Question about Panasonic KX-T7633 Corded Phone
DND button will not turn off
DND/CF light lit up and Im not hearing the phone ring. Its a panasonic phone that we have here at work but Im not sure the model.
    Scholar:
  • 38 Answers
Depending on how your system is programmed, you might be able to turn it off by pressing it. Otherwise, you might have to press it and dial a code number, which also can vary from one installation to another, but I would try "0"
Otherwise, it can be programatically corrected by your installer if the system got "stuck" or something.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
Kx-t7433 how to turn on fwd/dnd does not work
What happens when you dial 165 on the intercom? If you get voice mail, then try dialing 7104 165 # on the intercom. That sets CF-No Ans to voice mail for your set and the FWD/DND button should light solid (or not, it's a program option) or flash. If you dial 7101 it should turn on Do Not Disturb (7100 cancels). In DND, the FWD light should flash.
Once you have set these two conditions up, the FWD/DND button has 3 states, FWD, DND, and OFF.
Carl
Jul 10, 2012 | Panasonic KX-T7633 Corded Phone
My Panasonic Phone KX-T7630 rings seventeen (17) times before going to voice-mail. Desired amount of rings before going to voice-mail is four (4) to five (5).
This is just for your phone ringing when it's dialed, not for outside lines ringing on your phone.
From your intercom, dial *7104 (CF No Ans) 500 (if that's your VM extension) # That will flash your FWD/DND light to tell you it's forwarded on No Ans. Now on the intercom, dial *71324 The 713 part tells your phone to forward after xx seconds. 24 is about 4 rings. You can adjust the timing using 6 seconds as a ring cycle.
Carl
Jun 28, 2011 | Panasonic KX-T7630 Corded Phone
Why can't I turn off the FWD/DND flashing light?
It will flash for 2 reasons. The phone is in Do Not Disturb, The phone is forwarded and the lazy installer didn't change the button indication to solid.
What happens when you press the FWD/DND button on an idle phone? In most systems, it's supposed to toggle between FWD DND and OFF after you press it more than once. If that doesn't work, try pressing FWD STORE 0 STORE. That should turn off FWD/DND and unset it.
However, here's the problem. Your phone may have CF-condition set to send busy and unanswered calls to voice mail. We do that so the individual extension can set his own transfer to VM time. Those commands start with *710x and the VM extension which is 500 by default. For example dialing *7104 500 on the intercom will set CF-NA to the voicemail port on a TDA/TDE system equipped with a Panasonic Voice mail system. When that happens, the FWD/DND light goes either red or blinks red and the forward condition is set.
You can review the operations in the OM for your system under Call Forward and Do Not Disturb.
Carl
Mar 04, 2011 | Panasonic KXDT343 Phone
I have Panasonic KX-T7420s with a TVS50. I have voice mail set up at each extension number. I tried calling from an outside number and transferring to a different extension number to see if I can leave...
Take a look at the manual. One of the bits in programming deals with the status of the FWD/DND button. You can make it light solid for FWD and flash for DND. There are other ways to intercept the calls, but trust me, this is the cleanest. You set 7104 165 # and it will forward always on no answer after x rings. Those rings are set system wide and can be adjusted in programming.
If you sit down wiht the PG manual, pay attentiion to programs 202,203,619 and 990 area 9 bits 3&4. A ring cycle is about 6 seconds and the default intercept is TWELVE rings....you should adjust that to no more that 4.
Car
Dec 27, 2010 | Panasonic KX-T7420 Corded Phone
Panasonic Digital Model KX-T723OE The key FWD/DND
I'm guessing that you didn't mention that the phone doesn't work, it must be in FWD mode. You can cancel CF, or get someone to go into 990 area 9 bit 3&4 and reverse the bits so it will be solid on FWD and flashing on DND.
Carl
Nov 03, 2010 | Panasonic KX-T7730 Corded Phone
What I can do
I would check that the volume is turned up (lower right button). If that doesn't work, I'd take a look at the DND (Do Not Disturb) function on the phone. Good luck!
Mar 03, 2010 | Panasonic KX-T7730 Corded Phone
I want my phone to be the first line
You can clear the FWD/DND conditions by dialing *790 on the intercom, but that probably won't do what you want.
Phone ringing is controlled by programming and it should have been set up at installation. Maybe you can join forces with this guy :-)
http://www.fixya.com/support/t2945714-fwd_dnd
You may need those instructions if you drop all of your extension programming.
Carl
Sep 17, 2009 | Panasonic KX-T7630 Corded Phone
How do I put my phone on DND?
You get a chance for that to work next time :-)
Panasonic features are in the system, not the phone. If you have a TA series, from the phone, pick up the handset and press the FWD/DND button and dial 4#. (you may also dial 71 in place of pressing the button).
Cancel is 0# in place of 4#, but you also have CF to voice mail issues, where 1+VM EXT is all calls and 2 is BUSY/NA.
If you have a TD or TDA or TAW system, you get lucky, because the FWD/DND button works in 3 modes. For DND it's 7101 or *7101. The button will light with a solid red light and when you press it, it either flashes or goes off. The system gives you both FWD and DND settings.
Carl
Apr 05, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic vb-42211 phone won't ring. How do I
1) Press PROG, follow by programming no. 50 or FWD/DND button.
2) Press ENTER or STORE, follow by selection no. 0=OFF FWD/DND, 1=ON FWD/DND.
3) Press ENTER or STORE to save the setting.
4) Press EXIT or PROG to quit setting mode.
YBC (/\)
Feb 18, 2009 | Panasonic KX-T7633 Corded Phone
FWD/DND - PANASONIC KX-T7130
Don't laugh. Push the button and read the display. It will either unset DND or CF :-).
The 7100 command is part of the sequence to cancel those features on most phone systems and 790 or 79# will reset the extension. Of course it may be different if you have a TDA or TAW box (*7100) or a KX-T xxx10 system.
Carl
Nov 16, 2008 | Panasonic KX-T7130 Corded Phone
Panasonic KX-T7633 Corded Phone Logo
320 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
