How do I restore file? directions in device are not clear. I see no "my backup folder" to check. I need to restore an entire file to my C drive. Your help please.
  • 46 Answers
Was this file recently deleted? in windows? you wont have a backup unless you are using a program to regularly back up your files.
First stop would be to check the recycle bin which should be on your desktop
Posted on Jun 06, 2008
Iphone data recovery
You can restore iPhone backup from iTunes. Obviously, we always choose to restore backup on iTunes directly.
Step 1. Connect your iPhone to your computer using an USB cable. Then launch iTunes.
Step 2. Click device button to the left of the iTunes Store button in the top right corner in iTunes. Then click "Summary" in the left sidebar.
Step 3. Click "Restore Backup" in the right part, iTunes will begin to back up your device.
iphone-data-recovery-oxaxc0rwhkhzilrwacqreyis-5-0.png How to Restore iPhone from iTunes Backup
Nov 12, 2016 | Apple iPhone Cell Phones
Tip
How to back up a offline disk folder
<p>Backing up your computer in a folder on the hard disk that goes offline, because sometimes surprisingly simple for the Windows Sync Center. You have a network available offline. Your computer will copy the backup of the hard drive of your computer's hard drive when you're online. The folder will appear as if it were accessible online, because the files are copied to the folder on your computer and then sync when the device is online. <br /> <p><br /> <p>1. Click "Start", "computer" and open the folder with your backup folder. Right-click the backup folder and click on "always available offline." <br /> <p><br /> <p>2. Waiting for the files in the directory so that the copy on your computer available offline. <br /> <p><br /> <p>3. Right-click again on the backup folder and click on "Map Network Drive". Click "Finish". <br /> <p><br /> <p>4. Click Start, Control Panel, System and Security "and" Backup and Restore. "Click" Create Backup.<br /> <p> <br /> <p>5. Select the mapped drive that you defined earlier in the Drive list. Click "Next" and follow the steps to complete your backup to adjust. Click Save Settings and perform the backup. " <br />
on Jun 22, 2011 | Computers & Internet
Tip
How to copy program using True Image
<p>Acronis True Image allows the computer to back up the data. The programs can periodically back up the entire hard disk, either online or in another physical disk. It can also backup individual items, such as files, folders or programs. <br /> <p><br /> <p>1. In a clear picture, click "File backup" from the main window. "The backup file is opened. <br /> <p><br /> <p>2. Navigate to the folder in the program with the left panel. For example, if you want the program to copy folder with the software Menezes "in" Program Files "directory, navigate to" Program Files ". <br /> <p><br /> <p>3. Folder from the right window. <br /> <p><br /> <p>4. Select the destination of the "target" drop-down box. For example, if you program to a "D" of the secondary unit. <br /> <p><br /> <p>5. "Backup Now" button. <br />
Toshina External Hard Drive backup files in
Which program did you create the backup with? You'll need to install a copy of that software on your new computer. Then you will let the software find the backup and restore it. This will only work if you used a file backup. Many backup programs do not restore to systems with different hardware (different CPU, hard drive, OS, etc.).
However, I don't know which software uses *. PFT, pfi or pfp extensions. PBF is the format for one of the older Paragon Backup software versions. Acronis uses *.TIB . For a list of many of the software extensions used for backups, see https://www.file-extensions.org/filetype/extension/name/backup-files .
Canvio drives used to include NTI BackupNow EZ software. However, I believe that NTI backups use BJF or NTI extensions. The installer for that is here: http://support.toshiba.com/sscontent?contentId=3044104 . To check for other software for your external drive, try looking up your drive at http://support.toshiba.com/support/home . The available drivers and software should be listed. Alternatively, check if the backup software installer is still on the external drive.
I hope this helps.
Mar 03, 2017 | Toshiba Canvio Plus 320 GB 2.0 Portable...
How do i delete only selected message recipeint or call from the log. How do i move any received file into any folder in memory card. Not in memory card..but a folder in memory card
Hi, you can delete selected message recipient by using Conversation View in Nokia X3. Please open Messages menu and select Conversation view, now select option on any message recipient then select Delete Conversation to delete the messages sent by a particular recipient. You can delete Calls from the log by opening Log Menu and selecting "Clear Log lists". You cannot move any Messages directly to the Memory Card or to a folder in Memory Card. However you can backup all Messages, Contacts, Calendar, Notes...etc to the Memory Card by going>Menu>Settings>Sync & backup> Create backup option. This will create backup on which you select like Messages, Contacts...etc to the Memory Card. You can restore the created backup by using the "Restore backup" option in the same Sync & backup Menu. It is also possible to restore the backup by directly opening the backup file which you have created in the Memory Card.
May 05, 2011 | Nokia X3 Cell Phone
I am preparing to do a PC restore for a problem unrelated to Seagate products. Will FreeAgent C7200 back up my emails, one account in Outlook and and the other web based, so that they can be reinstalled?
You can backup all your programs in the free agent with the help of the software that is provided with the drive please read all the instructions very carefully like how to backup and restores the file from the drive before reinstalling the OS and remember there is always two options available one is file backup and another is system backup.
Mar 05, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I bought a refurbished Tungsten E. Because there was some incompatibility with the software version of my other Tungsten (which is on its last leg), I downloaded new software off the internet. In the...
Are you syncing the new device to the same username in Palm Desktop as an older device?
If you are, this will cause problems on the new device. When you sync the device, it saves the device settings, 3rd party apps, preferences, etc. in the backup folder in the username folder on the PC. When
you sync the new device it copies the contents of the backup folder for the old device to the new device. This will cause corruption in the settings for the new device thus causing erratic behavior of the new device.
Looks like you may need to hard reset your device and rename your backup folder
Go to http://www.palm.com/cgi-bin/cso_kbURL.cgi?ID=887 and follow the directions to do a hard reset. Next before you hotsync your data back over you will need to rename your backup folder, to do that go here;
XP
C:\program files\palm or palm one\[hotsync username]\ and rename your backup
folder to backup.old
Vista
Start-->documents\Palm OS Desktop\[hotsync username]\ and rename your backup
Then hotsync to your current hotsync name and all your contacts, calendar,
tasks, and memos will come back over.
Show file extensions for XP or Vista
XP
If you can not view file extensions on your PC I would like you to open a
folder go to Tools-->Folder Options--> View (tab) and under show hidden
files and folders uncheck hide file extensions for known file types.
Vista
Open control Panel go to Folder Options--> View (tab) and under show hidden
Mar 28, 2009 | Palm Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
