RCA P52755 ST buzzing audio
My television's audio is buzzing.   If you make the audio loud enough it drowns out the buzzing.  I do not have a manual since it came with the house when we bought it.   I think It is around 10 years old. What can I do to eliminate the buzzing?
    Genius:
  • 1,030 Answers
Buzzing audio.. does the set buzz with the audio all the way down. sounds like a torn speaker to me.. disortion in audio is cause be this or bad audio ic
if the set make the noise with the sound down could be something else. This unit is not a dlp therefore does not have a color wheel
Posted on Jun 06, 2008
  • Willie Howell Jun 06, 2008
    this is a rather old set.. the high voltage splitter in these set are a common problem after a few years.
  • 3,037 Answers
The High Voltage Blocks tend to go after this many years on these sets. This is the first thing that you should consider replacing. Many times when one thing starts to fail, others follow, so it may be wiser to just buy a new tv but if you want to fix it, this is the first part that you should replace.
Let me know if you have any questions about doing this, make sure you replace it correctly and good luck doing this
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Jun 06, 2008
    The color wheel is not the problem, this would be a high pitched sound not coming from the speakers, if its coming from the speakers, then its the HV block
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • Benjamin Patri
    Benjamin Patri Jun 28, 2008
    President:
  • 2,712 Answers
Most likely the color wheel is the problem. This part can be replaced but is difficult and requires considerable dissasembly and then a difficult alignment process. Reccomend an RCA auth. service center for this repair.
  • Swilin Sampson
    Swilin Sampson Jun 06, 2008
    If your Tv is a CRT, then most likely it is a flyback issue or the auto transformer is faulty. In either case, I wouldn't recommend you opening up the TV, as there are charges in there that can kill if you do not have prior experience.
    And, unfortunately, even the very best brands are not recommended for
    repairs after they have reach 8 years or beyond. This is because they
    are too near the end of their normal life. Fixing this will cost some
    money, but there is a very high probability that another failure will
    occur soon after the repair; and again and again. Soon you will have
    invested huge sums of money into it.
    As to the particular repairs needed all indications, from the buzzing
    and the high pitch sounds, are the high voltage and/or the deflection
    systems have failed. These repairs result in repair costs of around
    $250 plus or minus. Also, the manufacturer no longer supports models
    this old and it may be hard to find replacement parts.
    www.partstore.com does have a few parts for this model; the high
    voltage splitter/distribution box is around $92, for example, if that
    is one of the components that could have failed in the high voltage
    area. (This could be a part of the problem).
My RCA 52inch DLP TV has 5 blink red lights and is making a loud buzzing sound. I am pretty sure it's the color wheel, but from your experience, could this be it?
the loud buzzing could mean something is stuck in the color wheel or that it's shattered. Either way, you're going to need a new color wheel, I agree.
Feb 04, 2010 | RCA Televison & Video
My RCA projection tv makes a loud buzzing, humming noise. Does as soon as turned on even before picture comes on, does not stop till tv is turned off.
buzzing noise is cause by small electrical arc inside the unit or a problem in your audio circuit.if you can open the unit up and check if its an electrical arc.
Jun 21, 2009 | RCA HD52W59 HDTV Projection Television
RCA P52755 BA - Rear projection won't turn on
This Tv is CTC169 series. Look, you have 2 options repair. 1'-Power supply don't run properly 2.- Possible leak coolant or High voltages splitter is bad. If do you have any experienced on soldering station, I recommended replace 2 electrolitic capacitors in pwr supply section. 2.2uf 100v and 39uf 100v. If pictures tubes leak...Still repairable, but need be washer pure good ( usse alcohol 90%) and tied screws CTR gasquet. I hope this help you. Thank you
Aug 10, 2008 | RCA P52926 52" Rear Projection Television
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Loud Buzzing Sound
Sounds like the cooling fan blades are hitting something (possible worn bearings).
Apr 21, 2008 | RCA P52926 52" Rear Projection Television
Buzzing loud noise constantly.
I HAVE A RCA 50 HDTV DLP MODEL #D50LPW134 IT MAKE A BUZZING SOUND AND NO PICTURE i CHANGE THE BULB AND STILL NOT WORKING.
cantrin@hotmail.com
Ken
Dec 12, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Great pic but bad sound
Your problem could be the main amp board, the signal panel or the audio processor board. You will need to get a service manual for this set to diagnoise these problems. Good Luck
Mar 31, 2007 | RCA D56W20 56" Rear Projection Television
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
