Question about IBM Netfinity 5600 8664 Server
Boot Problems... Complicated...
Just got this mahine from a computer teacher of mine, and we've been trying to fix it. It used to run fine but hasn't been used in a while. I tried to boot and got nothing at first, just power on. i'm getting a post test error for starters. 3 short beeps, pause, 3 short beeps, pause, 3 short beeps, then silence... attempted looking this up and only got results for a 3500, and its a RAM error there, between registered and unregistered DIMMs, but i checked and it's all registered 256mb ram (PC133) and its what it needs... this is not a novice solution, or i would be able to figure this out... It has done some strange things on occasion too... If more info is needed i will gladly post more, i just dont know if this server is too old for anyone to know much about it...
The IBM Netfinity 5600 is a complicated beast for sure. You really need to get a copy of the Netfinity Manual from IBM (not on the web site fyi.). It's as big as the machine unfortunately. In section 3, p.124 it lists 3-3-3 beep code as "No memory has been detected in the system" solution is "Reseat mem modules or install mem modules. If prob persists get machine serviced." On the previous page, 3 short beeps (only) on POST indicate "system mem error. combo only occurs when video bios cannot display error msg. replace the failing mem module." You might also want to check the light-path diagnostics inside the machine. A little light will be illuminated right beside the bad DIMM.
Posted on Jul 08, 2008
  • nerdmeback Jul 08, 2008
    Oh yeah, you need to have registered ram with ECC. it is very picky. It's a server class machine so it needs the high end ram. non-reg, non-ecc retail ram will not work on this beastie.
    Order of ram install is important. Put the biggest dimm in j1, then next biggest in j4, then j3, then j2. The web site has the errata on this as the manual actually has it backwards.
    Just found a copy of the manual online at IBM FTP...check p.199...
    http://tinyurl.com/6peotw
I'm unable to use my desktop PC cause black screen says: reboot and select proper boot device or insert boot media in selected boot device and press a key _ what can i do to fix it?
I'm Electronics Telecom Engineer,webdesigner ,seo, PC support professional,Online teacher via skype I'll help YOU
to fix problem REMOTELY Please feel free to contact me anytime via e-mail at besubmitbe@gmail.com, or on Skype at bpshbp
Jan 13, 2014 | Acer Computers & Internet
HP Pavillion dv6700t black screen issue
You might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below...
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Jun 29, 2012 | HP Pavilion DV6700T Notebook
Compaq presario v6317 not turning on
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
May 04, 2012 | Compaq Presario Computers & Internet
MSI usb problems
Sounds like your O/S was damaged when the old MB failed. I'd boot the computer with yoru system disk and run a scandisk or, in the case of Win Vista or 7, choose the option to repair Windows.
Mar 21, 2012 | MSI Microstar KT6 Delta (MS-6590)...
Code 19 Error
How to Fix Windows Error Code 19
f your computer's CD or DVD drive appears to be missing or corrupted and you've received a "Code 19" error message that says "Your registry might be corrupted," you can fix it by following some steps to modify the Windows registry. Note that while this process isn't particularly complicated, it does require that you are familiar with computers and know how to modify the Windows registry. If you aren't comfortable doing this, you should seek the help of a qualified computer professional to assist.
Instructions
1. Click the "Start" button, click the "Run" option and then type "regedit" and click the "OK" button.
2 Use the navigation pane on the left side of the window to navigate to the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10
3 Select the "UpperFilters" key in the right side of the window, then click the "Edit" button and then click the "Delete" option. Click "Yes" to confirm the deletion.
4 Click the "LowerFilters" key, then select the "Edit" button and choose the "Delete" option again. Click confirm the deletion.
5 Close the Registry Editor window and restart the computer to finish applying the settings that should fix the Code 19 error.
_________________________________________________________________________________________________________________________
How To Fix Registry Code 19 Errors
The Code 19 registry error is caused by a system hardware failure. The failure occurs because the computer is trying to use two drivers for the same device on the computer. When you try to boot your computer, you will get a Code 19 error message that will lock you out of the computer. You can resolve this error by using the Safe Mode option
Instructions
1. Start your computer and then press the "F8" key while it is starting up. This will take you to the "Advanced Boot Options" menu. Scroll down to the "Safe Mode" option with the arrow keys on your keyboard.
2 Press the "Enter" key and wait for the computer to boot into Safe Mode. This should take about 45 seconds to complete. Click the "Start" button when the computer has booted and then click the "Run" box.
3 Type "Regedit" into the run box and press the "Enter" button. This will start your registry checker tool. Wait for the registry checker tool to complete the scan. This should take about one to five minutes to complete. When the scan has completed, you will be prompted to restart your system.
4 Click the "Restart" button when prompted to restart your computer. The computer will restart as normal and the Code 19 error will be fixed.
The Windows registry is a large database that contains the settings and configurations for hardware, programs and applications running on your computer.
Dec 02, 2011 | Computers & Internet
I have a 2004 Chrysler Sebring Sedan 2.4 DOHC. About a year ago, When my fuel gauge would go below 1/2 tank of fuel, I start having problems. It sputters and dies when I stop. It starts back up fine,...
Hi Angie,
I don't want to be too harsh, but you need to stop randomly replacing parts and stop putting chemicals in your fuel tank.
I have been in the auto repair business for over 36 years and that garbage that they sell at the parts stores have never fixed a drivability problem that I have ever seen. Those things are only stuff that "snake-oil salesmen" use to part desperate people from their hard-earned cash. There is no such thing as "mechanic in a can".
A seasoned, well trained, automotive repair technician with a few years of experience, can scan your engine computer, look at the data when the engine is running poorly, and give you a pretty good idea of what is causing your problem....This is what is called DIAGNOSTICS. You can spend a fortune and loose a lot of hair over trying to "guess" what the problem is.
Please also review the following articles. You may find them somewhat "enlightening".
Why Is My Engine Light On?
What Else Could Be Wrong?
Oct 09, 2011 | 2004 Chrysler Sebring
19 inch slyvania tv/dvd combo turn on play button stays on and the the tv goes to red green yellow and blue screen and won't do anything else
I have been having just about the same problem with mine, i can watch the tv for about 20 min and then the dvd player comes on by itself then it goes to red, green, yellow, and black and white, i've tried resetting the dvd player to default but it hasn't helped mine.When i try to turn it off it automaticly comes back on so i have to unplug it.If i find a way to make mine work right i will send you a message to let you know so you can try it on yours. I've had mine just over a year and i don't have a warrenty anymore.
Aug 08, 2011 | Sylvania LD195SSX 19 in. LCD TV
Power saver problems
Did it come out of power-save mode when you connected it to the other computer?
Does your laptop have a "toggle":
* video-output only to internal LCD screen
* video-output only to external monitor
* video-output to both displays
If so, toggle the setting to "external" or to "both".
Dec 14, 2009 | LG W2252TQ Monitor
IBM Netfinity 5600 8664 Server Logo
430 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
