Question about Garmin StreetPilot c340 GPS Receiver
Garmin c340 my garmin c340 will not locate satelite any suggestions
    Scholar:
  • 52 Answers
First, be sure you are outside, in the open when making this diagnosis. Some cars have metallic defrosting layers, which blocks the GPS signal. If, when outside in clear view, you still have problems, try this...
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get the unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Posted on Jul 18, 2008
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
Garmin Nuvi 265 GPS wont recognize satelite
Look near the SN # and press the reset button.
Jun 14, 2009 | Garmin nuvi 265 Car GPS Receiver
Garmin c340 will not charge. I tried pressing the reset button under the faceplate. Any other suggestions?
How old is it? Could the battery need replacement ?Mine still works but the battery like has gone down to an hour.
Feb 24, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin nuvi 350-can not change the location it is stuck on
you may need to reset it, as in resetting the c340, turn off and then press back on again, if this does not work maybe the reset button is in the same place as it is on my c340, instructions for the c340 is as follows: place your thumb nail in the groove located under the Garmin logo on the face plate, gently pull off the face plat, press the reset button, turn the unit back on and hopefully it will operate normally
Dec 28, 2008 | Garmin Nuvi 350 Car GPS Receiver
We cannot get our garmin c340 to acquire satellites.
turn it on and use it more ,even if going to grandmoms house ,for some reason they lose satelites when not in use.i found useing it or at least turning it on every day has cured the problem.hope this helps
Dec 28, 2008 | Garmin StreetPilot c340 GPS Receiver
GARMIN CANNOT LOCATE SATELITE
Try Update it Here, This resolves transient satelite problems.
Regards
Dec 17, 2008 | Garmin StreetPilot c340 GPS Receiver
Frozen touch screen on
hold down the power button when you turn it on until the calabaration screen comes up and that might fix your problem
Nov 01, 2008 | Garmin StreetPilot c340 GPS Receiver
Locating satelites
Are you outside, exposed to the GPS signals?
If so, have you tried resetting the unit?
Remove the face cover (GENTLY pry it loose by using the fingernail groove directly under the GARMIN logo), press the RESET button, then re-attach front cover... this is covered in the owners manual, also available online at garmin.com /support /downloads
Feb 27, 2008 | Garmin StreetPilot c340 GPS Receiver
Saving Favorites before updating Garmin c340
Use MapSource to transfer the Waypoints from the unit to your PC. If you lose them, you can then transfer them back. (I updated a C330 from 4.40 to 6.10 and did NOT lose them, however.)
Feb 23, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
49 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
