Old Hard Drive Installation as 2nd Drive
Company's computer for used for creating keying systems wouldn't power up any longer.
Replaced with Gateway 2000 which was in use in office.
Took HD #1 from defunct computer & installed in Gateway as master, then used old "D" assigned HD from Gateway & installed as slave.
Now, even though BIOS lists both drives properly and as master and slave, and the drive from defunct unit is assigned as "C", I cannot access the other drive by any higher letter command such as "D", "E" or any other letter.
AND...no matter which one I assign as slave, it still boots up into the same "C" directory on the original drive.
Any suggestion would be welcome.
  • 46 Answers
First check your boot sequences. If you want to get it to boot from the defuct PCs HDD you will need to see which is booting first. Bios will remember the actual hard ware by serial etc, not by which is master and slave.
If you just want to run the programs off that drive, then are you running windows?
check out the computer management tools (found in the administrator tools section of the control panel) and there you should be able to use disk management to see what drives are there.
Here you can change drive letters and will be able to see if the drives are being picked up by windows
Posted on Jun 06, 2008
Recovery disk for SX2855-UB10P
At what stage of the installation process do you get the message ?
Which operating system are you trying to load ?
Is there an operating system on your hard drive ?
You have to format your hard drive using a third party disc to erase everything on your hard drive
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
Note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
Note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
Hope this helps.
Jan 24, 2013 | Gateway SX2855-UB10P Desktop - 2GB Memory...
System recovery on a gateway 6214 laptop
Try This:
    • 1 Back-up any important files to an external hard drive, if at all possible, before proceeding.
    • 2 Place the Windows Install CD into the computer's optical drive. Restart the computer with the disc inside. As the computer starts up, it will prompt you to press any key to boot into the Windows Install CD, press any key to do so
    • 3
      Press "Enter" to bypass the "Welcome to Setup" screen. Press "F8" to accept the Windows License Agreement. Windows Setup will ask if you'd like to install any available updates to the operating system. If you currently have a (wired) Internet connection, download the updates. If you do not, you can install the updates after the restore completes.
    • 4 Select the "Custom" installation route. Select the internal hard drive as the installation destination. Press "D" to delete any and all data on the hard drive. Confirm this action by pressing "L". Press "C" to create a new partition to install Windows. You will need to use the "NTFS" file system, as this is the Windows default.
    • 5 Continue the installation by following any on-screen instructions. You will be asked for the Product Key, your region/time zone and to create a name for the computer. The whole re-installation, reformat and restore process will take a little over an hour. Once complete, the computer will reboot to apply the finishing touches. Remove the Windows Install CD at this point to avoid booting back into the disc. The Gateway laptop will launch into a freshly restored Windows installation.
Jul 18, 2012 | Gateway MX6214 Notebook
Trying to remove the hard drive in an old desktop, how do I do it?
Almost every computer manufacturer has their own way of installing hard drives on each system they make. You should look up your specific Gateway system at their website and look for service and support. There should be instructions posted. Given that Gateway is failing or has failed as a company there may not be any resources available. If that is the case you should take the computer to a computer service center for assistance.
Jul 27, 2011 | Gateway Computers & Internet
How to make a potission on new hard drive
If you running win XP, here is a small video that shows you how:
http://www.youtube.com/watch?v=bwNLNYhTaEk
Sorry for the bad sound.
Its almost the same in vista.
Hope this was helpfull.
Mar 12, 2011 | Dell Computers & Internet
I WANT TO INSTALL 2003 SERVER ON IBM X236 BUT IT IS SHOWING NO DRIVE PRESENT
Use the IBM configuration disk and it should be able to prepare the server for what ever OS you need to install. If you don't have it then, try redoing RAID and reformat the hard drives and try again..You can probably hit F6 during the initial portion of the install and supply the necessary SATA drivers on a floppy and get it to install. You will probably need a USB floppy though unless your server has a floppy drive.
Insert your Microsoft Server 2003 Installation disc into the CD/DVD-ROM drive and boot the server from the installation disc. Microsoft Setup will load the files it needs to perform an installation. Press "Enter" to setup and install Windows.
  • 2 Press "F8" to accept the Microsoft License Agreement.
  • 3 Create a new partition to install the operating system onto by selecting the "Unpartitioned Space" and pressing "C." If there is no unpartitioned space, highlight and delete all of the other partitions on the hard drive by pressing "D." Set the partition size to the "Maximum Size" and press "Enter."
  • 4 Format your new partition with the "NTFS" or the "NTFS (Quick)" option. Windows setup will format your hard drive and load the installation files. Your IBM Netfinity will restart and installation will continue.
  • 5 Select language and regional setup information, then press "Next." Enter your name and company name, then press "Next." Enter your Windows 2003 Server Product Key and press "Next."
