Question about Polaroid PDM-0742 Portable DVD Player
Bad disc... I have tried many DVDs that I know are good and bad disc appears on the screen
  • webland5 Jun 21, 2008
    I have the PDM-2737, I am also getting the Bad Disc Error. We only used it for a short time.
    President:
  • 814 Answers
1-866-289-5168 FOR ASSISTANCE. Try this number for technical assistance for you problem. Hope this helps you.
Posted on Apr 30, 2009
The machine keeps stating bad disc, for all dvds. We have the GoVideo DVD VCR combo... we tried playing several different dvds and the machine keeps coming up with "bad disc".
It could just be dirt on the lazer/lens. Try cleaning it with a good brand name lens cleaner for DVD/CD. If that doesn't do the trick there might be damage to the lens, or an electrical fault.
Jan 04, 2010 | GoVideo Go Video DVD/VCR Combo
"Bad Disc" message when reading a disc with JPEG files
Hi
Similar Issue happen to one of my client what we have done is putting the JPEG files into folders (Not Subfolder). It worked well however some JPEG images being skipped if the size is unusual. JPEG images will appear as tracks. Hope this will be helpful. If issue persist please post once more. Also let me know if WMA files are being played.
Good Luck
Jan 24, 2008 | Onkyo DV-CP704 DVD Player
I can't play dvds but I can play copied dvds
Most copied DVD-Videos for home playback use a CSS crack to strip the region code i.e. to Region 0 to they will work in all DVD players.
However most standalone DVD Players can have this restriction lifted using a sequence of codes.
First check your current firmware version to see if you need to upgrade:
1. When TV shows Philips wallpaper, close disc tray with no disc.
2. Press <0>, <0>, <0>, <9>, <OK> on the Remote Control.
Note: In case the firmware version does not appear on the screen, eject and close the disc tray to reset, and try again.
In this case region is 2 (UK) and the firmware is “Feb 23 2007” this is the latest for this DVD VR.
There are other codes that can be used to set this DVD to region 0 it might be a good idea for you do to the same with yours.
Nov 22, 2009 | Philips DVDR3380/05 DVD Recorder
MY BOSS BV7970 DO NOT PLAY ANY BURN CDRW OR DVDS
Some players are picky with certain cdrw/dvdrw discs. You might have to experiment with different brands/types for your discs. I used to have a cd player (teac) which would just refuse certain brands cd-r discs but play others just fine. I know it sounds odd, but once I noticed which ones work and which ones don't I never looked back.
Also, have the "problematic" discs been recorded on just one recorder? Have you tried playing discs recorded on a different recorder?
Also - I'm sure you've already tried it-it's always a good idea to clean the laser just in case.
Hope this helps+
Good luck,
Raf
Nov 13, 2009 | Boss BV7970 CD Player
After burning home movies on dvd - they won't play on dvd player or computer --- says disk error. Software says disc was successfully copied
Be sure you purchased compatible discs for your DVD player, ie. DVD +R or -R. Some players won't support both.
Jun 24, 2009 | JVC Everio GZ-MG21 Camcorder
PS2 will not play DVDs
hEy i hAd the sAme pRob...............dOn wOrRy all u hAv to do is to turn on uR pS2 witthout puttin a DVD oR aNy diSc........on mEnu screen gOto [options] by pRessing 'triangle' button......... a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst.....then insert the DVD movie........tURn off PS2....press n hold the reset button till the blue light is turned on......release the button and press it again.............. it wOuld take a little tYm foR uR DVD movie to be loAded........be patient till the movie plays it self..............
Jun 13, 2009 | Sony PlayStation 2 (PS2) Console
I'm having disc error messages or/and I cannot play dvds region 4
Below is a process to unlock the region's in that DVD player. There were a few methods try this one and post back letting me know how it goes.
1. Remove any disc in the tray.
2. Using the remote, turn the power off.
3. Turn the power on.
3. Open the empty tray.
4. Close the empty tray and wait until the player recognizes there is no disc in the tray.
5. Press "Menu, 1, 9".
6. A large rectangular area will appear in the bottom half of the screen; in the middle of the rectangle will be a single number that identifies the region to which the player is set.
7. Pressing the number keys on the remote will have no effect. Instead, use the up or down arrows above and below the "enter" button to change the region number. ("0" presumably is "region free".)
8. Once you have selected the region code (i.e., the number that now appears in the middle of the rectangle) press "enter".
9. Press the "opne/Close" button and the unit will save the selected code.
Hope this works let me know .Thank you for choosing Fixya! Feel free to leave a positive rating if this solution helps.
Mar 21, 2009 | Cyberhome CH-DVD 300 DVD Player
C:31:23 error on my sony digital handycam
i also don't think it has to do with taking the disc out since i did that with a new disc and it still works. i am unable however to view my data on the disc where the error 'movie recording disabled' appears--and it sounds like some of you can view the data. i'm wondering if my whole disc is bad?
Sep 17, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
"wrong disc" display
I have the same problem with my DP313 Norcent. I found though that it will play recorded dvds. It also will play older Dvds and some Anime ones. It will play older recorded mp3s but NOT newer ones, I'm not sure if it's because they are burned at a faster rate or what. Also it will not play any of the new dvds except as stated before some of the Anime ones. It pays to try everything out to ensure it not a mechanical problem. I found it's not with mine, but still unsure why it won't play new dvds?
Oct 10, 2006 | Norcent Technologies DP313 DVD Player
Polaroid PDM-0742 Portable DVD Player Logo
131 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
