Question about Philips 42PFP5332D 42 in. Plasma Television
TV is trying to turn on by itself
Purchased the set in November 2007, connected to direct tv, for a while i kept hearing this clicking noise coming from the set, as if it was trying to turn itself on, at first it would do it at 5am on the dot, doesn't do it anymore, now it happens about 11pm and i believe i caught it at 3am, the screen is black and the blue power light is off, what i do notice is that it is lit in the back( seen the reflection on the living room wall, checked the auto clock and it's on manual. any idea's why this is happening, also the set is plug on power surge as well as the cable box, dvd and vcr. thanks
    Problem Solver:
  • 18 Answers
Last time i saw this problem...tried doing a firmware upgrade to update software...did not work....replacing power supply fixed problem...open uinit up...get p/n from power supply board...try ordering board from andrews electronics in california or send board to PTS electronics for repair/board swap...Be careful...power supply can give you a shock even after its been off for awhile...you can discharge large caps by bridging a 10k ohm resistor across them making sure not to touch anything..JOE ACE
Posted on Jun 13, 2008
Why does my Samsung LED TV have sound but no picture?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 30, 2014 | Samsung Televison & Video
This TV has Model number 2404141 serial number H466DD2D7 also ATC 106 and service # 2404141T This is a relative's set. When turned on, either with the remote or button on the cabinet, it acts as...
id suspect power supply boad is faulty......
if you can use a soldering iron.............
replace the caps on the board..........or search ebay for a replacement board........
cheers
May 02, 2011 | RCA Televison & Video
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
52" plasma tv - turns on - and I hear something reset inside
i hear a clicking noise- the clicking noise is most likely you ballast trying to power the lamp, but failing. this may indicate a defective ballast if you have recenty purchased a new lamp.I recomend you have your lamp tested to help narrow down the cause of the defect. It's highly unlikely for a new lamp to be dead on arrival
Dec 04, 2008 | Dell Televison & Video
Clicking noise in the back of tv and wont come on no standby ligh
The TV is in protection mode because of a fault with moving it and then coming on briefly I would suspect that the fault is a dry joint ( a solder joint which has fractured) finding it can be time consuming but it is most likely to be around the caps in the line output stage which need resoldering.
SUPER8
Dec 01, 2008 | LG 30FZ1DC 30" TV
Magnavox 27m53404/17 Picture went out
Hello there, I'm having a major problem with my TV, I have called all of the local TV repair shops and they all are the same, they want money money money before they will even speak with me about the problem I'm having. This is the only TV in my entire household for a family of 4 and we desperately need the TV in working condition for our kids. I don't want to have to put out $500 for another set if I don't absolutely have to.
The Problem...
About 3-4 months ago the TV when turned on, the picture would slowly come into view and be very scrambled and before the picture would come into complete view the TV power would shut itself off, but the power light would remain on. You can hear the "Click" noise when it would shut itself off.
2-3 seconds after it 'shut itself off' then the TV would make the "Click" noise (The same noise it makes when you first turn it on), it would make the "Click" noise over and over and over again but nothing would happen. So i would turn it off and on again and change the channel rapidly until after 2-3 minutes it would come into view and work.
So we decided to leave the TV on 24 hours a day. Then today we awoke and it was off and making the "clicking" noise over and over and over again but with no picture or sound. Now it wont even turn on/off it just sits there and goes "Click, Click Click Click" and doesn't do anything.
I described the problem as best as I can. Here is the TV information and specifications...
Philips 27 Inch Tube TV
Model Number... 27PT54 3S37A
Serial Number... 78438404
105 Watts
60HZ
120V
Date Code March 2003
Now that I typed the model number there are threads everywhere people saying the same issue exactly as me, I will read them but please someone tell me is there anything I can do...
Can anyone explain exactly what is wrong with the Tv and why it's doing this?
Also, what should I expect to pay to repair it?
Any information or help would be appreciated very much.
Thanks in advance,
Anthony
Just got off the phone with certified Philips shop...they said they will repair it for $100-$130 with a $25 down payment just drop it off and he will call me when its done. Does this sound like its worth it or a rip off?
Sep 07, 2008 | Philips 27PT543S 27" TV
Tv wont turn back on
Hii.... first I like to know the chassis of yor KV27FS100..
sound like problem with regulated parts block.....and can more helpfull if you count the blinking of the LED....sony have selft diagnostic at the LED Blinking.....
I hope hear from you soon....
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Feb 23, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
My RCA TV turned itself off and started making chirping noise
You have poor solder connections these sets are famous for this! Solder Flyback transfomer pinns this should fix it.
Oct 07, 2007 | RCA D52W19 52" Rear Projection Television
TV turns on & off by itself
You can check the board where the components are mounted and resolder any that look bad. a brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. all can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced.
Nov 17, 2005 | RCA 32F530T 32" TV
Philips 42PFP5332D 42 in. Plasma Television Logo
90 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
