Question about Samsung Televison & Video
I have a samsung 50 inch dlp tv. When I turned it on yesterday it is making a really loud noise and most of the color is gone from the picure and it is shaky. Any idea what is wrong. It sounds like a fan motor burn out or something.
My 50 inch samsung TV just started making a very loud noice when I turned it on today. I have to turn the volume up very loud to drown the sound. What's up with that? what is wrong with my TV?
Posted on Nov 20, 2009
  • Samsung Master
  • 8,617 Answers
Most likely the color wheel is faulty and will need to be changed. Does it make a squealing noise?
Posted on Jun 06, 2008
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
My first gen samsung dlp tv makes noise from back and will not turn.when it happened it was going in and out of color
Tv have a colors wheel.Colors fade in and out or flashes black and white within the picture.The tv making humming or loud motor noises the colors wheel is dying and not spinning correctly in it motor anymore.The tv must have it colors wheel replace,will solved this problems.
Jan 01, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung hlr5078wx DLP tv. rumbling noise and shaky picture
This is a color wheel problem.
I would recommend to use professional help because you can make more damage to the optical engine. Not to mention index delay have to be re-adjusted in special service menu after repair is complete.
Regards.
Russ.
Jul 23, 2010 | Samsung HL-R5078W 50" HDTV
Replaced the lamp bulb on my samsung HLP5663. It went on right away. Though the problem was fixed. Turned the tv on a little while ago and the picture is gone. The timer light is blinking. Any ideas what's...
Now tv turn on.Hear alots of clicking or squiling,loud motor noises turn on?Alot of clicking,the Ballast board it dead,this board help ignite the projection lamp.Tv also have a colors wheels.The colors wheel is dead,if hear squiling noises,loud motor noises.
Jul 14, 2010 | Samsung DLP HL-P5663W 56" TV
50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call PartStore.com
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Apr 28, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
My tv is making a loud buzzing noise
Bearings in color wheel going bad and needs to be replaced. Call a local tv repair shop on pricing and availability of color wheel for your model and chassis
number.
Dec 03, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-R4266W..no sound or picture. TV is completely dead
Assuming the noise is a high-pitched whine, then yes, it is the color wheel.  If the color wheel goes out, the TV will turn on for a while, then turn off when it can't establish color wheel sync.  The color wheel has to be in sync with the mirrors on the DLP, so if sync can't be established, the TV turns off.
You can order a new color wheel from Sears or partstore.com (among other places) and replace it yourself, if you are so inclined.
Jan 24, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Loud squealing noise from dlp tv -50 inch samsung, modelHLN507W
your color wheel needs to be replaced the squealing noise are the bearings.
Jun 10, 2008 | Samsung Televison & Video
Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Dlp vertical lines
the person you talked to at samsung is more than likely a customer support rep that does know anything but what his computer tells him. i have seen this symptom several times in many makes and models. if you can give me your full model number i will give you a part number to fix this issue.
Oct 24, 2007 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
269 people viewed this question
Henry  Thomas
Henry Thomas
