Question about Canon FaxPhone L75 Plain Paper Laser
Canon L75 Black Vertical Line
I had one of the people in a remote office open the front flap and clean what was hopefully the scan bar where the document is scanned and a black vertical line is still coming up. I'm having her change a cartridge when she gets in, any other ideas?
    Problem Solver:
  • 16 Answers
The problem is with the cartridge itself and should be cleaned as the toner has dropped on to the roller inside the cartridge and causing the lines. or you could change the cartridge and see if that works.
Posted on Jun 17, 2008
When I scan a receipt a 2" line (vertical) appears. I've purchased and tried the cleaning kit but it didn't remove this black line. Please help
It seems as though the scan bar (the bright light strip that scans the document) has a faulty receptor. It needs servicing or replacement. Assuming it's under warranty take it back to your supplier for repair/replacement/refund.
Mar 06, 2015 | Office Equipment & Supplies
Vertical blank strip
clean the roller and the cartridge head with alchol.
Jul 18, 2008 | Canon FaxPhone L75 Plain Paper Laser
Scan gear code 2 156 50 met CANIN PIXMA 6350
I frequently had this error message code 2,156,50 with my CANON PIXMA MG3500. The error code tells you there is a USB problem. I re-installed the Software, used new cables, bypassed USB Hubs and and and........ Result: Sometimes it works for the moment then it stops working a few days later but nothing is really reproducible. In the meanwhile I think I found out what it really is. In my case it has nothing, really nothing to do with USB connections (possibly in other situations it has to do with it). To solve it do the following: Shut the Computer down, switch your CANON on and OPEN THE FRONT FLAP. The restart your Computer. As you all know the PIXMAS will not print when the fron flaps are not opened. It seems so that keeping the flaps shut when you just scan (there is no need to insert paper in that situation) error code 2156,50 is initiated forcing scans to stop. Since I leave the front flap open the Problem never reocurred.
Hope that helps other users as well. REG. Gerd
Dec 11, 2013 | Canon PIXMA Office Equipment & Supplies
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
I have a big black line down the middle of my scans
If dirt sticks to the scan module, it will be scanned continuously and appear as a line in the output. Clean the glass with Isopropyl Alcohol. Dont use any other solvent.
S. Mohan, India
Mar 12, 2013 | Canon DR-5010C Scanner
Vertical line appears with APF
Open the ADF cover and clean off the narrow scan glass (most likely has white out on it)
Jun 03, 2009 | Canon imageCLASS D680 Laser Printer
Red vertical lines, scanning to computer
I had one red line appear when i used the duplex. I happened to notice that the thinner glass window on the scanner was dirty. I cleaned it and now no line appears.
Nov 24, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Thin black line 1.5 in from the right side of the paper going down the whole page
If it doesnt have a line on it when you scan it and open up the document then it's not going to be a scanner issue, more then likely, it's going to be an issue with the toner of the printer you are using to print with. Check the drum on the toner and you'll probably see the line in question on the drum itself. You'll just have to push back the flap that covers the drum on the toner if this is a laser printer... hope this help's if it does, please mark as a FIXYA!!
Oct 06, 2008 | Canon DR-9080C Path-Through Scanner
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Canon FaxPhone L75 Plain Paper Laser Logo
108 people viewed this question
old marine
old marine
