Question about E-Machines T2240 PC Desktop
E-machines desktop PC will not power up at all
We were given an older e-machines desktop computer with a standard tower. It worked fine for a month or two, but then one day we went to use it and the power up button does not even work. The power source is fine, but no sounds, no nothing. Help.
  • 2 more comments
  • jangel Jun 07, 2008
    wow same thing. have had computer for a few years and monday morning nothing when you push the on button. everything was fine. no hint of a problem just wont power up. thought for sure power supply had failed until i read your post, now i am unsure about ordering a new power supply. is there a way to test this one or do i have to just spend the $30 and hope for the best.
    john
  • Anonymous Jun 08, 2008
    Similar problem to the June 7 post. Came back from 2-week vacation, and was unable to power-up the machine. Pressing ON-button has no effect; light does not come on. The power cord is plugged into a power strip with other peripherals (monitor, mouse, printer, router), which are all OK - and all on same power strip.
    There were no power outage or surge events while I was away, since no other electronic devices in house show any signs of power disruption - just the PC (4-yr-old T2984 desktop, by the way).
    1. Tried mfgr's suggested step of removing power cord for at least 10 seconds, then reconnecting it, and then powering up - to no avail.
    2. Tried using a different power strip socket - no effect.
    3. Tried using a different power cord - no effect.
    4. Have not yet opened case (waiting to hear reply from trusted expert).
    Suspect Power Supply, but have seen posts elsewhere that indicate PS failure could cause other problems
  • Anonymous Jun 14, 2008
    Yeh, I was just given an Emachine that just quit running. I replaced the power supply, and checked the power switch(with multi meter-ok) on the front of the machine. Still very much dead. I suspect the circuit on the mother board has failed. I Will pull it apart later, but don't have much faith as it is an emachine....Rick
  • ronq Jun 28, 2008
    Have the same problem, cannot power up the unit. It was working fine, when I returned from a trip it was dead. I too suspect the power supply, but I'd like to verify berfore I order a new one.
  • 58 Answers
1) Check and see if the switch on the power supply is turned on (if there is one).
If it still won't turn on then most likely the power supply is dead. It's not very expensive to replace.
The other explanation might be that the power-on switch maybe broken...
Posted on Jun 10, 2008
My computer mouse and keyboard not functioning well. I replace the keyboard but only last a month.
Hi jhunix,
I'm going to need even more information; The devices that use PS2 connections, which device is it, and how many of those devices do you have?
One thing that might be a problem, if the issue you see is intermittent, I would check the PS2 connector and see if the pins are bent or broken. PS2 connector pins sometimes will bend or break and this can cause some connection issues if not completely stop the keyboard/mouse from working... Also given the age of your PC the PS2 port may just be bad, but this is not a fatal injury to a computer.
Replacing the Keyboard and Mouse with a standard USB keyboard and mouse, should resolve all of your issues.
PS2 is an older technology that keyboards and mice used to run on; Now however USB connections are used.
Further more, if this an HP Desktop with 2 USB ports on the front, and 4 USB ports on the back, you will want to avoid using the 2 USB ports on the front, especially on older HP and Dell Desktops, the reason is the power supplies often do not have enough power to run multiple USB devices on the front USB ports.
The back ports should be fine regardless of the number of devices.
Hope this helps.
Dec 10, 2013 | Computers & Internet
M5640 power comes on no video. changed motherboard and power supply
I assume you are using the integrated video, (on board). With a new power supply and motherboard you have eliminated all but the monitor. Try a different monitor. I have also seen a case where a computer tower worked fine in one setup with a flat screen, but when hooked up to an older CRT monitor it would not display because of the resolution settings.
Apr 07, 2011 | Acer Aspire m5640 PC Desktop
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
Power supply first. at least 450 watt.
If you need more let me know
Mark
Apr 11, 2009 | E-Machines eMachines Desktop PC
Power cutting out from tower. EMACHINES 550
There maybe to much dust build up on your cpu cooler that causes it to shut down to protect itself it needs clean about every 2 months or less to make it run smoothly.That is one solution the other solution is that your power supply needs to be clean also or replaced.Buy a can of air from your local computer store or walmart etc......
Jul 28, 2008 | E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz...
Pc start-up failure
It could be overheating. Make sure all the components and fans inside the tower a clean of dust. Get a can of compressed air and blow all the dust out. You could also try removing and re-seating all your pc cards, memory sticks and cables.
If you found this information helpful please vote.
Thank You
Apr 19, 2008 | HP Compaq Business d530 PC Desktop
Monitor connection problem....
Check your battery in your computer, it should read 3Volts, if it don't you need to replace it. If it is fine, then your monitor don't work.
Mar 16, 2008 | Computers & Internet
No power after external power failure
The first thing I have to advise you is to change the Power supply unit. Before buying one change it with another one (probably from a friend's PC) and see if it is working. To remove the power supply unit, you need to remove your tower's case, and unscrew the power supply and remove it. the power supply is the metallic box on top of the computer at the back.
Oct 08, 2007 | E-Machines H2824 PC Desktop
Power Problem
It sounds to me like your power unit inside the tower smoked. If you have the time and patience, replacing the power unit isn't to difficult to accomplish. You need to go to your computers manufacture online and download instructions via e-mail. There might have been a power overload that caused it to go. You can also remove all connections and take the whole tower to a repair shop to be tested. Usually $25.00 or less to verify problem. Hope it works.
Jan 30, 2007 | E-Machines T2792 PC Desktop
E-Machines T2240 PC Desktop Logo
80 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
