Baxi 105 he
Ive lost pressure so have no hot water or anything how do i get the pressure back?
  • bobugdoo Sep 10, 2008
    disconected the filling loop and turned the water back on . The water came out of the filling loop but is not going into the boiler .Can anyone help?
  • Philly Bobs Dec 10, 2008
    I have the same problem with my Baxi 105HE and the local installer has said that I must have a leak around the heating pipework and to check the radiators. I have checked them all, and no leaks are evident. There is no water coming out of the overflow pipe but there is out of the condensate pipe - which I have been told is normal. I have to fill up the pressure to at least 2.0 twice a day to get the boiler to start and it drops down to 1.0 after a few minutes and remains there until heating goes off and gradually drops down to zero, so effectively will not come on via the timer. If the unit is set to Hot water only, you can see the needle dropping down gradually until it reaches zero. If the hot water is used it goes up a few small notches but then drops down to zero again and then eventually will not come on for water until it is topped up. Does anyone have any clues on this one yet ??
    Problem Solver:
  • 11 Answers
On the pipework near the boiler there should be a silver flexi hose connecting the two copper pipes ...this is called a filling loop there sould be taps on the filling loop turn on by moving the black plastic taps do this slow ..at the same time look at the pressure gauge on a baxi do not go over 1 bar...............
warning ..if the boiler has lost pressure where has it gone..is there any leaks anywhere..if it persist contact a engineer
Posted on Jul 07, 2008
  • 86 Answers
Heating Is a closed system, so if its loosing water that fast , must be a leak somewhere, look for green scale on pipework joints, or rusty spots around radiator, espescialy around the bleed valves and plugs at the top, also check the red pressure relief is not stuck open, turn it untill it 'clicks' shut to be sure. When filling fill up to about 1.5 bar then run system warm and go round bleed each radiator, highest first, then top up to about 1.5 warm.
Posted on Jan 01, 2013
Baxi heating
Have u got it set to heating and hot water.....Also check ur circulating pump is working
Oct 11, 2013 | Heating & Cooling
My pressure is low on my baxi boiler have attached feeder to pipes and turned valve to introduce water but the pressure is not changing, what am I not doing?
Does the water pressure before the heater is strong? if so then there is a problem with the entrance valve.There might be some object that blocks the entrance of water or the valve itself is not working properly.
Nov 04, 2010 | Heating & Cooling
Our mascot 330 system lost pressure when a water main broke. Now we can't get the pressure back up to restore the hot water. How do we build the pressure back up. Or who should we call?
Have you tried turning on the hot water for a few minutes?Is that what you mean by no pressure.I would call the maker.A repair shop may or may not tell you for free,you could try 1 or 2.Someone would be likely to,to attract future business mainly.Good luck! Greg
Aug 16, 2010 | Heating & Cooling
I have a potterton proforma28 boiler can anyone advise how to get hot water back as it seems to have gone off
if you go to the baxi potterton wed site you can down load a manual with fault finding on your boiler as this could be a number of things
Aug 07, 2010 | Heating & Cooling
Woke up the other morning with no heating or hot water from my 5 or 6 year old baxi 105e combi.i have,within the last 2 months, replaced the central heating temp sensor,and currently have the usual(and...
Per the User's Operating Instructions you want to check the condensate drain. Make sure it is free and clear. Also check the ingnitor, ensure there is no debris or buildup that could prevent it from firing properly.
Also, here are the Installation and Service Instructions that might be of help to you.
Without being onsite with toolbox in hand, I hope this information is very helpful to you. :-)
Mar 31, 2010 | Heating & Cooling
Baxi 130HE losing pressure
I would go with the valve first cheaper, then see if it still doing the same thing
Mar 04, 2010 | Heating & Cooling
I have a baxi 130he which loses pressure and I have to top up once a day. The copper pipe outside which I believe is an overflow is constantly dripping. Boiler runs fine central heating and hot water.
Hi the pipe out side is the pressure relief valve change the valve or it has something stuck on the seating , changing it will stop the pressure drop
Mar 03, 2010 | Heating & Cooling
Heating & Cooling Logo
654 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
