Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
Makita 6405 3/8
Can you change the drill bit? how?
    Champion:
  • 313 Answers
According to my breakdown its a drill. do you checked if there is a screw inside the chuck. if there is one remove it by turning clockwise.open the chuck fully & insert allen key 5/16 or 3/8 short side to the chuck.tighten the chuck & wak the allen key with a hammer counter clockwise. do it again if required.putting back together the other way.
Posted on Jun 09, 2008
Makita HR2450 drill all functions working fine drill bit will not lock in
Here is the manual for your drill. Pictures show to install and remove the bit. http://powertool.manualsonline.com/manuals/mfg/makita/hr2450x.html
Apr 10, 2017 | Makita Drills
Makita hr1260 drill won't rotate. how can I fix it?
have an appliance centre check out the drill motor as it may be burnt out.
Apr 22, 2015 | Makita Drills
The chuck on my new makita drill is stuck with a drill bit in it. It won't open back up.
This is caused by tightening the chuck using the drills power, if you clamp the bit in a vice and using a pair of multi grips on the chuck in an anti clockwise direction gently bounce the grips and after a few tries it will undo, don't use too much pressure or try to unwind it in one move or myou will damage the chuck sleeve
Oct 16, 2012 | Makita Drills
Change drill bit on makita dc18ra
on most you just push in the nose of the driver it will release
Jun 29, 2012 | Makita Lxfd01cw 18-Volt Compact...
I can't loosen the the sleeve that holds the bit and therefore I can't change my bits.
Stick the speed fix to 1, put drill in reverse, and hold on to the chuck as hard as you can, and squeeze the trigger.
Jun 07, 2012 | Makita 12 Volt Cordless Drill/Driver Kit
The screw point got stuck inside of the makita
Low quality steel drill bits get stuck in the Makita because the hammer impact squashes the metal, forming a ridge that gets snagged on the anvil's steel ball bearing. Use only impact drill bits.
Sep 15, 2011 | Makita 18V LXT Lithium - Ion Cordless...
Changing Bit
where the bit goes into the drill there is a metal ring. Pull the metal ring away from the drill with one hand and pull the bit out. this model you may have to pull the meteal ring twards the body of the drill.
Feb 26, 2010 | Makita 9.6v Cordless Impact Driver 6903VD
How do I change the bit on makita 6095d The drill bit is on right now and I simply want to change it to the phillips screwdriver bit. Thanks
have you opened up the chuck to remove the drill ? If not then you need to by holding the chuck tightly with your hand and then run the drill in reverse. hope this helps you
Oct 05, 2009 | Makita Drills
I can't unscrew the bit?
just above the operating button there should be a lever that pushes left to right.
Jun 16, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
193 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