  • 6 Select the licensing mode you would prefer to use and press "Next." Create an administrative account and password and press "Next." Enter the current time and time zone and press "Next."
  • 7 Setup your Network information by naming the server and defining how it will connect through the net. Press "Next" to navigate through the network setup screens. Windows Setup will finish the installation process and provide you with a log-in screen to use your computer.
  • If you delete old partitions from the hard drive to install Windows Server 2003, you will lose all information on those partitions.
    Jan 20, 2011 | IBM eServer xSeries 236
    My 13 year old son laptop need be reset like new
    There are a couple possible solutions to your problem. If the computer will still turn on and load windows, and I assume you are using Windows XP, you can try doing a system restore. To do this, go to Start, Programs, Accessories, System Tools, and select System Restore. If system restore is enabled, you should be able to choose a date in the past when the laptop was working properly and restore the computer to that date. If you want to completely reload windows, you will need a Windows XP installation disc. Load the disc in the CD or DVD player and reboot the computer. You should see a screen asking you to press any key to boot from CD, go ahead and press Enter. You will now enter setup where you can reformat the hard drive and reload windows XP. Follow the on-screen instructions to delete any old partitions, and then create a new partition and format it using NTFS. The windows XP installation will continue after the hard drive is formatted. If, when you reboot the computer with the installation disc in the drive, you are not prompted to boot from CD, you may need to reboot and press F2 or F12 to change the boot selection to the CD or DVD drive so it will load the CD first before it tries to load your original Windows installation.
    Jul 18, 2010 | Dell Inspiron 1525 Laptop Midnight Blue
    When powered on it says os not found
    Make sure that there is NO CD or DVD disc loaded in the CD/DVD drive while you are turning your laptop ON. Eject all CD/DVD discs are restart.
    Nov 10, 2009 | Gateway MX3560 Notebook
    I have a gateway m285-e and can't get XXp Sp2 to recognize the Hard drive. How do i fix it??
    hi guy
    just follow this guide it'll help you
    fisrst of all get the driver from here :
    http://support.gateway.com/support/drivers/getFile.asp?id=20455&dscr=Gateway%20Notebook%20Computer%20Intel%20SATA%20Support%20DriverVersion:%205.5.0.1035
    then follow this guide
    Note: Installation of this driver requires the use of a floppy disk drive. If your computer does not have an internal floppy disk drive, an external USB drive can be used instead.
    Download the driver file to the desktop, and then perform the following steps.
    1. If you have not already done so, locate and double-click the D00455-001-001.exe file that you downloaded from the Internet and execute the file. Files extract to the C:\Cabs\D00455-001-001 folder on your hard drive.
    2. Insert a blank floppy disk in the floppy disk drive.
    3. In the C:\Cabs\D00455-001-001 folder, double-click F6flpy32.exe.
    4. Click OK to start the disk creation.
    5. The disk creation dialog box closes when the disk is complete.
    6. During the installation of Windows you will need install this SATA controller driver. Press the F6 key on your keyboard to install a third party controller driver.
    7. The Windows installation program requires the use of a USB floppy disk drive and the floppy disk that was created above.
    8. The Windows installation procedure attempts to load the drivers twice; once directly after the F6 selection, and a second time after the installation files copy to the hard drive.
    9. Select the "- Intel(R)82801GBM SATA AHCI Controller Mobile ICH7M" option as listed.
    Note: To find the required selection it may be necessary to scroll down even though there is no indication to scroll down.
    Note: If you experience any recognition errors during the installation, please reference this Microsoft Knowledge Base article KB916196. This article explains which USB floppy drives are supported by the Windows installation process. http://support.microsoft.com/kb/916196/en-us
    Removal
    Because the computer must have these SATA drivers when using a non-Gateway supplied operating system, these drivers are necessary and should not be removed.
    just let me know
    Oct 15, 2009 | Computers & Internet
    Have problem with windows Xp pro.
    You can get the correct drivers from the Gateway website. Use another computer and download all the Windows XP files for that model number from the website. You need your model number of your pc. Get the files for your motherboard, video, sound card, network card, etc. save them to a usb key or a burn them to a cd. Take the usb key/cd to the other system and load the drivers.
    This will get your system back up and running in now time.
    I hope this helps you.
    Feb 18, 2009 | Microsoft Windows XP Professional
    Western digital Scorpio 120 G
    Actually there is no solution, the hard drive is bad.
    What I ended doing was recording the partition in iso. ( I had a Factory Partition)
    Got a new hard drive 160G scorpio unfortunately it does not come with installation disc.
    Installed Vista, and with vista created a partition and then installed the contents of the factory partition.
    Feb 18, 2009 | Western Digital Scorpio WD1200BEVS 120 GB...
    Computers & Internet Logo
    53 people viewed this question
    David Payne
    David Payne
